POV-Ray : Newsgroups : povray.binaries.images : Car WIP 4 Server Time
23 Jul 2026 07:21:55 EDT (-0400)
  Car WIP 4 (Message 6 to 15 of 15)
<<< Previous 5 Messages Goto Initial 10 Messages
Subject: Re: Car WIP 4
Date: 1 Oct 2001 10:36:10
Message: <3bb87f5a@news.povray.org>
"Dan Dombrowsky" <ddo### [at] vtedu> wrote in message
news:3bb879f9@news.povray.org...
> Nice Work!
> I think the easiest way for a license plate may be a heightfield. *looks
> through links* I think someone has a tutorial about making flat-type objects
> with hfs. Hmmm...
Thanks. After trying to do a guitar with a violin shaped bulge via a heightfield
and not liking the results(reflection looks bad), I try to stay away from height
fields. But then again it would probably work for a number-plate as it's not the
most important part of a car(design-wise)....
Thanks
- Nekar
Date: 2 Oct 2001 01:09:16
Message: <3bb94bfc@news.povray.org>
"Nekar Xenos" <j-p### [at] citywalkcoza> wrote in message
news:3bb87f5a@news.povray.org...
> > Nice Work!
> > with hfs. Hmmm...
heightfield
height
the
Given it's lack of importance, and the fact you'll not likely have a close-up
shot of it, then you might be able to use a thin slice of a superellipsoid cube
(for round corners) and use the image you might make for a height-field as a
bump-map instead.
Batronyx ^"^
Date: 2 Oct 2001 01:37:22
Message: <3bb95292@news.povray.org>
"Batronyx" <bat### [at] cadronhsacom> wrote in message
news:3bb94bfc@news.povray.org...
> > > Nice Work!
objects
> > > with hfs. Hmmm...
> heightfield
> height
> the
cube
> bump-map instead.
Sounds good to me. Thanks.
- Nekar
Date: 2 Oct 2001 17:41:35
Message: <3bba348f@news.povray.org>
To me, a heightfield is the best choise here. Have you ever seen what some
people (Jaime Vives Piqueres) can do with heightfields? They're fast,
efficient and, why not, quite precise. I'm quite sure one could make a whole
scene just with heightfields!
Jonathan.
"Nekar Xenos" <j-p### [at] citywalkcoza> ha scritto nel messaggio
> > Nice Work!
objects
> > with hfs. Hmmm...
heightfield
height
not the
> Thanks
> - Nekar
Date: 3 Oct 2001 01:48:46
Message: <3bbaa6be@news.povray.org>
"JRG" <jrg### [at] hotmailcom> wrote in message news:3bba348f@news.povray.org...
Well, it maybe fine for the number-plates. In the past I've tried doing shiny
round objects with heightfields, but it had a course matt finish, even with
hi-res bitmaps and the best settings to my knowledge. Maybe you can tell me how
to do smooth round objects with heightfields? I remember the first thing I
thought of when I heard of height-fields was doing a face.
- Nekar
Date: 3 Oct 2001 13:29:50
Message: <3bbb4b0e$1@news.povray.org>
Hi, I'm an old Pov-Ray user, once I was used to read regularly this
newsgroup but now I'm somehow a newbe.
So, what does 'WIP' mean? I wasn't able to find it.
Thank you, Massimiliano.
news:3bb83535@news.povray.org...
> Fixed the mirror. The mystery CSG that kept me busy for hours on end,
trying to
> find where it came from was actually just the inner part of the wheel well
> reflecting the tyre and outside! Fixed it by changing the colour to a matt
> black. The blue texture is getting better, but it's still not exactly what
I
> want. Still got to do the panels and doors I've been promising. I think
I'll use
> negative blobs, so that the edges won't be too sharp. And then there's the
> interior...
> Does anyone have any suggestions on how to do the number-plate?
> I find myself only seeing certain mistakes when I do the large final
renders. I
> wish there was a way to do real-time modelling renders. I've tried +q1
with
> simple textures but it's still very slow. Any ideas?
> - Nekar
Date: 3 Oct 2001 14:09:16
Message: <3bbb544c@news.povray.org>
Work In Progress. It's nice to see a fellow from my country, city,
University in this newsgroup!
Cheers,
Jonathan.
"Massimiliano Cirri" <m.c### [at] ingunifiit> ha scritto nel messaggio
news:3bbb4b0e$1@news.povray.org...
> trying to
well
matt
what
> I
> I'll use
the
> > interior...
> renders. I
> with
> > - Nekar
Date: 3 Oct 2001 14:25:40
Message: <3bbb5824$1@news.povray.org>
Blurring the h-f image in your favourite image-processing package should
help you here. The quality much depends on its resolution. And don't forget
*smooth on* in the h-f block!
Jonathan.
news:3bbaa6be@news.povray.org...
some
whole
shiny
with
me how
> - Nekar
Date: 4 Oct 2001 02:07:42
Message: <3bbbfcae@news.povray.org>
"JRG" <jrg### [at] hotmailcom> wrote in message news:3bbb5824$1@news.povray.org...
That's just it. I a very high res image and I used smooth on. It just doesn't
seem to work correctly with reflections. Maybe I should try the guitar again in
3.5...
I think I'll just use CSG for the number-plates. I want to be able to specify
different number-plates for different cars without having to make a new image in
another application each time. We have flat number-plates here in South Africa
now, so it'll be SA number-plates...
- Nekar
Date: 4 Oct 2001 03:42:25
Message: <3bbc12e1$1@news.povray.org>
Thank you very much, sometime we should meet and discuss about PovRay.
bye.
"JRG" <jrg### [at] hotmailcom> ha scritto nel messaggio
news:3bbb544c@news.povray.org...
> Cheers,
> Jonathan.
> > trying to
> well
> matt
> what
> > I
think
> > I'll use
> the
> > > interior...
> > renders. I
> > with
> > > - Nekar
