I have a silly problem.
This is a dummy background for my next (hopefully) IRTC entry.
Problem is memory consumption. This little scene with 6 houses (from Gilles
are placed and randomly rotated within a while loop) needs whooping 830 MB
peak memory.
One single tree consumes only about 21 MB.
A 3.5 bug?
Does anybody know more ?
Norbert
Download 'dummy.jpg' (51 KB)
Preview of image 'dummy.jpg'
> A 3.5 bug?
I don't think it's a 3.5 bug. I don't know why there's so much memory
consumption, but the best way to reduce it is to use image_map on very thin
boxes. Have a look to this image and it's description :
http://www.irtc.org/ftp/pub/stills/2000-06-30/cbwild.jpg
http://www.irtc.org/ftp/pub/stills/2000-06-30/cbwild.txt
Sylvain
If youre using radiosity (I can't say that from this notebook) you might
expect such requirements (though I'm really in doubt...)
Without radiosity you would expect something like 20*8=160 MB (since IIRC
only the foliage is a mesh), but with high radiosity settings this can
quickly raise.
If you're not using radiosity forget it.
Jonathan
"Norbert Kern" <nor### [at] t-onlinede> ha scritto nel messaggio
news:3bab8e86@news.povray.org...
> Hi,
Gilles
(they
> peak memory.
> A 3.5 bug?
> Norbert
"Norbert Kern" <nor### [at] t-onlinede> wrote in message
> Hi,
> peak memory.
> A 3.5 bug?
> Norbert
Are you using the file output option when generating the tree and including
the file 8 times, or are you calling the macro directly 8 times with identical
parameters? I would expect the latter to consume more memory than the former,
as well as being slower to parse. The arrays and the recursion would eat up
a considerable amount of memory above and beyond the actual objects used in the
trees.
Batronyx ^"^
bat### [at] cadronhsacom
http://www.batronyx.com
For image-mapped objects in a scene to reduce memory requirements of the
final scene, see my site at:
http://www.angelfire.com/md2/castlewrks
"Sylvain Boutry" <bab### [at] yahoofr> wrote in message
news:3bab9a64@news.povray.org...
> > A 3.5 bug?
thin
> Sylvain
Yes, I used the file output option and memory saving was only minimal.
Norbert
including
identical
former,
up
in the
> trees.
I know your technique since your fine entry in the Garden round.
All 1 GB RAM of my machine were in full use with about 17 mio polypons in my
warm_up entry.
Norbert
"Robert J Becraft" <cas### [at] aolcom> schrieb im Newsbeitrag
news:3babb8bc$1@news.povray.org...
all meshes can be downloaded from his homepage IIRC). Its definetively fast
parsing and memory saving.
Nowadays I have a new 1.4 GHz Athlon C with 1 GB Ram and thougt to make
"real" 3d scenes.
But perhaps I have to substitute the full shadowed trees. thanks for the
tip.
Norbert
"Sylvain Boutry" <bab### [at] yahoofr> schrieb im Newsbeitrag
> > A 3.5 bug?
thin
> Sylvain
Hi JRG,
yes, I use radiosity. But the rca file is <100 MB for the full scene with
good quality settings.
Its a very tricky problem with no solution so far.
Norbert
"JRG" <ant### [at] liberoit> schrieb im Newsbeitrag
news:3bab9bf0@news.povray.org...
> quickly raise.
Norbert Kern wrote:
> Hi,
> peak memory.
> A 3.5 bug?
> Norbert
How many light_sources have you got?
In several scenes featuring tens of light sources, I found that
switching light buffers off dramatically decreased memory consumption.
Concerning rendering time, the impact was not that terrible, but I might
have been lucky.
__ __ __ __ _
| | / \ / / |_ / |/
\/\/ \__/ /_ /_ |__ \_ |\
