POV-Ray : Newsgroups : povray.binaries.images : maketree dummyscene Server Time
17 Jul 2026 05:54:18 EDT (-0400)
  maketree dummyscene (Message 1 to 10 of 10)
Subject: maketree dummyscene
Date: 21 Sep 2001 15:01:26
Message: <3bab8e86@news.povray.org>
I have a silly problem.
This is a dummy background for my next (hopefully) IRTC entry.
Problem is memory consumption. This little scene with 6 houses (from Gilles
are placed and randomly rotated within a while loop) needs whooping 830 MB
peak memory.
One single tree consumes only about 21 MB.
A 3.5 bug?
Does anybody know more ?
Norbert
Download 'dummy.jpg' (51 KB)
Preview of image 'dummy.jpg'
Subject: Re: maketree dummyscene
Date: 21 Sep 2001 15:52:04
Message: <3bab9a64@news.povray.org>
> A 3.5 bug?
I don't think it's a 3.5 bug. I don't know why there's so much memory
consumption, but the best way to reduce it is to use image_map on very thin
boxes. Have a look to this image and it's description :
http://www.irtc.org/ftp/pub/stills/2000-06-30/cbwild.jpg
http://www.irtc.org/ftp/pub/stills/2000-06-30/cbwild.txt
Sylvain
Date: 21 Sep 2001 15:58:40
Message: <3bab9bf0@news.povray.org>
If youre using radiosity (I can't say that from this notebook) you might
expect such requirements (though I'm really in doubt...)
Without radiosity you would expect something like 20*8=160 MB (since IIRC
only the foliage is a mesh), but with high radiosity settings this can
quickly raise.
If you're not using radiosity forget it.
Jonathan
"Norbert Kern" <nor### [at] t-onlinede> ha scritto nel messaggio
news:3bab8e86@news.povray.org...
> Hi,
Gilles
(they
> peak memory.
> A 3.5 bug?
> Norbert
Date: 21 Sep 2001 17:58:47
Message: <3babb817@news.povray.org>
"Norbert Kern" <nor### [at] t-onlinede> wrote in message
> Hi,
> peak memory.
> A 3.5 bug?
> Norbert
Are you using the file output option when generating the tree and including
the file 8 times, or are you calling the macro directly 8 times with identical
parameters? I would expect the latter to consume more memory than the former,
as well as being slower to parse. The arrays and the recursion would eat up
a considerable amount of memory above and beyond the actual objects used in the
trees.
Batronyx ^"^
bat### [at] cadronhsacom
http://www.batronyx.com
Date: 21 Sep 2001 18:01:32
Message: <3babb8bc$1@news.povray.org>
For image-mapped objects in a scene to reduce memory requirements of the
final scene,  see my site at:
http://www.angelfire.com/md2/castlewrks
"Sylvain Boutry" <bab### [at] yahoofr> wrote in message
news:3bab9a64@news.povray.org...
> > A 3.5 bug?
thin
> Sylvain
Date: 21 Sep 2001 22:20:59
Message: <3babf58b$1@news.povray.org>
Yes, I used the file output option and memory saving was only minimal.
Norbert
including
identical
former,
up
in the
> trees.
Date: 21 Sep 2001 22:45:24
Message: <3babfb44@news.povray.org>
I know your technique since your fine entry in the Garden round.
All 1 GB RAM of my machine were in full use with about 17 mio polypons in my
warm_up entry.
Norbert
"Robert J Becraft" <cas### [at] aolcom> schrieb im Newsbeitrag
news:3babb8bc$1@news.povray.org...
Date: 21 Sep 2001 22:45:25
Message: <3babfb45@news.povray.org>
all meshes can be downloaded from his homepage IIRC). Its definetively fast
parsing and memory saving.
Nowadays I have a new 1.4 GHz Athlon C with 1 GB Ram and thougt to make
"real" 3d scenes.
But perhaps I have to substitute the full shadowed trees. thanks for the
tip.
Norbert
"Sylvain Boutry" <bab### [at] yahoofr> schrieb im Newsbeitrag
> > A 3.5 bug?
thin
> Sylvain
Date: 21 Sep 2001 22:45:26
Message: <3babfb46@news.povray.org>
Hi JRG,
yes, I use radiosity. But the rca file is <100 MB for the full scene with
good quality settings.
Its a very tricky problem with no solution so far.
Norbert
"JRG" <ant### [at] liberoit> schrieb im Newsbeitrag
news:3bab9bf0@news.povray.org...
> quickly raise.
Date: 22 Sep 2001 19:31:57
Message: <3BAD1F5A.921EECC7@club-internet.fr>
Norbert Kern wrote:
> Hi,
> peak memory.
> A 3.5 bug?
> Norbert
How many light_sources have you got?
In several scenes featuring tens of light sources, I found that
switching light buffers off dramatically decreased memory consumption.
Concerning rendering time, the impact was not that terrible, but I might
have been lucky.
      __  __ __  __  _
|  | /  \  /  / |_  /  |/
\/\/ \__/ /_ /_ |__ \_ |\
