POV-Ray : Newsgroups : povray.binaries.images : Rendering patterns different in 3.1 and 3.5? Server Time
31 Mar 2026 23:01:44 EDT (-0400)
  Rendering patterns different in 3.1 and 3.5? (Message 1 to 6 of 6)
Subject: Rendering patterns different in 3.1 and 3.5?
Date: 15 Sep 2001 00:35:43
Message: <3ba2da9f@news.povray.org>
from povray.general
>I noticed that rendering patterns in POV-Ray 3.1 and 3.5 give different
results.  Rendering in POV-Ray 3.5 with >the following texture (as given by
Ricky[Kitty]5 in povray.binaries.images under 'more glass balls...') yields
a very >soft pattern to objects this material is applied to.  But when
rendered in POV-Ray 3.1, the pattern appears much >more defined.  Why the
change?  Is there any convention to use so that a scene with materials
intended to be >rendered in POV-Ray 3.1 can be rendered in POV-Ray 3.5 with
the same look, or is it just a matter of manually >tweaking?
>I've posted images in povray.binaries.images comparing the same pattern
rendered in 3.1 and 3.5.
>#declare Material1 =
>   material  // Material1
>      texture
>         pigment
>            color rgb <1.0, 1.0, 1.0>
>         normal
>            bozo , 0.5
>            turbulence 0.5
>            ramp_wave
>         finish
>            ambient 0.0
>            diffuse 0.6115
>-Paragon
Download 'myscene35.jpg' (5 KB) Download 'myscene31.jpg' (15 KB)
Preview of image 'myscene35.jpg'
Preview of image 'myscene31.jpg'
Subject: Re: Rendering patterns different in 3.1 and 3.5?
Date: 15 Sep 2001 00:54:52
Message: <3ba2df1c@news.povray.org>
Actually, here is a much better comparison.  It's just a cube on a plane
with one light source, no anti-aliasing.
-Paragon
Download 'myscene31.jpg' (19 KB) Download 'myscene35.jpg' (10 KB)
Date: 15 Sep 2001 03:29:56
Message: <Xns911D60A19271seed7@povray.org>
> 3.5 with the same look, or is it just a matter of manually
> >tweaking?
Look for 2.6.1, 2.6.14, 6.7.12.4 and 6.11.10 in the docs.
Ingo
Date: 15 Sep 2001 17:15:04
Message: <3ba3c4d8@news.povray.org>
I still get different results when I render in 3.5 and use #noise_generator
1.  Am I missing something?
scene31.jpg - rendered with POV-Ray 3.1
scene35.jpg - rendered with POV-Ray 3.5 using #noise_generator  1
scene35a.jpg - rendered with POV-Ray 3.5 using #version 3.1
-Paragon
Download 'scene31.jpg' (22 KB) Download 'scene35.jpg' (11 KB) Download 'scene35a.jpg' (22 KB)
Preview of image 'scene31.jpg'
Preview of image 'scene35.jpg'
Preview of image 'scene35a.jpg'
Date: 15 Sep 2001 23:50:32
Message: <3ba42188@news.povray.org>
"Paragon" <use### [at] hostcom> wrote in message news:3ba3c4d8@news.povray.org...
> -Paragon
6.7.2.1.1  might also apply here, particularly if the default value (previously
unavailable for user tuning) has changed from 3.1.
Date: 16 Sep 2001 10:32:46
Message: <3ba4b80d@news.povray.org>
Paragon <use### [at] hostcom> wrote:
: I still get different results when I render in 3.5 and use #noise_generator
: 1.  Am I missing something?
  There's no such a thing as #noise_generator (povray gives an error if you
write that). What you probably meant was global_settings { noise_generator 1 }
  But anyway, you could try with different values of accuracy in your
normal block. Try with very small values (such as 0.001 and so on).
