POV-Ray : Newsgroups : povray.binaries.images : mlPOV SSS (2 jpegs, 50kb total) Server Time
19 Oct 2024 04:17:28 EDT (-0400)
  mlPOV SSS (2 jpegs, 50kb total) (Message 1 to 10 of 13)
Subject: mlPOV SSS (2 jpegs, 50kb total)
Date: 4 Dec 2003 16:28:38
Message: <3FCFA6ED.5020202@hotmail.com>
Hello everyone. I've got hills of ice.... or something loosely
resembling ice.
In one image no subsurface scattering is used. In the other image,
lighting effects can be seen 'wrapping around' the hills.
Ice_hill_not.jpg took 26 seconds to render.
Ice_hillSSS.jpg took 9 minutes, 45 seconds to render.
The SSS is a 'faked' version made in mlPOV and uses the projection
pattern. Some artifacts can be seen if you look closely. For instance,
at the bottom of the middle hill you can see horizontal lines caused by
the ground plane, which is also included in the SSS evaluation. Also,
lines following the contour of the tops of certain hills can be seen
because of the low samples and high scattering values I used.
The SSS takes both light_sources into account, thus simulating light
scattering from both the sun and background sky.
I should try this scene with media... or if somebody else wants to
render it I can make the source code available.
Q's, C's?
Samuel Benge
stb### [at] hotmailcom
See my website@: http://www.goldrush.com/~abenge/Top/index.html
Download 'ice_hill_not.jpg' (19 KB) Download 'ice_hillsss.jpg' (31 KB)
Preview of image 'ice_hill_not.jpg'
Preview of image 'ice_hillsss.jpg'
Subject: Re: mlPOV SSS (2 jpegs, 50kb total)
Date: 4 Dec 2003 17:12:45
Message: <3fcfb15d$1@news.povray.org>
"Samuel Benge" <sbe### [at] hotmailcom> wrote in message
news:3FC### [at] hotmailcom...
> resembling ice.
This really looks "cool".
Now add some snow fields on the horizontal parts of the mountain... to make
things look even cooler
Subject: Ice Hill detail (18kb jpeg)
Date: 4 Dec 2003 17:53:20
Message: <3FCFBAD7.4080402@hotmail.com>
Just a closeup render with higher SSS settings. Some incidental
striations are visible, and seem to resemble cracks in the ice.
Took 21 minutes, 25 seconds to render.
An animation of this might ruin the effect, but I'm thinking if the
angle of incidence(aoi) pattern were used, things might look more
believable.
Samuel Benge
Download 'ice_hillsss_detail.jpg' (18 KB)
Preview of image 'ice_hillsss_detail.jpg'
Date: 4 Dec 2003 18:32:33
Message: <3fcfc411@news.povray.org>
> resembling ice.
> Q's, C's?
I hate to be critical, especially since I'm nowhere near your level,
but something about the SSS image says "small" to me, like the central
hummock is only a few centimeters across, like a dirty ice-cube.
At the risk of being wrong as usual, maybe the SSS
is a little overplayed?
Wonderful effect though.
Bill Hails
Date: 4 Dec 2003 18:45:01
Message: <web.3fcfc5f71c8ae714560089ea0@news.povray.org>
>resembling ice.
>Q's, C's?
>Samuel Benge
yes ... would love to see the source ...
been wanting to model some snow and ice and it's that time of year. ;)
-ts-
Date: 4 Dec 2003 18:53:12
Message: <Xns94488FE2E438raf256com@204.213.191.226>
bil### [at] europeyahoo-inccom news:3fcfc411@news.povray.org
Exacly, I had same fealing. My first reaction was - what a nice wax/plastic
toy representing an mountaint.
Date: 4 Dec 2003 21:15:01
Message: <web.3fcfe8991c8ae7143e5041e90@news.povray.org>
I think it's beautiful.  You can make it look larger if you put some things
in the foreground and make the ground look more finely textured.  Also,
large, translucent ice formations look distinctly <a
href="http://aku-aku.com/images/antarctic/aa035.jpg">blue</a>.  Try adding
some color.
(<a
href="http://www.lakesuperiorphoto.com/upper%20peninsula%20winter/grand%20island%20fallen%20ice%20boulders.jpg">More</a>
<a
href="http://www.thefickeadventure.com/WorldTrip/NewZealand/WestCoast/BestCave.html">blue</a>
<a
href="http://www.losglaciares.com/en/parque/galeria/025.html">formations</a>,
<a href="http://www.photolib.noaa.gov/corps/corp2494.htm">another</a>)
It's not perfect but I think you knew that.
Date: 4 Dec 2003 22:22:36
Message: <oprzougshnu942mt@news.povray.org>
Wow, a new dimension of realism for our renders :) I agree with some
posters that could put some more objects in the foreground to emphasize the
size of the glacier. Also try making it more blue!
George
On Thu, 04 Dec 2003 13:28:13 -0800, Samuel Benge <sbe### [at] hotmailcom>
wrote:
> Hello everyone. I've got hills of ice.... or something loosely resembling
> ice.
> pattern. Some artifacts can be seen if you look closely. For instance, at
> the bottom of the middle hill you can see horizontal lines caused by the
> ground plane, which is also included in the SSS evaluation. Also, lines
> following the contour of the tops of certain hills can be seen because of
> I should try this scene with media... or if somebody else wants to render
> Q's, C's?
Using M2, Opera's revolutionary e-mail client: http://www.opera.com/m2/
Date: 5 Dec 2003 14:55:39
Message: <3FD0E2B9.9060504@hotmail.com>
Thanks George. I did make it a little blue already, but it looks like I
need to add more color still. Some more objects would help it.....  but
the whole scene needs to be remodeled.
> the size of the glacier. Also try making it more blue!
> George
Samuel Benge
Date: 5 Dec 2003 15:00:51
Message: <3FD0E3F1.1040107@hotmail.com>
Thank you.
> large, translucent ice formations look distinctly <snip>
Thanks for the reference. I think I'll go Googling to see what else I
can find. My heightfields don't really lend a realistic appearance to
the ice.... and I really need to fix the color.
Yes, I do. The render was only made from my poor memory of what ice is
really supposed to look like. If anything, it looks like salt crystals
which have built up onto a pile of rocks... Or wax that was dripped onto
something.
Samuel Benge
