POV-Ray : Newsgroups : povray.binaries.images : mlPOV SSS (2 jpegs, 50kb total) Server Time
14 Apr 2026 05:42:55 EDT (-0400)
  mlPOV SSS (2 jpegs, 50kb total) (Message 4 to 13 of 13)
<<< Previous 3 Messages Goto Initial 10 Messages
Subject: Re: mlPOV SSS (2 jpegs, 50kb total)
Date: 4 Dec 2003 18:32:33
Message: <3fcfc411@news.povray.org>
Samuel Benge wrote:
> Hello everyone. I've got hills of ice.... or something loosely
> resembling ice.
> In one image no subsurface scattering is used. In the other image,
> lighting effects can be seen 'wrapping around' the hills.
> Ice_hill_not.jpg took 26 seconds to render.
> Ice_hillSSS.jpg took 9 minutes, 45 seconds to render.
> The SSS is a 'faked' version made in mlPOV and uses the projection
> pattern. Some artifacts can be seen if you look closely. For instance,
> at the bottom of the middle hill you can see horizontal lines caused by
> the ground plane, which is also included in the SSS evaluation. Also,
> lines following the contour of the tops of certain hills can be seen
> because of the low samples and high scattering values I used.
> The SSS takes both light_sources into account, thus simulating light
> scattering from both the sun and background sky.
> I should try this scene with media... or if somebody else wants to
> render it I can make the source code available.
> Q's, C's?
I hate to be critical, especially since I'm nowhere near your level,
but something about the SSS image says "small" to me, like the central
hummock is only a few centimeters across, like a dirty ice-cube.
At the risk of being wrong as usual, maybe the SSS
is a little overplayed?
Wonderful effect though.
Bill Hails
Date: 4 Dec 2003 18:45:01
Message: <web.3fcfc5f71c8ae714560089ea0@news.povray.org>
>resembling ice.
>Q's, C's?
>Samuel Benge
yes ... would love to see the source ...
been wanting to model some snow and ice and it's that time of year. ;)
-ts-
Date: 4 Dec 2003 18:53:12
Message: <Xns94488FE2E438raf256com@204.213.191.226>
bil### [at] europeyahoo-inccom news:3fcfc411@news.povray.org
Exacly, I had same fealing. My first reaction was - what a nice wax/plastic
toy representing an mountaint.
Date: 4 Dec 2003 21:15:01
Message: <web.3fcfe8991c8ae7143e5041e90@news.povray.org>
I think it's beautiful.  You can make it look larger if you put some things
in the foreground and make the ground look more finely textured.  Also,
large, translucent ice formations look distinctly <a
href="http://aku-aku.com/images/antarctic/aa035.jpg">blue</a>.  Try adding
some color.
(<a
href="http://www.lakesuperiorphoto.com/upper%20peninsula%20winter/grand%20island%20fallen%20ice%20boulders.jpg">More</a>
<a
href="http://www.thefickeadventure.com/WorldTrip/NewZealand/WestCoast/BestCave.html">blue</a>
<a
href="http://www.losglaciares.com/en/parque/galeria/025.html">formations</a>,
<a href="http://www.photolib.noaa.gov/corps/corp2494.htm">another</a>)
It's not perfect but I think you knew that.
Date: 4 Dec 2003 22:22:36
Message: <oprzougshnu942mt@news.povray.org>
Wow, a new dimension of realism for our renders :) I agree with some
posters that could put some more objects in the foreground to emphasize the
size of the glacier. Also try making it more blue!
George
On Thu, 04 Dec 2003 13:28:13 -0800, Samuel Benge <sbe### [at] hotmailcom>
wrote:
> Hello everyone. I've got hills of ice.... or something loosely resembling
> ice.
> pattern. Some artifacts can be seen if you look closely. For instance, at
> the bottom of the middle hill you can see horizontal lines caused by the
> ground plane, which is also included in the SSS evaluation. Also, lines
> following the contour of the tops of certain hills can be seen because of
> I should try this scene with media... or if somebody else wants to render
> Q's, C's?
Using M2, Opera's revolutionary e-mail client: http://www.opera.com/m2/
Date: 5 Dec 2003 14:55:39
Message: <3FD0E2B9.9060504@hotmail.com>
Thanks George. I did make it a little blue already, but it looks like I
need to add more color still. Some more objects would help it.....  but
the whole scene needs to be remodeled.
> the size of the glacier. Also try making it more blue!
> George
Samuel Benge
stb### [at] hotmailcom
See my website@: http://www.goldrush.com/~abenge/Top/index.html
Date: 5 Dec 2003 15:00:51
Message: <3FD0E3F1.1040107@hotmail.com>
Thank you.
> large, translucent ice formations look distinctly <snip>
Thanks for the reference. I think I'll go Googling to see what else I
can find. My heightfields don't really lend a realistic appearance to
the ice.... and I really need to fix the color.
Yes, I do. The render was only made from my poor memory of what ice is
really supposed to look like. If anything, it looks like salt crystals
which have built up onto a pile of rocks... Or wax that was dripped onto
something.
Samuel Benge
Date: 5 Dec 2003 15:03:10
Message: <3FD0E47C.9060900@hotmail.com>
I'll make it available soon..... but you'll need mlPOV to use it. I
still need to make the effect fall off more realistically. The pattern
is only like a 'thick' diffuse which penetrates the surface of the object.
> -ts-
Samuel Benge
Date: 5 Dec 2003 15:10:51
Message: <3FD0E649.4050302@hotmail.com>
No you don't.... or at least yout shouldn't. Critisicm in low levels can
be a good thing.....
Now that's going too far :)
I overplayed it on purpose. By overusing it, I hope to figure how it
might be used in more appropriate levels. The effect is still a work in
progress, and it will be until I can work out the many, many bugs.
Thanks!
Samuel Benge
Subject: Re: Ice Hill detail (18kb jpeg)
Date: 5 Dec 2003 22:38:50
Message: <3fd14f4a@news.povray.org>
looks awesom as is.
Samuel Benge wrote:
> Just a closeup render with higher SSS settings. Some incidental
> striations are visible, and seem to resemble cracks in the ice.
> Took 21 minutes, 25 seconds to render.
> An animation of this might ruin the effect, but I'm thinking if the
> angle of incidence(aoi) pattern were used, things might look more
> believable.
