POV-Ray : Newsgroups : povray.binaries.images : Subsurface Scattering: A Tuesday Mystery (21kb jpeg) Server Time
14 Apr 2026 05:43:54 EDT (-0400)
  Subsurface Scattering: A Tuesday Mystery (21kb jpeg) (Message 8 to 17 of 17)
<<< Previous 7 Messages Goto Initial 10 Messages
Subject: Re: Subsurface Scattering: A Tuesday Mystery (21kb jpeg)
Date: 26 Nov 2003 02:47:53
Message: <3FC45AA8.4090607@hotmail.com>
Christopher James Huff wrote:
> Very nice.
Thank you Chris.
>"Can you tell how I did it?"
> A semitransparent, porous isosurface filling the interior?
Nope, pretty far off. You know, I've tried doing it that way, but could
never get any good results.
Here's a hint: this method doesn't take the interior of the object into
account at all.
Samuel Benge
stb### [at] hotmailcom
See my website@: http://www.goldrush.com/~abenge/Top/index.html
Date: 26 Nov 2003 02:57:48
Message: <3fc45cfc$1@news.povray.org>
Samuel Benge wrote:
> I think I have found a new way to simulate subsurface scattering(SSS). I
> have attached an image of an object with a yellowish diffuse and reddish
> SSS.
> Can you tell how I did it? I did not use media or photons. I did not use
> double_illuminate.
> Four stars to the person who figures it out.
The image is really nice and gorgeous...
Is your method faster than "regular" sss ?
Nico
Date: 26 Nov 2003 03:00:28
Message: <3FC45D9B.3000605@hotmail.com>
Thanks.
> Nico
If you are comparing it to media, then yes, it's much faster.
Samuel Benge
Date: 26 Nov 2003 03:30:58
Message: <3fc464c2$1@news.povray.org>
This is really impressive. Did you try to do a candle ? Does your
technique work with a very close light ?
My guess for your technique is a two pass render, first pass with a
black and white spherical pigment depending on the light position that
you apply to all objects with subsurface scattering, and then a second
pass where you use the first one to evaluate the color. While explaining
my guess I have no really precise idea on the how you did it though.  :-)
Am I any close ??   8-p
JC
> SSS.
> double_illuminate.
Date: 26 Nov 2003 04:32:07
Message: <7h8e91-pq2.ln1@triton.imagico.de>
> SSS.
> double_illuminate.
Tricky, but i have an idea.  Could you render it with the light source
in the middle between the two shapes?
Last updated 25 Oct. 2003 _____./\/^>_*_<^\/\.______
Date: 26 Nov 2003 10:21:10
Message: <3FC4C4E3.8020800@hotmail.com>
Thanks JC. Nope, haven't tried a candle yet, it was getting quite late
last night.
 > Does your
I don't think it will, but only because my math is sloppy. I'm hoping
when I release the code that somebody with better coding skills will
develop it further.....
You are very close. A black/white pigment is involved, and a preliminary
pass to establish subsurface scattering effects is used.
Samuel Benge
Date: 26 Nov 2003 10:22:12
Message: <3FC4C522.3060606@hotmail.com>
Nope, not until the math is fixed. Then I should be able to render it
with very close light_sources.
Samuel Benge
Date: 26 Nov 2003 11:20:01
Message: <web.3fc4d292c4cfe4f2736664ab0@news.povray.org>
Hi Samuel,
my guess is a mlpov render with use of shadow_pigment, use of the object on
itself, a nonzero ambient value for nonshadowed and ambient zero for
shadowed parts. For the smooth transition you perhaps used an area light to
define the shadow pigment and a point light for the scene.
Norbert
>SSS.
>double_illuminate.
>Samuel Benge
Date: 26 Nov 2003 13:04:12
Message: <nf6f91-sh8.ln1@triton.imagico.de>
Well, i thought the slope pattern might be involved.  In this case it
would only work well for a distant light source, otherwise you would
need the aoi pattern instead.
Looking closer at the image reveals that there are indeeed problems,
strong scattering occurs at places where it should not occur.
I have two other things in mind:
1) you use saved radiosity data from a different but related scene
setup.  This is far fetched of course but it might be an intersting idea
for such effects
2) you use trace() to place blob components on the surface and use the
blob with the object pattern (not sure how you could achieve the smooth
transit with this method though)
Date: 26 Nov 2003 14:34:44
Message: <3FC50051.30406@hotmail.com>
 > Christoph
Congratulations, you get four stars :) While you didn't explain the
whole technique, you explained the guts of my setup.
I used trace to place blob components randomly onto the object. The blob
object is made into a pigment using the object pattern . The blobby
pigment is then jittered about 100 times inside an average pattern's
color_map.
I have made a few enhancements and bug fixes, and I think it's about
ready to be released. In order to allow the use of multiple
light_sources I might have to make it into a macro which you place into
an average pattern's texture_map.
It will be ready very soon.
Samuel Benge
