POV-Ray : Newsgroups : povray.binaries.images : Simple cloud Server Time
31 Dec 2025 17:17:46 EST (-0500)
  Simple cloud (Message 1 to 3 of 3)
Subject: Simple cloud
Date: 15 Jun 2003 23:12:48
Message: <3EED33C9.B1D0DA3C@mail.com>
I always wanted to have full control on cloud shape.
So I came up with this very simple technique. It was
built from simple mesh element (see the second image)
and is very similar to 'stacked planes' technique.
Rendering time 3 seconds and it looks the same way in
any resolution. The source is in p.b.s.-f.
It's waiting for somebody who can make macro from it :)
That mesh element could be placed on different curves
(splines) to make plump cloud(s) :)
Gena.
Download 'clouds1.jpg' (31 KB) Download 'clouds2.jpg' (29 KB)
Preview of image 'clouds1.jpg'
Preview of image 'clouds2.jpg'
Subject: Re: Simple cloud
Date: 18 Jun 2003 18:15:01
Message: <web.3ef0e3651bad6fd57053ea40@news.povray.org>
>Gena.
Simple as it may be, I rather like it. Perhaps you should write a tutorial
on how peons like us newbies can make it.
Date: 18 Jun 2003 19:52:26
Message: <3EF0FB3C.40886A47@mail.com>
There is nothing special just check the source. It's really very simple
code :) But despite its simplicity I believe that that technique can be
used for very complicated clouds. I'll try to prove that whenever
I have time :)
More likely you have to increase max_trace_level for very
complicated cloud(s). Also if you place several mesh
elements in the same plane (e.g. x-y) and if they overlap make
sure that you have a small gap between those elements (e.g.
z*0.00001)
I created this cloud manually. Just scaling rotating and translating
the basis mesh element. For simple clouds that's OK. But I think
that more complicated plumpish clouds should be created by
macros. I just don't know any appropriate algorithm for that :(
Using several mesh elements with slightly different hues you
can get good looking colorful cloud(s).
One of the advantages of this technique - clouds look the same
way in any resolution. Another advantage - mesh nature of
the cloud. As a result you can fill by such clouds the whole sky
without any impact on memory.
Gena.
