POV-Ray : Newsgroups : povray.binaries.images : Lathe problem (JPG, 800 x 600, 6 KB) Server Time
16 Jul 2026 20:49:16 EDT (-0400)
  Lathe problem (JPG, 800 x 600, 6 KB) (Message 1 to 6 of 6)
Subject: Lathe problem (JPG, 800 x 600, 6 KB)
Date: 13 Feb 2003 15:19:26
Message: <3E4C0DBF.BB303E66@tiscalinet.de>
High!
Currently, I'm modeling an ancient mathematical co-prozessor... and with
its pins, a problem occurred. As they are somehow soldered to the
ceramic die's lower side, there is a smooth transition between the pin
itself and its flat round base. Any attempts to model this with blobs
resulted in monstrously swollen base cylinders, so I decided to do it
with a lathe, using Moray.
But when viewed from along the z axis, the lathe turns out to be
asymmetric (see picture)! Did this result from the fact that I did not
specify a fourth point on the y axis?
Here is the code:
#declare Pin_Raw=
cylinder
 0, <0, 0.0037, 0>, 0.0001
#declare Pin_Transition=
lathe { // RotSweep001
  quadratic_spline
  3  // control points
  <28.704931, 14.913935>,
  <5.999999, -0.033529>,
  <0.639678, 11.939946>
  scale 0.0001
  translate 0.00003
#declare Pin_Socket=
cylinder
 0, <0, 0.00003, 0>, 0.0006
#declare Pin=
union
 object { Pin_Raw }
 object { Pin_Transition }
 object { Pin_Socket }
 texture { T_Gold_2B }
Download 'cyrix0001.jpg' (6 KB)
Preview of image 'cyrix0001.jpg'
Subject: Re: Lathe problem (JPG, 800 x 600, 6 KB)
Date: 13 Feb 2003 15:31:56
Message: <3E4C0177.FCF065B9@Rapidnet.com>
I would have done something like this:
#declare contact_pin =
intersection {
    union {
        difference {
            torus { 0.015625, 0.0078125 translate 0.0234375*y }
            cylinder { <0.0, 0.0234375, 0.0> <0.0, 0.046875, 0.0> 0.046875 }
        cylinder { <0.0, 0.0234375, 0.0> <0.0, 0.078125, 0.0> 0.0078125 }
    cylinder { <0.0, -0.015625, 0.0> <0.0, 0.09375, 0.0> 0.0234375 }
        texture { T_Gold_5A }
        Anthony D. Baye
> High!
> Here is the code:
> #declare Pin_Raw=
> cylinder
>   quadratic_spline
>   3  // control points
>   scale 0.0001
>   translate 0.00003
> cylinder
> #declare Pin=
> union
>  object { Pin_Raw }
Date: 13 Feb 2003 15:32:57
Message: <uuSjHFAGDAT+Ew$a@econym.demon.co.uk>
>High!
>Here is the code:
>#declare Pin_Raw=
>cylinder
>  quadratic_spline
>  3  // control points
>  scale 0.0001
>  translate 0.00003
The lathe itself is symmetrical, it's just that you've translated it by
<0.00003, 0.00003, 0.00003> relative to the Pin_Raw cylinder. Try
   translate 0.00003*y
Mike Williams
Gentleman of Leisure
Date: 13 Feb 2003 15:55:03
Message: <web.3e4c055774012f68b417814a0@news.povray.org>
=?iso-8859-1?Q?J=F6rg?= 'Yadgar' Bleiman wrote:
>High!
>Here is the code:
>  quadratic_spline
>  3  // control points
>  scale 0.0001
>  translate 0.00003
Are you aware that POV-Ray promotes
the 0.00003 scalar in your
"translate 0.00003" expression to a
vector, so that the expression
becomes this:
translate <0.00003, 0.00003, 0.00003>
Maybe you meant to write:
translate 0.00003*y
Hmmm...
I see now that you are using Moray.
Maybe I haven't found your problem.
Tor Olav
Date: 13 Feb 2003 16:44:10
Message: <3E4C219C.76DE80B2@tiscalinet.de>
High!
>    translate 0.00003*y
Ouuuh... how stupid!!!
Date: 13 Feb 2003 17:02:37
Message: <3e4c15fd$1@news.povray.org>
You should perhaps explain what you're actually trying
to do with that code. Some newbies might not understand
that you're taking a cylinder, put a thick base, of which
you carve a quarter of a torus. And without an image
they might not get what the effect is...
Just a suggestion,
Tim
Tim Nikias
Email: Tim### [at] gmxde
> intersection {
>     union {
>         difference {
> Regards,
>         Anthony D. Baye
> > High!
> > Here is the code:
> > #declare Pin_Raw=
> > cylinder
> >   quadratic_spline
> >   3  // control points
> >   scale 0.0001
> >   translate 0.00003
> > cylinder
> > #declare Pin=
> > union
> >  object { Pin_Raw }
> >  [Image]
