one isosurface filled with emmiting media
ABX
#declare _=function(a,b,x){((a^2)+(b^2))^.5-x}#default {pigment{color rgb 1}}
union{plane{y,-3}plane{-x,-3}finish{reflection 1 ambient 0}}isosurface{ //ABX
function{_(x-2,y,1)|_((x+y)*.7,z,.1)|_((x+y+2)*.7,z,.1)|_(x/2+y*.8+1.5,z,.1)}
contained_by{box{<0,-3,-.1>,<3,0,.1>}}translate z*15finish{ambient 1}}//POV35
Download 'by_night.jpg' (35 KB)
Preview of image 'by_night.jpg'
You could try to use the same function in a density block, so that those
*tubes* look brighter towards the centre.
Jonathan.
news:m780ut04vc1ocm333h198gbau4le0qeki9@4ax.com...
> ABX
1}}
//ABX
1}}//POV35
Weird, what's the function for that? It looks like a sphere_sweep to me.
- Slime
[ http://www.slimeland.com/ ]
[ http://www.slimeland.com/images/ ]
> ABX
1}}
//ABX
1}}//POV35
Hmm. Looks like those little glow tubes they sell at festivals.. :-)
//Mahalis
camera{location<0,0.25,-2> look_at 0.5*y} #declare T=texture{pigment{crackle
scale 0.5 rotate 90 turbulence 0.75 color_map{[0 rgb 1][0.05 rgb 1][0.1
rgb<1,0.25,1>][0.25 rgbf 1][1 rgbf 1]}} finish{ambient 1}} #declare
c=difference{torus{0.5,0.1 rotate -90*x}box{<0.7,0,0.2>,<-0.7,-0.7,-0.2>}}
merge{object{c translate<0.5,0.5,0>} object{c translate<-0.5,0.5,0>}
cylinder{<1,0.5,0>,<1,0,0>,0.1} cylinder{<-1,0.5,0>,<-1,0,0>,0.1}
cylinder{0.5*y,0,0.1} texture{T}}
> ABX
1}}
//ABX
1}}//POV35
This is my WIP isomaze function limited to small space. Larger version you can
find some post below (above).
ABX
Be sure I check this with my isomaze.
ABX
Cool, looks great.
Can anyone explain why there are a couple of brighter patches on some of the
strands?
James
> ABX
> by_night.jpg Type: JPEG Image (image/jpeg)
> Encoding: base64
