POV-Ray : Newsgroups : povray.binaries.images : Neon Tubes Image Server Time
26 Dec 2025 11:07:37 EST (-0500)
  Neon Tubes Image (Message 1 to 5 of 5)
Subject: Neon Tubes Image
Date: 2 Oct 2001 01:47:55
Message: <3BB95428.36EEC5AD@netvision.net.il>
[Image]
The Middle Neon is supposted to be Green.
Download 'us-ascii' (1 KB) Download 'c:\windows\temp\nsmailvr.jpeg.jpg' (34 KB)
Preview of image 'c:\windows\temp\nsmailvr.jpeg.jpg'
Subject: Re: Neon Tubes Image
Date: 2 Oct 2001 05:55:02
Message: <po2cp9.d02.ln@micha.riser>
Eitan Tal wrote:
> [Image]
Unfortunately my newsreader (knode) does not show the image.. does it work
with everybody else?
- micha
Date: 2 Oct 2001 07:02:40
Message: <3bb99ed0$1@news.povray.org>
It seems to work for me- can't your newsreader display jpegs?
Nice image; if you aren't using standard color definitions, rgb<> instead,
then you might have a value mixed up somewhere in there.
"Micha Riser" <mri### [at] gmxnet> wrote in message
news:po2### [at] michariser...
> Eitan Tal wrote:
> > [Image]
> - micha
Date: 2 Oct 2001 08:40:13
Message: <3bb9b5ad@news.povray.org>
KNode can display jpegs, but the problem is that Eitan posted HTML, and in
that case KNode seems to not care about the Image.
Date: 2 Oct 2001 09:52:28
Message: <slrn9rjhku.f4k.ron.parker@fwi.com>
Or that the name of the file is "C:\WINDOWS\TEMP\nsmailVR.jpeg" which some
newsreaders, particularly on backward systems that use the wrong directory
separator, might not see as a legitimate filename.
Eitan, it looks like the light from the red and blue tubes is mixing with
the light from the green tube to make white.  Have you tried putting opaque
boxes between the three tubes to see if that's the case?
#macro R(L P)sphere{L F}cylinder{L P F}#end#macro P(V)merge{R(z+a z)R(-z a-z)R(a
-z-z-z a+z)torus{1F clipped_by{plane{a 0}}}translate V}#end#macro Z(a F T)merge{
P(z+a)P(z-a)R(-z-z-x a)pigment{rgbf 1}hollow interior{media{emission 3-T}}}#end
Z(-x-x.2x)camera{location z*-10rotate x*90normal{bumps.02scale.05}}
