Do I have to do anything special to MegaPOV after I upgrade to 3.5???
Bryan Valencia
Software Development Engineer
Did you install 3.5 to the same directory as 3.1 and megaPOV.?
Are you getting an error at MegaPOV startup regarding the editor DLL?
-tgq
"Bryan Valencia" <bry### [at] 209softwarecom> wrote in message
news:3B9CFDF4.95801A6B@209software.com...
> Bryan Valencia
Nah, I was just hesitant to install it with Mega finally running so well.
I got over it, and found that it installs in a completely new directory.
Now I can't get it to do my isosurfaces right.
Here is the code...
#declare F=function{pigment{
bumps
turbulence .41
color_map { [0 rgb 1] [1 rgb 0] }
scale 0.1
isosurface {
function { x*x + y*y +z*z -1 + F(x,y,z)} <-- right before the last
"}" it says it needs a "." if I put one there it needs a "color or vector
member".
method 2
max_gradient 3.2
accuracy 0.0001
contained_by{sphere{0,1}}
pigment {rgb .9}
scale 5e4
translate <0,0,1e5>
> -tgq
> > Bryan Valencia
Bryan Valencia
Read the thread in povray.beta-test on isosurface conversion. This may give
you the info you are looking for.
-tgq
news:3B9D0DF6.D6C4B28B@209software.com...
> Here is the code...
> bumps
> turbulence .41
> scale 0.1
> isosurface {
last
> member".
> method 2
> max_gradient 3.2
> accuracy 0.0001
> pigment {rgb .9}
> scale 5e4
> translate <0,0,1e5>
> > -tgq
> > > Bryan Valencia
> Bryan Valencia
>Here is the code...
> bumps
> turbulence .41
> scale 0.1
>isosurface {
>member".
> method 2
> max_gradient 3.2
> accuracy 0.0001
> pigment {rgb .9}
> scale 5e4
> translate <0,0,1e5>
3.5b1 is not MegaPOV. The isosurface syntax is significantly different.
If you were to fix the "color or vector number" problem you'd still fall
foul of the fact that 3.5 doesn't have a "method" keyword. You may need
to learn how to write isosurfaces all over again.
As it happens, my isosurface tutorial page has just been updated to
include 3.5b1 and might help you to learn the new syntax.
<http://www.econym.demon.co.uk/isotut/index.htm>
Mike Williams
Gentleman of Leisure
Thanks for upgrading this I need all the help I can get understanding isos!
By the way I caught a small typo on your front page, on the last line before
the TOC:
The source files for the examples on each page are available as ZIP files.
There are two versions of the zip files, one for use with POV-Ray 3.2 and
one for use with Mega-Pov
You mean 3.5
: As it happens, my isosurface tutorial page has just been updated to
: include 3.5b1 and might help you to learn the new syntax.
: <http://www.econym.demon.co.uk/isotut/index.htm>
: Mike Williams
: Gentleman of Leisure
Excellent tutorial, Mike ... thanks for this !!!!!!
I don't know how you can do this and still have leisure time ;)
Y
