POV-Ray : Newsgroups : povray.binaries.images : Scaling Server Time
16 May 2026 05:57:49 EDT (-0400)
  Scaling (Message 1 to 9 of 9)
Subject: Scaling
Date: 9 Sep 2001 04:03:41
Message: <3B9B2461.2D6561F8@rapidnet.com>
I've been trying to create a scene of a foggy night with street
lamps. I can get the atmospheric media to work on a small level,
typically when the scene is built using regular intervals. (i.e.
1.2.3.4....) but, for the sake of detail, I multiply all the dimensions
by 12 and use anything less than that for inches.
    Here's where I run into problems.  After a certain size, the media
ceases to function as expected.  Does My problem stem from my scaling?
If so do I have to scale everything down to unmanageably long float
values or can i modify the media statement to function on a large scale?
A.D.B
Subject: Re: Scaling
Date: 9 Sep 2001 06:35:31
Message: <3b9b45f3@news.povray.org>
The density of the media isn't scaled when you scale the density,
so you'll have to decrease the density.
Date: 9 Sep 2001 06:36:06
Message: <3b9b4616$1@news.povray.org>
Date: 9 Sep 2001 13:02:07
Message: <3b9ba08f$1@news.povray.org>
"Simon" <sim### [at] surfeude> wrote in message
news:3b9b45f3@news.povray.org...
You can say that again. :-)
Andy Cocker
Date: 9 Sep 2001 13:14:14
Message: <3B9BA56C.48C1F4DE@rapidnet.com>
What if no density is used?
Date: 9 Sep 2001 13:30:59
Message: <3b9ba753@news.povray.org>
Make the color of your media darker.
That will decrease its density.
scale?
Date: 9 Sep 2001 13:55:32
Message: <3b9bad14@news.povray.org>
news:3b9ba753@news.povray.org...
I believe density is considered to be rgb 1 by default even if a density
statement doesn't exist.  So, what Simon was reffering to is that you'll
need to add one in and use a smaller rgb.
Bob H.
Date: 9 Sep 2001 14:20:55
Message: <3b9bb307@news.povray.org>
> Bob H.
I was reffering to the color you use in your scattering or whatever
statement
for example:
scattering{1,rgb <1,0.5,0.239>}
Date: 9 Sep 2001 23:27:40
Message: <3b9c332c@news.povray.org>
news:3b9bb307@news.povray.org...
> statement
> for example:
I see, sorry.  Either way should result in the exact same thing.
Bob H.
