POV-Ray : Newsgroups : povray.binaries.images : Exoskeleton 1.5 (61 ko bu) Server Time
5 May 2026 00:00:40 EDT (-0400)
  Exoskeleton 1.5 (61 ko bu) (Message 6 to 15 of 15)
<<< Previous 5 Messages Goto Initial 10 Messages
Subject: Re: antiblobs (82 ko bu)
Date: 16 Jan 2001 10:49:12
Message: <3A646DE3.BDFB0B36@xlstudio.com>
> That looks good, i wonder if some reflection would be good, of course that
> would require some environment to reflect.
I'll make tests at home...
> I had a look at the shader code and although i do not yet completely
> understand how it works, the same should be possible with the slope
> pattern, although you then have to take the light positions into account.
I don't comment my tests in general...I know, it's not a good thing...
The advantage of the shader is that the lights positions are given (not
exactly but, the result is the same, you know where it comes from) and ease a
lot the work...this shader is simple (I think) because, there is no real
physic behind !
I just do a gradient with the 2 colors. the coef is given by the angle between
the light and the surface normal (Ln.Nn).
            David
Subject: rad antiblobs (31 ko bu)
Date: 17 Jan 2001 03:42:02
Message: <3A655B46.71EADAF@xlstudio.com>
I made tests at home !!
               David
Download 'antiblobs rad.jpg' (31 KB)
Preview of image 'antiblobs rad.jpg'
Subject: Re: rad antiblobs (31 ko bu)
Date: 17 Jan 2001 14:08:32
Message: <3A65EDAE.686CD696@gmx.de>
It looks good, some aspects of iridescence are still missing, but it's
probably difficult to simulate with povray anyway.
I found that combining radiosity with shaders somehow leads to strange
results, in this case radiosity should not have much influence on the
object, but i did not manage to achieve that.
Date: 17 Jan 2001 18:05:55
Message: <3A66252A.AEEF4A32@online.no>
gemelli david wrote:
> > Might want to try something like in:
> > Message-ID: <39A31644.AB3DE5EF@online.no>
> > Date: Wed, 23 Aug 2000 02:09:40 +0200
> > From: Tor Olav Kristensen <tto### [at] onlineno>
> > Subject: 72 Antiblobs (120kB + 22kB)
> Don't know if you wanted ME to do it but, here it is !
> (thanks Tor for the scene... and Christoph for the idea...)
I'm happy to see this !
But can you please explain to me what a "shader" is ?
And what is POVMan ?
Best regards,
Tor Olav
mailto:tor### [at] hotmailcom
Date: 17 Jan 2001 19:09:49
Message: <3A663311.4A4A8FE1@faricy.net>
POVMan is a POV/Renderman hybrod or such IIRC.
I'm going to venture a guess on shaders, but I don't actually know: does
it let you specify a falloff_map of sorts, like a color_map or slope_map
except related to brilliance and angle of incidence? I'm guessing
because I notice hue changes perpendicular to the light direction in
these renders.
Date: 17 Jan 2001 22:44:50
Message: <chrishuff-FB45B2.22455317012001@news.povray.org>
In article <3A663311.4A4A8FE1@faricy.net>, David Fontaine
It is an unofficial version of POV-Ray which supports RenderMan-like
shaders.
> these renders.
Shaders are just bits of code that specify how the color of the surface
is calculated. POVMan shaders are written in a special language that is
different than POV-Script and based on the RenderMan lanugage, it is
basically a way to customize rendering without having to patch the
program. The shaders are interpreted, so there is a speed penalty for
this flexibility. And I think POVMan shaders are just special pigments,
so you should be able to combine them with ordinary finish and normal
features, but would normally use ambient 1 to get the unmodified result
of the shader.
Basically super-functions which can handle colors and vectors and have a
different set of built-in functions, and result in a color instead of an
index for a color_map.
Christopher James Huff
Date: 17 Jan 2001 22:55:02
Message: <3A6667DC.D7C2FF34@faricy.net>
> > these renders.
> of the shader.
So in a way I was right... :)
Date: 18 Jan 2001 13:38:09
Message: <chrishuff-6F91E2.13391318012001@news.povray.org>
In article <3A6667DC.D7C2FF34@faricy.net>, David Fontaine
Sort of...there is no "falloff_map" and it doesn't use a color_map, but
it lets you do all those things. (As well as nearly any other effect
that can be programmed.)
Date: 19 Jan 2001 18:31:24
Message: <3A68CD06.44366D19@faricy.net>
I did make it a simile. :P
Date: 19 Jan 2001 20:10:16
Message: <chrishuff-415BBB.20112119012001@news.povray.org>
In article <3A68CD06.44366D19@faricy.net>, David Fontaine
Well, I *did* fail the second half of Grammar III last year... ;-)
