POV-Ray : Newsgroups : povray.binaries.images : Exoskeleton 1.5 (61 ko bu) Server Time
5 May 2026 01:24:38 EDT (-0400)
  Exoskeleton 1.5 (61 ko bu) (Message 1 to 10 of 15)
Subject: Exoskeleton 1.5 (61 ko bu)
Date: 16 Jan 2001 03:03:10
Message: <3A6400A5.98BB433A@xlstudio.com>
here is the version 1.5 (I've just added a '+' sign in order to make the
surface react to multiple lights !!)
I hope it isn't too dark this time !
I added a light source, made more spheres and added a little bump.
I tried to replace the spheres by a bumps pattern but, even if the shape
of the pattern is close to the original, the render is very ugly so, I
came back to my spheres...slow but nice !
        David
Download 'insect - test01.jpg' (61 KB)
Preview of image 'insect - test01.jpg'
Subject: Re: Exoskeleton 1.5 (61 ko bu)
Date: 16 Jan 2001 06:03:20
Message: <3A642A78.90555092@gmx.de>
Might want to try something like in:
Message-ID: <39A31644.AB3DE5EF@online.no>
Date: Wed, 23 Aug 2000 02:09:40 +0200
Subject: 72 Antiblobs (120kB + 22kB)
BTW, do you want to publish the shader code? :-)
Date: 16 Jan 2001 06:31:29
Message: <3A643180.4B30852D@xlstudio.com>
I've posted the shader and the test scene in povray.text.scene-files.
          David
Subject: antiblobs (82 ko bu)
Date: 16 Jan 2001 09:06:45
Message: <3A6455BF.F6623E12@xlstudio.com>
> From: Tor Olav Kristensen <tto### [at] onlineno>
Don't know if you wanted ME to do it but, here it is !
(thanks Tor for the scene... and Christoph for the idea...)
       David
Download 'antiblobs.jpg' (82 KB)
Preview of image 'antiblobs.jpg'
Subject: Re: antiblobs (82 ko bu)
Date: 16 Jan 2001 10:18:53
Message: <3A64665C.DDE99715@gmx.de>
That looks good, i wonder if some reflection would be good, of course that
would require some environment to reflect.
I had a look at the shader code and although i do not yet completely
understand how it works, the same should be possible with the slope
pattern, although you then have to take the light positions into account.
Date: 16 Jan 2001 10:49:12
Message: <3A646DE3.BDFB0B36@xlstudio.com>
I'll make tests at home...
I don't comment my tests in general...I know, it's not a good thing...
The advantage of the shader is that the lights positions are given (not
exactly but, the result is the same, you know where it comes from) and ease a
lot the work...this shader is simple (I think) because, there is no real
physic behind !
I just do a gradient with the 2 colors. the coef is given by the angle between
the light and the surface normal (Ln.Nn).
            David
Subject: rad antiblobs (31 ko bu)
Date: 17 Jan 2001 03:42:02
Message: <3A655B46.71EADAF@xlstudio.com>
I made tests at home !!
               David
Download 'antiblobs rad.jpg' (31 KB)
Preview of image 'antiblobs rad.jpg'
Subject: Re: rad antiblobs (31 ko bu)
Date: 17 Jan 2001 14:08:32
Message: <3A65EDAE.686CD696@gmx.de>
It looks good, some aspects of iridescence are still missing, but it's
probably difficult to simulate with povray anyway.
I found that combining radiosity with shaders somehow leads to strange
results, in this case radiosity should not have much influence on the
object, but i did not manage to achieve that.
Date: 17 Jan 2001 18:05:55
Message: <3A66252A.AEEF4A32@online.no>
I'm happy to see this !
But can you please explain to me what a "shader" is ?
And what is POVMan ?
Best regards,
Tor Olav
mailto:tor### [at] hotmailcom
Date: 17 Jan 2001 19:09:49
Message: <3A663311.4A4A8FE1@faricy.net>
POVMan is a POV/Renderman hybrod or such IIRC.
I'm going to venture a guess on shaders, but I don't actually know: does
it let you specify a falloff_map of sorts, like a color_map or slope_map
except related to brilliance and angle of incidence? I'm guessing
because I notice hue changes perpendicular to the light direction in
these renders.
