POV-Ray : Newsgroups : povray.binaries.images : Exoskeleton 1.5 (61 ko bu) Server Time
5 May 2026 00:01:14 EDT (-0400)
  Exoskeleton 1.5 (61 ko bu) (Message 11 to 15 of 15)
Subject: Re: antiblobs (82 ko bu)
Date: 17 Jan 2001 22:44:50
Message: <chrishuff-FB45B2.22455317012001@news.povray.org>
In article <3A663311.4A4A8FE1@faricy.net>, David Fontaine
<dav### [at] faricynet> wrote:
> POVMan is a POV/Renderman hybrod or such IIRC.
It is an unofficial version of POV-Ray which supports RenderMan-like
shaders.
> I'm going to venture a guess on shaders, but I don't actually know: does
> it let you specify a falloff_map of sorts, like a color_map or slope_map
> except related to brilliance and angle of incidence? I'm guessing
> because I notice hue changes perpendicular to the light direction in
> these renders.
Shaders are just bits of code that specify how the color of the surface
is calculated. POVMan shaders are written in a special language that is
different than POV-Script and based on the RenderMan lanugage, it is
basically a way to customize rendering without having to patch the
program. The shaders are interpreted, so there is a speed penalty for
this flexibility. And I think POVMan shaders are just special pigments,
so you should be able to combine them with ordinary finish and normal
features, but would normally use ambient 1 to get the unmodified result
of the shader.
Basically super-functions which can handle colors and vectors and have a
different set of built-in functions, and result in a color instead of an
index for a color_map.
Christopher James Huff
Date: 17 Jan 2001 22:55:02
Message: <3A6667DC.D7C2FF34@faricy.net>
> > these renders.
> of the shader.
So in a way I was right... :)
Date: 18 Jan 2001 13:38:09
Message: <chrishuff-6F91E2.13391318012001@news.povray.org>
In article <3A6667DC.D7C2FF34@faricy.net>, David Fontaine
Sort of...there is no "falloff_map" and it doesn't use a color_map, but
it lets you do all those things. (As well as nearly any other effect
that can be programmed.)
Date: 19 Jan 2001 18:31:24
Message: <3A68CD06.44366D19@faricy.net>
I did make it a simile. :P
Date: 19 Jan 2001 20:10:16
Message: <chrishuff-415BBB.20112119012001@news.povray.org>
In article <3A68CD06.44366D19@faricy.net>, David Fontaine
Well, I *did* fail the second half of Grammar III last year... ;-)
