POV-Ray : Newsgroups : povray.binaries.images : Fibonacci Stones (142KB) Server Time
25 Mar 2026 00:07:33 EDT (-0400)
  Fibonacci Stones (142KB) (Message 11 to 20 of 30)
Subject: Re: Fibonacci Stones (142KB)
Date: 5 Sep 2000 12:29:00
Message: <39B51E08.3B2723CB@online.no>
Richard Dault wrote:
> This is a little bit off topic, but not too much since raytracing is all
> about math.
> Anyone interested in mathematics and/or the golden ratio and/or pi should
> check out the film called "Pi".  See http://www.pithemovie.com for more info
> about it.
I would like to see this film, but unfortunately I haven't
seen any advertisements for it here in Norway.
But maybe I can order a DVD-copy of it.
Thank you for the tip.
Tor Olav
mailto:tor### [at] hotmailcom
Date: 5 Sep 2000 12:43:31
Message: <39B522EB.CF16615D@schunter.etc.tu-bs.de>
Tor Olav Kristensen wrote:
> Hmmm... I need to figure out how to make a
> sand texture.
plane with some granite normal or ... isosurface ;-)
> > maybe scale the texture ...
> Up or down ?
down, but you can also leave it as it is.
Date: 5 Sep 2000 13:35:05
Message: <chrishuff-AC6430.12364705092000@news.povray.org>
In article <39B517ED.F7229D48@online.no>, Tor Olav Kristensen
<tto### [at] onlineno> wrote:
> Or is it possible to read from an image file with
> standard POV ?
Not unless it is an ASCII format. However, you could position the blob
component at the origin, rotate an image map so the portion of the image
the blob will represent is also at the origin, and scale it up by a
large amount, so the whole component is a single color. Doing this, you
could make it *look* like each blob component has a solid color.
Using the eval_pigment() function would be much more elegant, though...
Christopher James Huff
Subject: Re: Fibonacci Stones -> Mosaic image (75KB)
Date: 5 Sep 2000 17:18:49
Message: <39B561E7.BC0D7B11@online.no>
> > standard POV ?
So I could read an uuencoded image then ? =)
Great idea !
I have now tried this with an array of spheres. => See attached image.
Is this a well known technique ?
Now I have to go and try to use this on my antiblobs,
as Xplo Eristotle suggested.
Yes, but .... :)
Tor Olav
Download 'imagemosaic01.jpg' (76 KB)
Preview of image 'imagemosaic01.jpg'
Date: 5 Sep 2000 17:23:55
Message: <39B56320.3F77E7E@online.no>
> > sand texture.
NO!  It can't be THAT simple.   :-)
I was thinking too complicated then ...
> > Up or down ?
Ok
Tor Olav
Date: 5 Sep 2000 17:43:03
Message: <39B567A5.57EC279A@online.no>
I used a part of the first image on this page:
http://www.wadhome.org/frazetta/overview0002.html
(Not really: Some years ago I scanned my Frazetta
poster-book with a monochrome scanner and added
pseudo colours to the image.)
If anyone is interested in the art of Frazetta, then here
are two links:
http://www.frazettaartgallery.com/
Tor Olav
Date: 5 Sep 2000 17:55:04
Message: <chrishuff-1ECF18.16564705092000@news.povray.org>
In article <39B561E7.BC0D7B11@online.no>, Tor Olav Kristensen
An interesting idea...anyone want to write a uu-decoder in POV-Script?
Ouch, did I really write "rotate"? I meant "transform"...
If it is, I have not seen it...it was just something I thought of as I
was writing that the eval_pattern() patch was the only way to do it. :-)
I highly doubt I was the first to come up with this idea, though,
especially since there have been mosaiac images in the past using
official POV.
> Yes, but .... :)
But it requires a patched version of POV.
And if you want to do something to the objects themselves that depends
on the color, or if you want to make them light sources or something,
you do have to use eval_pigment().
Date: 5 Sep 2000 18:21:16
Message: <39B5728A.54AE8936@unforgettable.com>
Ha! I can see it now: Fibonacci mosaic glows.
-Xplo
Date: 5 Sep 2000 18:23:45
Message: <39B5731F.5DE12310@unforgettable.com>
> > > sand texture.
Nonsense. Making 600,000 tiny isosurfaces and tracing them onto a
surface is a GOOD idea. :P
-Xplo
Date: 5 Sep 2000 18:58:06
Message: <chrishuff-1C2CFF.17594805092000@news.povray.org>
In article <39B5728A.54AE8936@unforgettable.com>,
My version of the glow patch is based on MegaPOV, which has
eval_pigment(), so I didn't mention that. Though it would be a problem
with POV-AFX...
