POV-Ray : Newsgroups : povray.binaries.images : POVEarth still far away... : Re: POVEarth still far away... Server Time
30 Mar 2026 18:57:18 EDT (-0400)
Date: 2 Aug 2020 14:52:37
Message: <5f270b75$1@news.povray.org>
Hi(gh)!
On 02.08.20 16:18, Bald Eagle wrote:
> Hmm.   That's pretty weird.
> What's your OS & povray version?
OS: Debian Linux 8.11
POV-Ray: 3.7.0.unofficial
> Have you tried running a different version or changing the #version statement at
> the top of the file?
I tried adding #version 3.6; - same as always before, memory access
error somewhere between a=18 and a=22.
> What about using #for instead of #while ?
I tried this also - memory access error at a=88.
> Stepping through the values by 2's ?
...is effectively by 3's (why?) - memory access error at a=171.
> If you can post an easy-to-follow version (indents, some comments) of your full
> code in the text file section, maybe I can spot something.
I did so, look at p.t.s-f
> Then everything that goes to the debug stream will go to the file as well.
> http://www.povray.org/documentation/view/3.6.1/222/
This produced just a seemingly endless rush of vertex numbers (from 0 to
999999), without any hint at the reason for the memory access error.
See you in Khyberspace!
Yadgar
