POV-Ray : Newsgroups : povray.binaries.images : Fresnel reflection { 0 } vs. Lambertian : Re: Fresnel reflection { 0 } vs. Lambertian Server Time
18 Mar 2026 09:07:54 EDT (-0400)
Date: 23 Jun 2020 23:34:56
Message: <5ef2c9e0$1@news.povray.org>
On 2020-05-06 12:16 PM (-4), William F Pokorny wrote:
> It looks like the parser defaults the finish fresnel to 1.0 if no float
> specified so you are turning it on in both cases despite not passing a
> non-zero float - and you have the required ior.
> When the reflection block precedes the finish block's fresnel, the
> fresnel keyword in the reflection block is turned on. Otherwise it is
> only on if you specify fresnel in the reflection block yourself.
>  From this, I don't think you are getting fresnel 'reflections' in any
> case.
> Fresnel is on always though, so it's still doing whatever it does to the
> other finish components - which I suspect explains the darker result.
> The idea of the finish level fresnel wasn't much about the reflection
> block as far as I knew, but about the behavior with respect to other
> finish elements when you know the (surface) IOR.
This was exactly the situation.  Giving fresnel an argument solved the
problem.  Thanks!
