POV-Ray : Newsgroups : povray.binaries.animations : Solar System Server Time
16 Apr 2026 23:00:37 EDT (-0400)
  Solar System (Message 33 to 42 of 72)
Subject: Re: Solar System
Date: 23 May 2017 15:20:00
Message: <web.59248aef4e850994c437ac910@news.povray.org>
> The issue with renders of the solar system is usually not memory, but
> precision; for example, if you set up a solar system with the sun at
> <0,0,0>, trying to render one of Mars' moons will give you issues with
> the precision used in the bounding mechanism.
> That issue can be solved by translating the whole solar system so that
> the camera ends up near <0,0,0>.
Excellent.  I will make a special note of that.
Is there a way in which greater precision may be obtained?
(I thought I saw something in that Graphics Gems series)
I realize that might be a somewhat complicated answer to a simple question, and
may not be something considered until V 4.0....
Date: 23 May 2017 15:49:11
Message: <59249237@news.povray.org>
I don't think it is Clipka you should be asking. Try the white haired
deity with flowing robes. ;)
Look at the Pale Blue Dot. At 3.7 billion miles, Earth's apparent size
is less than a pixel.
https://en.wikipedia.org/wiki/Pale_Blue_Dot
Regards
Date: 23 May 2017 16:05:01
Message: <web.592494cd4e850994c437ac910@news.povray.org>
I think Christoph's point is about significant figures.
If I have a planetary system with a moon at 651000 km away from the planet, then
I can model that accurately, whereas if I try to model that at the planetary
distance PLUS the moon orbit, then the planetary distance eats up a lot of zeros
and I can't calculate the smaller variations in distance.
Message: <web.592494f34e850994c437ac910@news.povray.org>
Also, 3D Models!
http://space.jpl.nasa.gov/models/
Date: 23 May 2017 16:24:35
Message: <59249a83$1@news.povray.org>
Yes and epsilon although if you can compile your own version of PovRay
you can change that.
Even if you could. Would you be able to see it at those distances?
Regards
Date: 23 May 2017 16:30:01
Message: <web.59249b934e850994c437ac910@news.povray.org>
Very nice.  I will have to look into that when I advance to that level, and get
a new computer   :)
With Lots of Vitamin A and squinting   :P
Date: 23 May 2017 16:39:30
Message: <59249e02$1@news.povray.org>
> Also, 3D Models!
You must be at work to do all this research. ;)
Thanks for the link. Pity there is only one texture.
I was thinking that when I finish my latest Earth. I would surround it
with as many space craft that I can.
Regards
Date: 23 May 2017 16:42:21
Message: <59249ead$1@news.povray.org>
> a new computer   :)
Carrots, don't forget to eat your carrots. :)
http://www.smithsonianmag.com/arts-culture/a-wwii-propaganda-campaign-popularized-the-myth-that-carrots-help-you-see-in-the-dark-28812484/
Regards
Date: 24 May 2017 01:10:13
Message: <592515b5@news.povray.org>
Hoe much of a performance hit will POV-Ray (in general) take if you do that?
Mike
Date: 24 May 2017 03:07:56
Message: <5925314c$1@news.povray.org>
>> level, and get
>> a new computer   :)
And never, repeat *NEVER*, forget your dried-frog pills! ;-)
