POV-Ray : Newsgroups : povray.binaries.animations : Solar System Server Time
26 Jun 2024 07:44:22 EDT (-0400)
  Solar System (Message 31 to 40 of 70)
Subject: Re: Solar System
Date: 22 May 2017 18:50:30
Message: <59236b36$1@news.povray.org>
On 5/12/2017 8:10 AM, Bald Eagle wrote:
> Here's the animation of the solar system over one Earth year.
> I just worked out a fast and efficient approximation for apsidal (orbital)
> precession last night. (not that it will make any noticeable effect)
> Still need to look up a bunch of things and do some further editing on the code
> before it gets fleshed out.
> Not sure how I ought to place the planets - so I just started at full syzygy.
> I may trace out the orbits in a future version.
Is POVray powerful enough to render details at large scale? I thought
there was a memory issue.
Mike
Date: 23 May 2017 07:53:17
Message: <592422ad$1@news.povray.org>
Am 23.05.2017 um 00:50 schrieb Mike Horvath:
>> (orbital)
>> the code
>> syzygy.
The issue with renders of the solar system is usually not memory, but
precision; for example, if you set up a solar system with the sun at
<0,0,0>, trying to render one of Mars' moons will give you issues with
the precision used in the bounding mechanism.
That issue can be solved by translating the whole solar system so that
the camera ends up near <0,0,0>.
Date: 23 May 2017 15:20:00
Message: <web.59248aef4e850994c437ac910@news.povray.org>
Excellent.  I will make a special note of that.
Is there a way in which greater precision may be obtained?
(I thought I saw something in that Graphics Gems series)
I realize that might be a somewhat complicated answer to a simple question, and
may not be something considered until V 4.0....
Date: 23 May 2017 15:49:11
Message: <59249237@news.povray.org>
I don't think it is Clipka you should be asking. Try the white haired
deity with flowing robes. ;)
Look at the Pale Blue Dot. At 3.7 billion miles, Earth's apparent size
is less than a pixel.
https://en.wikipedia.org/wiki/Pale_Blue_Dot
Regards
Date: 23 May 2017 16:05:01
Message: <web.592494cd4e850994c437ac910@news.povray.org>
I think Christoph's point is about significant figures.
If I have a planetary system with a moon at 651000 km away from the planet, then
I can model that accurately, whereas if I try to model that at the planetary
distance PLUS the moon orbit, then the planetary distance eats up a lot of zeros
and I can't calculate the smaller variations in distance.
Message: <web.592494f34e850994c437ac910@news.povray.org>
Also, 3D Models!
http://space.jpl.nasa.gov/models/
Date: 23 May 2017 16:24:35
Message: <59249a83$1@news.povray.org>
Yes and epsilon although if you can compile your own version of PovRay
you can change that.
Even if you could. Would you be able to see it at those distances?
Regards
Date: 23 May 2017 16:30:01
Message: <web.59249b934e850994c437ac910@news.povray.org>
Very nice.  I will have to look into that when I advance to that level, and get
a new computer   :)
With Lots of Vitamin A and squinting   :P
Date: 23 May 2017 16:39:30
Message: <59249e02$1@news.povray.org>
> Also, 3D Models!
You must be at work to do all this research. ;)
Thanks for the link. Pity there is only one texture.
I was thinking that when I finish my latest Earth. I would surround it
with as many space craft that I can.
Regards
Date: 23 May 2017 16:42:21
Message: <59249ead$1@news.povray.org>
> a new computer   :)
Carrots, don't forget to eat your carrots. :)
http://www.smithsonianmag.com/arts-culture/a-wwii-propaganda-campaign-popularized-the-myth-that-carrots-help-you-see-in-the-dark-28812484/
Regards
