POV-Ray : Newsgroups : povray.binaries.animations : Solar System Server Time
1 Jun 2024 16:10:39 EDT (-0400)
  Solar System (Message 11 to 20 of 70)
Subject: Re: Solar System
Date: 13 May 2017 00:50:00
Message: <web.5916900b4e8509949c5d6c810@news.povray.org>
Stephen <mca### [at] aolcom> wrote:
> On 5/12/2017 5:31 PM, Bald Eagle wrote:
> >>> Still pondering how to rotate the sun faster around the axis than the equator -
> >>> how to procedurally texture that....
Um, well, faster at equator. About 24 and a half days at equator and about 38
days at poles.
I wanted to do that kind of thing for sunspots and Jupiter cloud bands, which
doesn't transition evenly with latitude. Shouldn't be impossible to make
something looking good enough using patterned maps in a gradient y, guess so
anyway.
> >> You have started me thinking about creating a DF3 animation, of the sun.
> > Excellent!  Inspiration strikes!
> Maybe not. I was thinking about converting Blender's particle system
> into a point cloud or something like that but it is not obvious how it
> is done. I'll give it another decade or two to come up with an idea. ;)
> > Looks like Bob Hughes has taken a stab at that already:
> > http://objects.povworld.org/binaries/sun.pov
That does go way back, very simple really, and obviously doesn't render right
anymore in 3.7 so I tried fixing that.
It was from animation of solar probe idea, with Sun looking intensely bright at
first and dimming to show solar flares. Meant to be something like a lens filter
is being used. No realism of course.
// Persistence of Vision Ray Tracer Scene Description File
// File: SunChange.pov
// Vers: 3.7
// Desc: The Sun, with flares and corona.  Animatable to an extent.
// Date: 2000.8; 2017.36
// Auth: Bob Hughes
// Note: This Sun is not meant to be accurate, just my interpretation.
//       Will look different in Official POV-Ray as opposed to MegaPOV.
//       Scale is initially 1 million miles to 1 POV unit.
#version 3.7;
global_settings {
 assumed_gamma 1
// 1000000 will make scale be 1 unit = 1 mile
#declare S=1000000;
// for show
camera
  location <0,0,-2*S>
  angle 50
  look_at  0
background {rgb 0}
/* variable for Sun changes (can change this manually: use 0 to 1) */
#declare TimeLapse=1; //clock; // animate using clock here
// variables for Sunlight fading or filtering
#declare EXT=TimeLapse; // extinction, smaller is brighter
#declare Sc=TimeLapse; // emission, smaller is brighter
#declare Si=TimeLapse/2.5; //intensity, smaller number is brighter
union {
/* may want to use other than the "4" below or something else altogether
 be warned the light color changes the media appearance */
light_source
  0, 3-(Si*4)
       // area_light <.432,0,0>, <0,.432,0>, 3, 3 jitter adaptive 1
       // orient circular
        media_interaction on media_attenuation off
// Sun
#declare Space=density {rgb 0}
#declare Corona=
 density {
        radial turbulence .3 frequency 15
         density_map {
                [0 rgb <.125,.5,1.33>/3*.025*(1/S)]
                [1 rgb <.25,.67,1.25>/3*(.033+(Si/5))*(1/S)]
          sine_wave scale <.25,.125,.25>*3 rotate <5,0,5>
#declare Flares=
 density {
        marble phase (.55+(TimeLapse/10)) turbulence 1.6/2 frequency 1.3
         density_map {
                [0 rgb .025*(1/S)]
                [.75 rgb .05*(1/S)]
                [.85 rgb <.5,.33,.25>*(.1+(Si/1.33))*(1/S)]
                [.925 rgb <.5,.33,.25>*(.1+(Si/2))*(1/S)*2]
                [1 rgb <.5,.33,.25>*(.1+(Si/.33))*(1/S)*3]
         triangle_wave scale 0.67 rotate <60,45,100>
#declare Photosphere=
 density {
        bozo phase (TimeLapse/100) turbulence <1,.5,.25>*1.3
         //warp {turbulence <1,.5,.25>*1.3 octaves 2 lambda 1.5 omega 0.5}
         density_map {
                [0 rgb 0]
                [.95 rgb <1.125,1,.9>*(1.3+(Si/3))*(1/S)]
                [1 rgb <1.125,1,.9>*(.9+(Si/6))*(1/S)]
          ramp_wave scale .015
#declare Surface=
 density {
        crackle phase (TimeLapse/50)
         //warp {turbulence <1,.5,.25> octaves 2 lambda 1.25 omega 0.3}
         density_map {
                [.025*TimeLapse rgb .15*(1/S)]
                [.05*(.75+TimeLapse) rgb .3*(1/S)]
                [1 rgb <.75,.5,.33>*(2.5-(Si/1.25))*(1/S)]
          scallop_wave scale .005
#declare Interior=
 density {
        bozo phase (TimeLapse/100) turbulence <1,.5,.25>*.3
         //warp {turbulence <1,.5,.25>*.3 octaves 2 lambda 1 omega 0.2}
         density_map {
                [0 rgb 0]
                [.09 rgb <1.125,1,.9>*(.3+(Si/3))*(1/S)]
          ramp_wave scale .15
/* Sun (diameter is .864 units at the surface, 1 unit = 1 million miles) */
sphere
  0, 1
 pigment {rgbt 1}
  interior {
        media {
   method 3 samples 10,20
         emission <1,.75,.25>*((2-(Si/.25))+(1-Sc))
        // absorption <.33,.5,.67>*(.1+(Si*10))
        scattering {4,<1,.67,.33>*2 extinction (EXT/20)}
       density {
        spherical turbulence <.000125,.00015,.0002>
      density_map {
      [.025 Space] // end of Sun atmosphere
      [.25 Corona] // solar corona
      [.45 Corona] // solar corona inner edge
      [.5 Flares] // solar flares
      [.515 Photosphere] // solar photosphere
      [.5167+(TimeLapse/30) Photosphere] // solar photosphere
      [.568+(TimeLapse/15) Surface] // solar surface
      [.75+(TimeLapse/7.5) Surface] // solar subsurface
      [1 Interior] // solar interior
        } // media
        media {
   method 3 samples 5,10
         absorption <.33,.5,.67>*(.1+(Si*3))
       // scattering {4,<1,.67,.33>*1.33 extinction (EXT/20)}
       density {
      density_map {
      //[.25 Corona] // solar corona
      //[.45 Corona] // solar corona inner edge
      //[.515 Photosphere] // solar photosphere
      //[.5167+(TimeLapse/30) Photosphere] // solar photosphere
      //[.568+(TimeLapse/15) Surface] // solar surface
      //[.75+(TimeLapse/7.5) Surface] // solar subsurface
      }} // density
     } // media
  } // interior
  rotate 5*TimeLapse*y // a little rotation for animation
 hollow
 no_shadow
 } // sphere
  scale S
}  // union
Date: 13 May 2017 07:05:00
Message: <web.5916e64b4e850994883fb31c0@news.povray.org>
> [from Feynman's lectures, calculating all the positions of all the planets in the
Solar System]...
> "We need nine columns for the motions of Jupiter, nine for the motions of
> Saturn, and so on." [snip]
> http://www.feynmanlectures.caltech.edu/I_09.html
Here's something interesting to consider: In that particular part of the
lecture, Feynman is basically discussing the "n-body problem." The method
Feynman uses to get the results of all the interacting planetary positions is a
numerical *summation*, of the values in his list(s) of figures. As such, the
result is an approximation (which can be made more and more precise, but is
still an approximation.) In his previous simpler example-- the motion of a
spring-- he also uses a list of found values, but then notes that there is an
actual *equation* x=cos(t) that describes the situation exactly.
As far as I know, there is no exact solution or *equation* for solving the
"n-body problem", except for special cases where one or more of the variables is
simplified.
I think this is the reason why interplanetary spacecraft need 'course
corrections' every now and then, to arrive at their destinations. There are just
too many interacting variables to consider.
Date: 13 May 2017 08:38:39
Message: <5916fe4f$1@news.povray.org>
Am 13.05.2017 um 12:59 schrieb Kenneth:
> simplified.
I don't think so; the trajectories of spacecraft can be computed
numerically (simulated, if you will) with pretty good precision. There
are plenty other reasons for course corrections:
Some course corrections are simply inevitable, e.g. to enter or leave a
stable orbit around a celestial body.
Other course corrections are there to compensate for known
non-gravitational effects that cannot be compensated for by adjusting
the initial trajectory. An example would be decelerating effects on
orbital trajectories, such as atmospheric drag.
Spacecraft orbiting earth for any reasonably long duration will also
undergo occasional course corrections to evade pieces of "space junk".
Yet other course corrections are performed to compensate for influences
that would be impossible to predict with sufficient precision in
advance, such as mechanical tolerances in the propulsion systems,
acceleration due to non-uniform thermal radiation from the space probe,
interaction with coronar mass ejections, and other some such.
Date: 13 May 2017 11:15:01
Message: <web.591722e24e850994883fb31c0@news.povray.org>
I do a fair amount of amateur 'armchair thinking' about the n-body problem,
about why it hasn't been solved. (No solution from me yet-- ha!)
It seems that a new mathematical tool still needs to be found or invented, to
solve this and give an exact solution... a tool that's within our grasp, but
that just hasn't yet been formulated by a genius like Newton, Einstein or
Feynman.  (By solving it, I mean for the purely gravitational interactions of
all the planets, their moons, and the Sun-- without the 101 other subtle effects
involved.)
Calculus was invented to solve a 'similarly difficult' kind of problem (in
another mathematical realm), which had no real solution until then. And
Feynman's 'renormalization process' helped put quantum electrodynamics on a
surer footing. My gut feeling is that a new kind of tool like these is needed,
for exact solutions to mutually interacting objects, when there are lots of
objects involved.
Date: 14 May 2017 20:45:12
Message: <5918fa18$1@news.povray.org>
On 5/12/2017 8:10 AM, Bald Eagle wrote:
> Here's the animation of the solar system over one Earth year.
> I just worked out a fast and efficient approximation for apsidal (orbital)
> precession last night. (not that it will make any noticeable effect)
> Still need to look up a bunch of things and do some further editing on the code
> before it gets fleshed out.
> Not sure how I ought to place the planets - so I just started at full syzygy.
> I may trace out the orbits in a future version.
I tried modeling the solar system once in another program. I could never
figure out the "starting point" of each planet's revolution in time.
I.e. whether GMT is "aligned" correctly with respect to the sun and the
rest of the solar system.
I was unable to find this data in the source I looked in. IIRC there was
some sort of online database that you could access using queries, and it
would spit out the data relative to a chosen epoch. Can't remember the
name of the database now.
Mike
Date: 14 May 2017 23:13:51
Message: <59191cef$1@news.povray.org>
>> (orbital)
>> the code
>> syzygy.
If you want to be that accurate then search for "The equation of time".
That will give you the four days of the year when local time is the same
as solar time.
http://www.sundials.co.uk/equation.htm
That would be handy.
Regards
Date: 15 May 2017 08:10:01
Message: <web.59199a3a4e850994c437ac910@news.povray.org>
> The orbit of the moon would be nice to see.
Got about 24 of Jupiter's moons coded, both of Mars', and Earth's.
Jupiter is uv-mapped.
For some reason, my moons don't cast shadows onto my planets...   :|
I worked out lines connecting the center of the planet to the tiny moons, so
they can be tracked, and then added camera-facing text labels that revolve with
the moons, and I _think_ I got a torus object worked out to show the circular /
elliptical orbit.   I've only tested that with Luna.
Need to work out a formula to automatically adjust the typeface size for camera
distance.
(I have that as a 5730 kb animation - where to post?)
Got the auto-width bounding box, lines, and tori worked out - it's not perfect,
but it makes those things usable since I have a camera that moves across the
whole solar system  ;)
For some reason, I can see the far side of the torus through/in-front-of my
planet.   NO idea what's going on there.  A top-down view shows that the torus
fully surrounds the planet - so it's not a confusing viewpoint thing.
Camera definitions that follow a chosen planet around its orbit, so the
[visible] moons in the planetary system can be seen.
(Some of these "moons" are really _really_ tiny rocks  :O  )
Need to get a bit more data on celestial bodies.
Need to work out how to make my orbits precessing ellipses - for animation
purposes, and how to implement the stated eccentricity as a formula, and maybe
add some stars.
Download 'screenshot.png' (283 KB)
Preview of image 'screenshot.png'
Date: 15 May 2017 10:37:43
Message: <5919bd37$1@news.povray.org>
You have checked no_shadow is not set? :)
Use a white plane to see if any shadows are being cast.
You can try this newsgroup. If it is too large it can only fail.
Otherwise youtube and post a link.
You are getting on great guns.
Looking forward to seeing it.
Regards
Date: 15 May 2017 12:15:00
Message: <web.5919d3914e850994c437ac910@news.povray.org>
Too big.
An initial run was 5.59, the good one is 6.13MB.
Shall I email the good one to you?
Date: 15 May 2017 12:25:00
Message: <web.5919d5494e850994c437ac910@news.povray.org>
http://planetpixelemporium.com/planets.html
Wowza.  :)
Just the sort of thing I was looking for!
