POV-Ray : Newsgroups : povray.binaries.animations : spraypaint in motion Server Time
21 Mar 2026 06:45:02 EDT (-0400)
  spraypaint in motion (Message 1 to 4 of 4)
Subject: spraypaint in motion
Date: 22 Jan 2015 00:20:00
Message: <web.54c08807cd9fb75bbd92286f0@news.povray.org>
first test of my animation mods to my spraypaint macro.  Very slow, at the
moment: took most of two days to render 1800 frames.
A lot of that is because of the way I'm storing the point data between frames.
I'm currently working on some improvements that could speed things up
significantly.
comments are always welcome.
A.D.B.
Download 'spray1.avi.dat' (158 KB)
Subject: Re: spraypaint in motion
Date: 22 Jan 2015 19:36:05
Message: <54c19775$1@news.povray.org>
> significantly.
You might benefit from persistent variables in Uberpov for this
Date: 22 Jan 2015 21:15:00
Message: <web.54c1adcd5cb4e344bd92286f0@news.povray.org>
> > significantly.
no worries.  I fixed it.  It's WAY faster now.
I simply changed the way I saved the data -- from an array of points to a union
for each frame, with an index file that gets rewritten every frame and forms a
union of the unions.  My test render only took about 8 hours.
Though I suppose persistent variables would save quite a bit of time, I really
want this to be useful in the official version.
I also fixed a problem with the random distribution of particles being the same
for each frame.
A.D.B
Download 'spray3.avi.dat' (82 KB)
Date: 22 Jan 2015 21:35:01
Message: <web.54c1b3215cb4e344bd92286f0@news.povray.org>
> > > significantly.
> for each frame.
> Regards,
> A.D.B
I should have mentioned that the previous animation was actually a shorter test,
only 15 seconds as compared to 30. just to test the random fix.
I have more ideas for this. I'm thinking about support for multiple files --
different files for each spraycan -- and I'm considering changing the way I
handle the setup.  Currently there are quite a few parameters, and I have some
ideas...
Here's the second test. It looked really bad with my first attempt at fixing the
rand bug.
A.D.B.
Download 'spray2.avi.dat' (163 KB)
