POV-Ray : Newsgroups : povray.binaries.animations : alien seed sphere (animation 2.7 MB) Server Time
6 Dec 2025 07:55:07 EST (-0500)
  alien seed sphere (animation 2.7 MB) (Message 1 to 5 of 5)
Subject: alien seed sphere (animation 2.7 MB)
Date: 4 May 2009 02:10:02
Message: <web.49fe85c8fbc113faf50167bc0@news.povray.org>
As in, 'seeding' barren planets with life.
Just a fun little diversion. The animation is only about five seconds long. See
my post at...
http://news.povray.org/povray.binaries.images/thread/%3Cweb.49fe82c8fc186ae5f50167bc0%40news.povray.org%3E/
For some strange reason, when I view this on my Windows XP machine--using
Windows Media Player--I see a single, consistent 'stutter' at about 0.9 seconds
into it. This little glitch isn't there in the original image frames, nor is it
visible when previewing the animation in monkeyjam (the app I used to assemble
the images into an MPEG.) I'm wondering if anyone else sees this glitch?
KW
Download 'animated_alien_sphere.avi.dat' (3001 KB)
Subject: Re: alien seed sphere (animation 2.7 MB)
Date: 4 May 2009 12:50:00
Message: <web.49ff1c61dc4ed2723e3c08aa0@news.povray.org>
> my post at...
Hi Kenneth, I really like your animation. I can't wait until you're able to
share with us your methods!
> into it.
Sadly, this is also the case on my computer. I am running Windows XP too, so to
prove to myself that I wasn't going crazy I also looked at it under my fresh
dual-boot install of Windows 7, and I get the same result.
I loaded the video file into VirtualDub and indeed you have a duplicate frame at
frames 16 and 17 (0-based), which are identical. Removing frame 17 leaves a
smooth animation.
I don't know what to tell you, other than that I do see the glitch, and there
*is* an extra frame in there. Perhaps monkeyjam does see it too and removes the
duplicate frame automatically for you?
Date: 5 May 2009 02:00:05
Message: <web.49ffd564dc4ed272f50167bc0@news.povray.org>
> > seconds into it.
> smooth animation.
Thanks indeed for this info.  I'll take a closer look at my original frames,
although I'm 99% sure that the original un-blurred animation itself doesn't
include duplicate frames. (The scene's animation code--and my 'post'-blurring
code, averaging each 15 frame batch--are both 'clean' AFAIK, and wouldn't have
produced a duplicate frame, anywhere in the chain.)  It's definitely a strange
situation.
Before posting my animation file, I actually went through two complete attempts
at encoding the 'blurred' animation in monkeyjam (using the xvid MPEG codec,
BTW), and both times, the same little stutter showed up when I viewed it in
W.M.P. I haven't seen such a glitch before, in my other similarly-made
animations.
Time to do some detective work!
Ken W.
Date: 6 May 2009 15:00:01
Message: <web.4a01dcbedc4ed272f50167bc0@news.povray.org>
OK, I've discovered some strange things.
I went back and re-rendered a large block of original animation frames
surrounding this glitch. No duplicate frames anywhere--I checked. Then I
'post'-blurred them as before (again, no duplicate frame among the final
blurred animation frames), and again used monkeyjam and the xvid codec to make
the .avi MPEG movie. And, as I expected, there is a glitch again--a duplicated
frame--but now it isn't in the same place!
So I did some tests, using different video compression codecs in monkeyjam:
INDEO, CINEPAK, and MJPEG.  And, much to my surprise, none of those three
resulting animations show any duplicate frames! It only happens when monkeyjam
uses the xvid codec. So I went into xvid and fiddled with some settings
there--which didn't help.
Using VirtualDub (thanks for the hint, BTW), I took this 'new' glitchy animation
and removed the offending duplicate frame; then re-encoded it there using xvid
again (just as a test), and the final animation plays in W.M.P. with no glitch.
(So it wasn't a Windows Media Player problem, as I had originally thought; nor
specifically an xvid problem.)
So the only conclusion I can come to is that monkeyjam and the xvid codec have
some kind of problem working together. Which means I need to go back through
*all* the xvid-encoded animations I've made, to see if *they* contain any
duplicate frames that I never noticed.
KW
Date: 9 May 2009 04:55:01
Message: <web.4a0543addc4ed272f50167bc0@news.povray.org>
Sadly, I *do* see duplicate frames in many of my other monkeyjam/xvid
animations-- usually at the very beginning of the animation (which is probably
why they escaped my notice before) and *sometimes* an additional frame
somewhere within the animation. But I also discovered that monkeyjam has
sporadic problems with *other* MPEG compression codecs as well; not duplicated
frames per se, but other errors which look like 'interleaved video.' Not all of
the time, though, which is rather maddening.
Given these monkeyjam/codec errors, I think that from here on out, I'll use
monkeyjam only to *assemble* the animation, save it as a temporary,
UNCOMPRESSED video (which results in a large file, of course), then import that
into VirtualDub and do the xvid compression there. Experiments so far show me
that this is an error-free approach.
KW
