POV-Ray : Newsgroups : povray.binaries.animations : Vertex-motionblur in Megapov Server Time
10 May 2025 02:20:13 EDT (-0400)
  Vertex-motionblur in Megapov (Message 1 to 4 of 4)
Subject: Vertex-motionblur in Megapov
Date: 5 Jan 2009 17:25:01
Message: <web.4962871b77f8acca20776f0@news.povray.org>
Hi people!
While taking a closer look to the motionblur in megapov, I regonized that a
vertex-motionblur is possible.
All examples working only with transforms, such as translate, rotate, scale...
I've started to write a universal PovScript to handle a syntax, which is very
similar to the mesh2 syntax that generates the motionblur bases on geomagnetic
information from two frames.
The syntax for the geometry looks like this:
#declare Vertex_Vectors=array[1140][3]
 {0.0750842,-1.98293,4.51802},
 {0.106474,-1.58801,4.71834},
#declare Normal_Vectors=array[1140][3]
 {-0.996115,0.0880451,-0.00146716},
 {-0.996944,0.0780921,0.00226744},
#declare Uv_Vectors=array[1140][2]
 {0.447334,0.909562},
If you already familiar with the mesh2 syntax, you'll see the similarities.
I've already start to write a script for 3DS-MAX to export animated geometry, so
that it cam be rendered with motionblur in MegaPov.
I'm still working on it, but I'll think, I can share a working version in the
next two weeks.
The video shows a "running box", animated with MAX and was exported by my first
script and rendered with MepaPov
Holger :)
Download 'vector-mb.avi.dat' (673 KB)
Subject: Re: Vertex-motionblur in Megapov
Date: 6 Jan 2009 11:25:00
Message: <web.4963851484f4b9bc7e0b1b500@news.povray.org>
"H. Karsten" <h-karsten()web.de> wrote:
> Hi people!
> next two weeks.
> Holger :)
Sounds interesting.
I believe that the animation is very, very fluently.
Date: 6 Jan 2009 14:20:00
Message: <web.4963ae2784f4b9bcef2b9ba40@news.povray.org>
> Hi people!
Neat technique.  Good run cycle, too.  Quite smooth.  So is it just a linear
interpolation between successive frames?
 - Ricky
Date: 10 Jan 2009 12:40:00
Message: <web.4968dbeb84f4b9bc20776f0@news.povray.org>
"triple_r" <nomail@nomail> wrote:
> ..So is it just a linear
>  - Ricky
Yes, the interpolation is just from the current frame to the next. But I'm think
about to build a "natural_spline" for each vertex, five values per spline
(coming from five frames). This would give a _much_ better interpolation and it
would be possible to make timewarps by defining a time_spline for the camera and
another for the scene - something like this. The motionblur keeps very strong,
while everything (or just the scene, or the just camera, slows down)
I'm still working on it. I'm also build a interpolation between matrix-values to
get a motionblur by exporting simple translations.
I'm already build an exporter for matrix translations.
http://news.povray.org/povray.binaries.animations/attachment/%3Cweb.491889e0fd2a694020776f0%40news.povray.org%3E/m2.avi
.dat
The Robot was modeled in Rhino, in Max I'm just animated a lowpoly-version of
it. The rendered geometrie you see in the clip never ever goes throe Max.
PovRay just take the Matrix (exported from Max with the build in
VUE-File-Renderer), take the monster-polygon-version and render this...
But there is still a lot of work to do :)
Holger
