POV-Ray : Newsgroups : povray.binaries.animations : need help - clock - Server Time
21 Apr 2026 23:19:54 EDT (-0400)
  need help - clock - (Message 8 to 17 of 17)
<<< Previous 7 Messages Goto Initial 10 Messages
Subject: Re: need help - clock -
Date: 12 Feb 2007 07:25:00
Message: <web.45d05c2252f9d244718caa6c0@news.povray.org>
hi again,
i do care about this class and everybody in the whole class would get the
code you`ll give me...
Date: 12 Feb 2007 08:05:00
Message: <web.45d065a752f9d244f1cb1e660@news.povray.org>
"nero.corporations" <ner### [at] webde> wrote:
> hi again,
completed code for your schoolwork. You will get all the help we can give
you for you to do it yourself. I will describe how I would do it.
First create a clock face. You could use a disc or a cylinder. Next find an
image map that you can use for a texture. I googled
http://images.google.co.uk/images?hl=en&q=clock+face&btnG=Search+Images
Section 3.5.1.5  Image Maps in the documents will tell you how to use them.
Next create your clock hands. I would use CSG (Constructive Solid Geometry)
to create them. You will need something for the centre of the clock face to
represent the spindle that rotates the hands a cylinder will do.
One you have put your clock together you can rotate the hands to show the
time. Remember that all rotations in Pov-Ray are about the origin. So you
will need to offset your hands so that the point of revolution is at the
origin.
Next you will need to use the clock function to animate the rotation.
(3.2.1.3.6  Built-in Variables) Also look at some of the examples that come
with P0v=Ray.
Feel free to ask for help once you have started to build your scene.
Date: 12 Feb 2007 14:55:01
Message: <web.45d0c55252f9d24447d3ae5e0@news.povray.org>
If you dont care about actually learning anything, then render 70 or so
images and make a gif animation which changes image once per second... ;)
Date: 12 Feb 2007 15:28:15
Message: <45d0cddf$1@news.povray.org>
70-second minutes, mmm. Suitable for everything, except working.
Eero "Aero" Ahonen
   http://www.zbxt.net
Date: 13 Feb 2007 09:10:01
Message: <web.45d1c65752f9d24447d3ae5e0@news.povray.org>
> Eero "Aero" Ahonen
>    http://www.zbxt.net
Huh..?
A digital clock would start at say 13:45:10 and go through all images, one
per second, and end at 13:46:20...
I never said it was a good idea though, just a slick solution.
Date: 13 Feb 2007 13:47:31
Message: <tt14t21pusb8va49833qd9pnbh866d9bpp@4ax.com>
>> Eero "Aero" Ahonen
>>    http://www.zbxt.net
>Huh..?
I've a better idea, not saying that yours is not good.
A sundial, that measures in hours, minutes and seconds. If the reader can't make
out the seconds then it's his fault for not being skilful enough :-)
Regards
Date: 13 Feb 2007 14:35:14
Message: <45d212f2@news.povray.org>
> Huh..?
The first thing that came to my mind from your idea :).
Yep, I got the idea - I just got another idea also. Actually it (clock
with 70-sec/min, 70-min/h, 25h/d oslt) could be a nice idea for some
unrealistic animation, just as one little thing at the background,
almost unnoticable. Or for the given task a little trick for the teacher
:p, make seconds go a bit faster to get 70 sec-ticks to one minute,
still reaching the correct time in the long run.
Eero "Aero" Ahonen
   http://www.zbxt.net
Date: 13 Feb 2007 15:35:01
Message: <web.45d2201652f9d24447d3ae5e0@news.povray.org>
> Regards
>  Stephen
Hahaha, that's a neat idea indeed!
And Eero, sorry I misunderstood you.
Hehe, I sure wish the clock had 70 seconds per minute on spare time,
preferably borrowed time from 50 second minutes when at work... ;)
Date: 19 Feb 2007 07:30:00
Message: <web.45d997ae52f9d244aec9e0a10@news.povray.org>
thats at least what our teaher did...
i said, he is unqualified as no one else... think my mum could do that
better
Date: 19 Feb 2007 07:55:00
Message: <web.45d99cfb52f9d244f1cb1e660@news.povray.org>
> better
He really should have explained what was required of you, better.
Do you know the English adage?
Those who can, do.
