POV-Ray : Newsgroups : povray.binaries.animations : Liquid animation 23 Server Time
21 Apr 2026 21:29:53 EDT (-0400)
  Liquid animation 23 (Message 1 to 7 of 7)
Subject: Liquid animation 23
Date: 11 May 2006 14:15:01
Message: <web.44637dde8c0f5a5deeb4d6bd0@news.povray.org>
Hello,
I post a new animation of 2 objects falling in a tank of water. One object
is a wood box, the other one is a steel sphere. The target was to test the
different interactions water <-> object <-> object.
The video is MPEG1 encoded.
Any comment is wellcome.
Fidos.
Download 'box.mpg' (693 KB)
Subject: Re: Liquid animation 23
Date: 11 May 2006 19:56:26
Message: <4463cf2a$1@news.povray.org>
fidos wrote:
> Hello,
> Regards,
> Fidos.
Fantastic work fidos. I love these simulations you've been working on!
The wood block seems to behave a bit funny here, maybe that's just
because I don't have any personal experience with dropping a steal ball
and a block of wood into a tank? ;) It sort of looks like the wooden
block is not dense enough compared to the steel ball?
Date: 11 May 2006 20:48:20
Message: <4463db54$1@news.povray.org>
This is a major limitation of the ODE library, that all objects have the
same density.
...Chambers
Date: 11 May 2006 21:05:43
Message: <tpn7621v737vlsflmkispdjqepsb6fgvht@4ax.com>
Unless it is made of balsa wood.  :-P
Kyle
Date: 12 May 2006 13:10:01
Message: <web.4464c114c337d213c4b63fa80@news.povray.org>
Thomas Lake <smi### [at] hotmailcom> wrote:
> fidos wrote:
> > Hello,
> > Regards,
> > Fidos.
Thank you. I used a density of 0.25 for the wood and 1 for the steel. I know
that it is not realistic (not enough for both) but I wanted to have good
reaction of the box when the ball fall on it.
Fidos.
Date: 12 May 2006 13:20:00
Message: <web.4464c292c337d213c4b63fa80@news.povray.org>
> same density.
> ...Chambers
You can use the function dMassSetSphere(density) in case of a sphere to init
a dMass structure and after call the function dBodySetMass to attach the
mass to the body. It is what I do in my simulation.
Fidos.
Date: 15 May 2006 07:50:53
Message: <44686b1d$1@news.povray.org>
fidos scripsit::
>> fidos wrote:
>>> Hello,
>>> Regards,
>>> Fidos.
Steel: density about 8
water: density of 1
wood: typical density between 0.5 and 1.1 (ebony), using 0.9 ?
Eifersucht ist die Leidenschaft, die mit Eifer sucht, was Leiden
schafft.
Eco: -8.75 Soc: -6.72
http://www.politicalcompass.org/
