![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Hello,
I post a new animation of 2 objects falling in a tank of water. One object
is a wood box, the other one is a steel sphere. The target was to test the
different interactions water <-> object <-> object.
The video is MPEG1 encoded.
Any comment is wellcome.
Fidos.
Download 'box.mpg' (693 KB)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
fidos wrote:
> Hello,
> Regards,
> Fidos.
Fantastic work fidos. I love these simulations you've been working on!
The wood block seems to behave a bit funny here, maybe that's just
because I don't have any personal experience with dropping a steal ball
and a block of wood into a tank? ;) It sort of looks like the wooden
block is not dense enough compared to the steel ball?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
This is a major limitation of the ODE library, that all objects have the
same density.
...Chambers
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Unless it is made of balsa wood. :-P
Kyle
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Thomas Lake <smi### [at] hotmail com> wrote:
> fidos wrote:
> > Hello,
> > Regards,
> > Fidos.
Thank you. I used a density of 0.25 for the wood and 1 for the steel. I know
that it is not realistic (not enough for both) but I wanted to have good
reaction of the box when the ball fall on it.
Fidos.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> same density.
> ...Chambers
You can use the function dMassSetSphere(density) in case of a sphere to init
a dMass structure and after call the function dBodySetMass to attach the
mass to the body. It is what I do in my simulation.
Fidos.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
fidos scripsit::
>> fidos wrote:
>>> Hello,
>>> Regards,
>>> Fidos.
Steel: density about 8
water: density of 1
wood: typical density between 0.5 and 1.1 (ebony), using 0.9 ?
Eifersucht ist die Leidenschaft, die mit Eifer sucht, was Leiden
schafft.
Eco: -8.75 Soc: -6.72
http://www.politicalcompass.org/
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
