![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Hello,
I rendered my last post on a different angle and with radiosity and photons.
Here the result.
Any comments are wellcome.
The video is mpeg1 encoded.
Fidos.
Download 'wheel2.mpg' (671 KB)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
"fidos" <fid### [at] wanadoo fr> wrote:
> Hello,
> Here the result.
> Regards,
> Fidos.
Awesome!
I like this one the best.. the water looks more realistic here, and I like
the interaction between the water stream and the wheel. How did you do the
wheel motion, by the way?
I'd like to see more detail in the water surface (both spatially and
temporally), because some very interesting stuff happened at the end but it
also got choppy at the same time.. also the video ended too soon, as usual
Can you compute the simulation on other computers in parallel?
Kudos,
George
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
The motion of the wheel is done why ODE (http://ode.org/).
I think I used a too big diameter for the water source. It results in too
much water falling in the tank and the choppy effect.
No, my fluid simulator can only run on one computer. Moreover, my coding is
single thread. So the use of a dual core computer is also not a solution to
speed up the computation.
Fidos.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
