POV-Ray : Newsgroups : povray.binaries.animations : The Whiskey Corner Server Time
28 Mar 2026 21:37:42 EDT (-0400)
  The Whiskey Corner (Message 1 to 10 of 10)
Subject: The Whiskey Corner
Date: 5 Apr 2006 07:20:00
Message: <web.4433a67696b9597347d3ae5e0@news.povray.org>
Yup, that's the name of a counter-strike gaming community
(in Swedish WhiskyHornan), to wich I made this short
intro/splasher/thingy.
Some after effects added; text, fading and animated scene change.
The rest is pure Pov-Ray. Please have a look! =)
Mpeg format
~20Mb
~35 seconds
Located at:
http://s57.yousendit.com/d.aspx?id=2X8VMQ03SC1CC0ZYLPE1DV1T5V
Size 800*600
AA 0.3
Total render time for the 750 frames: 4d 4h 17m 7s
//RH
Subject: Re: The Whiskey Corner
Date: 5 Apr 2006 10:13:25
Message: <4433d085@news.povray.org>
> Mpeg format
> ~20Mb
> ~35 seconds
> Located at:
> Size 800*600
> AA 0.3
> //RH
Looks sweet :)
Nitpick : there's a little flickering in the necks of the bottles
Ger
Date: 5 Apr 2006 15:25:01
Message: <web.443418cc71c345d047d3ae5e0@news.povray.org>
Ger <No.### [at] ThankYou> wrote:
> Looks sweet :)
Thanks1 =)
> Ger
Yeah, I noticed that too. Probably would have been less of it with more
AA... but I dare not think of what the render time would have been then...
Date: 5 Apr 2006 16:33:12
Message: <44342988$1@news.povray.org>
Looks more like a coincident surface problem... (Given that there's
absolutely nothing to be refracted that could be generating so much
noise!) Does the liquid inside the bottle "touch" the bottle itself?
Date: 5 Apr 2006 17:22:06
Message: <l4d832tpojbp8tg9u0ph10m6j8spglfvu6@4ax.com>
Media Player 10 doesn't find the video codec for some reason.  What
codec did you use?  Maybe I can install it manually...
Thanks,
Kyle
Date: 7 Apr 2006 10:55:01
Message: <web.44367cfb71c345d047d3ae5e0@news.povray.org>
Orchid XP v2
Umm.. the liquid MAY be touching the bottle... perhaps. But it's just a
cylinder so I could just slightly decrease its radius. But would making the
whole bottle a union also remove it? :?
Kyle
How odd! I used a standard Mpeg-2, (if there is such a thing).
Tried VLC media player? I can recommend it, anyway! =)
Date: 7 Apr 2006 13:43:29
Message: <4436a4c1$1@news.povray.org>
No, making it a union will have no effect. (Merge might - but that's
usually *lots* slower.)
Try leaving a tiny gap between liquid and bottle and see if that fixes
the problem. (If it does, will probably render a fair bit faster too.)
Date: 7 Apr 2006 15:48:03
Message: <4436c1f3@news.povray.org>
Hash: SHA1
	There is, but windows doesn't support it (or any kind of MPEG2)
unless you have a DVD drive and the codec came with its drivers...
If you want maximum compatibility, use MPEG1. Otherwise, DivX (or
similar, like XviD) will give you better compatibility than MPEG2
with better quality to boot.
		Jerome
+------------------------- Jerome M. BERGER ---------------------+
|    mailto:jeb### [at] freefr      | ICQ:    238062172            |
|    http://jeberger.free.fr/     | Jabber: jeb### [at] jabberfr   |
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.2 (GNU/Linux)
iD8DBQFENsHyd0kWM4JG3k8RAgPjAJ0QICKG2JDoAvRSfqlqSZA2YDpNpwCeLw6p
q8AaNPRLHjmgc2ndTFnXtqs=
=eCni
-----END PGP SIGNATURE-----
Date: 7 Apr 2006 21:56:20
Message: <o06e325uc93anpegkcpcjom1pb11uec7bu@4ax.com>
I downloaded SLD Codec Pack version 2.2 and it apparently had the
correct codec.  I was able to view the video.  Pretty cool.
Kyle
Date: 8 Apr 2006 21:20:46
Message: <4438616e$1@news.povray.org>
I've not seen knives or ammo that were that shiny.  Usually the finish
has been dulled by surface corrosion.  Something with specular
highlighting would be more realistic.
Otherwise, pretty good.
John
