![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Hello,
I post a new fluid animation done with my fluid simulator. It's a ball
falling in a tank of water. It's my first results of a simulation where the
(object -> water) and (water -> object) interactions are computed.
The object is animated with ODE (http://www.ode.org/). I stopped to use
MechSim because I faced some stability problem.
The rendering is done with MegaPov 1.0.
The video is MPEG1 encoded.
Any comment is wellcome.
Fidos.
Download 'ball.mpg' (667 KB)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Well done! How long did this take?
John
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Thank you. The simulation took around 12 hours and the rendering around 10
hours.
Fidos.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Very nice!
Nitpicking: There's a lot of water on the ball after it pops up again,
and that water seems pretty glue-like (not fluent enough).
And thanks for pointing out ODE, too, didn't know it before.
Florian
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
It's a good point. The problem is coming from the way I handle the water /
object interface. I extend the speed of the object in the water which
results in that glue effect. I think that it also provoques the reduction
of the splash when the ball enter in the water. This last point is
something that I would like to improve.
Fidos
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
The feeling I get looking at this one is that the water is very thick. I
think that is because it's a plain blue ball, which makes it hard to
imagine what the impact of the ball hitting the water should be. If you for
instance used a ping-pong ball, a wooden ball or a metal ball texture one
would easier 'recognize' the effect the ball should have on the water
(given that you want to simulate plain water).
I love seeing your progress and always look out for the next animation.
Again it's absolutely nice to look at.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
