POV-Ray : Newsgroups : povray.binaries.animations : Pannellum Server Time
18 May 2024 03:42:42 EDT (-0400)
  Pannellum (Message 4 to 13 of 23)
<<< Previous 3 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Pannellum
Date: 3 Apr 2017 05:40:02
Message: <58e21872$1@news.povray.org>
On 4/3/2017 9:50 AM, omniverse wrote:
> Mike Horvath <mik### [at] gmailcom> wrote:
>> On 4/2/2017 8:52 PM, Mike Horvath wrote:
>>> I updated my spaceship scene and rendered new frames to be used with
>>> Pannellum panorama viewer.
>>> http://isometricland.net/panorama/pannellum.htm?config=pano-gh-scene-spinner.json
>>> I still was not able to turn the interior atmosphere due to render
>>> times. Even on the 16-core MS Azure server I am using for my renders
>>> this month, things were taking too long.
>> Forgot to mention there are strange square shaped artifacts in the blue
>> end caps of the scene. They exist in the source images as well. I don't
>> know what causes them.
> Impressive scene. And maybe disorienting to some earthbound people. :)
Yes it is impressive. :)
> If able to see it, is the atmosphere both ground-hugging and cloudlets floating
> around?
> Wild guess about the squares. Could it be something about the ends being
> directly opposite and slightly reflective, max_trace_level?
> Although I don't recall seeing unusual squared patterns from anything like that
> before.
I would definitely check the max level first.
When you were making the trefoil, is there anything with an unusual
normal involved?
Regards
Date: 3 Apr 2017 08:14:00
Message: <58e23c88$1@news.povray.org>
Am 03.04.2017 um 03:08 schrieb Mike Horvath:
Looks like radiosity artifacts to me.
Your scene may need a more exhaustive radiosity pretrace.
Make sure you have `always_sample` set to `off` (or not set at all).
Date: 3 Apr 2017 12:35:20
Message: <58e279c8$1@news.povray.org>
Here are my global settings. Radiosity is disabled.
global_settings
	charset utf8
	assumed_gamma	1.0
	#if (!NoRadiosity)
		ambient_light	0
		radiosity
			pretrace_start	0.08
			pretrace_end	0.02
			count			20
			error_bound		1
			recursion_limit	1
			normal			on
			brightness		0.8
			always_sample	no
			gray_threshold	0.8
			media			on
	#switch (TexQual)
		#case (-1)
			max_trace_level 4
		#break
		#case (0)
			max_trace_level 4
		#break
		#case (1)
			max_trace_level 4
		#break
		#case (2)
			max_trace_level 4
		#break
Mike
Date: 3 Apr 2017 12:37:06
Message: <58e27a32$1@news.povray.org>
Thanks!
> around?
No, it is a constant density.
> before.
It could be, since I have it set very low.
Mike
Date: 3 Apr 2017 14:10:32
Message: <58e29018$1@news.povray.org>
Am 03.04.2017 um 18:36 schrieb Mike Horvath:
Then I have no idea what might cause the artifacts.
Date: 3 Apr 2017 15:50:01
Message: <web.58e2a6b4d40b65bd9c5d6c810@news.povray.org>
> > around?
Ah, okay, I was using my imagination anyway. No I'm wondering what that would do
in the spiral light... if that is a light.
> > before.
What is really strange about it, to me, is how one of the nearby artifacts
(after moving scene around) appears to have a 90 degree angle going on.
The square shapes form a sort of floor and wall, if thinking of it as partially
covering tiles without seams where they meet.
Hopefully you can see or find that too.
Date: 4 Apr 2017 06:00:01
Message: <web.58e36e8bd40b65bd883fb31c0@news.povray.org>
> global_settings
>  charset utf8
[snip]
Although I haven't seen your animation yet, the   charset utf  entry caught my
eye. Wasn't there another recent post about artefacts due to that? I think it
was in the post about the "Dokken" logo not rendering correctly.
Date: 4 Apr 2017 09:25:36
Message: <58e39ed0$1@news.povray.org>
Am 03.04.2017 um 21:47 schrieb omniverse:
My guess is that the 360 degree image format is using a cube model, and
what you see is the edge of that box.
Date: 4 Apr 2017 09:27:55
Message: <58e39f5b$1@news.povray.org>
Am 04.04.2017 um 11:59 schrieb Kenneth:
>> global_settings
>>  charset utf8
> [snip]
"charset utf8" can't give you genuine render artifacts. It can only give
you wrong character shapes in a `text` object.
Date: 4 Apr 2017 22:17:03
Message: <58e4539f$1@news.povray.org>
Yes, it uses 6 images to form a cube map. The artifacts are distributed
randomly across each of the 6 images.
Mike
