POV-Ray : Newsgroups : povray.binaries.animations : Ocean waves (WIP) Server Time
29 Jun 2024 00:03:58 EDT (-0400)
  Ocean waves (WIP) (Message 1 to 10 of 21)
Subject: Ocean waves (WIP)
Date: 22 Jan 2009 17:34:11
Message: <4978f463$1@news.povray.org>
Hi, all.
The other day I had an idea of how to make realistic animated ocean
waves. Now I have implemented a first version of it and it turned out
quite well. It's not finished, I still have some things to try. It also
needs a better material.
Animation: http://www.daniel-nilsson.com/ocean01.mpg (1.6Mb)
Statistics: http://www.daniel-nilsson.com/ocean01.txt (for 250 frames)
The ocean surface is a mesh2 generated from a parametric surface defined
by three functions: x(u,v,t), y(u,v,t), z(u,v,t). I tried to use a
parametric object instead of mesh but it is much slower and looks no
better. The material is a uv mapped texture map using a function pattern
that controls the amount of foam.
There is no data saved between frames, no slow simulations, just
functions. It actually rendered much faster then I though it would,
almost 10 frames/minute on one core of my core2 quad @2.4GHz for 320x240
and no aa.
I'll post the code when it is finished and cleaned up.
Daniel Nilsson
Subject: Re: Ocean waves (WIP)
Date: 22 Jan 2009 19:35:00
Message: <web.49790fe645771519a7aaf540@news.povray.org>
Hum... Media Player won't play media...
Date: 22 Jan 2009 22:05:09
Message: <497933e5@news.povray.org>
clipka nous illumina en ce 2009-01-22 19:31 -->
Same thing here. Refuse to play.
Where the press is free and every man able to read, all is safe.
Thomas Jefferson
Date: 22 Jan 2009 22:35:47
Message: <49793b13@news.povray.org>
Try right-click on link, save to desktop, then play it from there. Works
OK for me.
Jack
Date: 23 Jan 2009 04:55:01
Message: <web.497992fe45771519a7aaf540@news.povray.org>
Glad to here it's not just my MP being crapped up again... had a problem
recently with that "alien in the park" movie, where my MP wouldn't install a
proper codec automatically for some stupid reason, so I had to find out how to
do that manually.
Message: <web.497993ae45771519a7aaf540@news.povray.org>
> OK for me.
Was the first thing I did when it didn't play right from the net. No-go though.
Date: 23 Jan 2009 09:13:05
Message: <g1kjn4tcpt8kkrjkkp2id3v9v1aelm98b8@4ax.com>
>> OK for me.
VCL Media Player plays just about anything even broken downloads.
Regards
Date: 23 Jan 2009 11:42:28
Message: <4979f374$1@news.povray.org>
Hmm, I encoded it with mencoder in linux with some settings I found on
the net. If someone can tell me some working options I'll use them.
Otherwise I will experiment some and test in windows before posting the
next time. I'm new to video encoding so I though that a MPEG-1 file is a
MPEG-1 file, and works everywhere. Obviously, that's not the case.
Daniel Nilsson
Date: 23 Jan 2009 12:40:01
Message: <web.497a00a24577151bdc576310@news.povray.org>
Thanks for the advice, but I'd like to stick to WMP if it can be helped.
Date: 23 Jan 2009 12:50:01
Message: <web.497a031a4577151bdc576310@news.povray.org>
That's what I thought as well - and I also thought that a .wma file is a .wma
file... but WMP keeps giving me painful lessons on this topic :-/
