POV-Ray : Newsgroups : povray.binaries.animations : Poor Man's Fluid Simulation Server Time
9 Apr 2026 02:43:39 EDT (-0400)
  Poor Man's Fluid Simulation (Message 1 to 7 of 7)
Subject: Poor Man's Fluid Simulation
Date: 8 Jan 2009 01:19:17
Message: <49659ae5@news.povray.org>
I was staring at the particle demo for mechsim:
http://megapov.inetart.net/demo/particle.mpg
It occurred to me to replaces the spheres with blobs, and see if I could
create the illusion of a liquid. The end result met my (admittedly low)
expectations. :-)
Mm, liquid mercury. ;-)
William Tracy
I disapprove of what you say, but I will defend to the death your right
to say it.
     -- Evelyn Beatrice Hall, frequently mis-attributed to Voltaire
Download 'particle.mpg' (460 KB)
Subject: Re: Poor Man's Fluid Simulation
Date: 8 Jan 2009 02:10:00
Message: <web.4965a609c4fc4309ef2b9ba40@news.povray.org>
> expectations. :-)
http://en.wikipedia.org/wiki/Smoothed_particle_hydrodynamics
http://www.rchoetzlein.com/art/
This is the basis for how a lot of free surface flows are simulated.  I don't
know the details, but it seems like the coefficient of restitution should
definitely be zero (so it doesn't bounce), and surface tension should manifest
itself as a small attractive force between particles (so droplets don't go
flying off without a decent push).  A few more particles and it could actually
look convincing.  I'm not sure how mechsim handles collisions or forces, but
this could get pretty expensive if you have to do it through functions or loops
in POV-Ray.  Of course there are existing implementations too.  Is this how
Blender does it?
 - Ricky
Date: 8 Jan 2009 12:10:54
Message: <4966339e$1@news.povray.org>
Hmm. There are a few mechsim parameters I could play with ... :-)
The biggest fundamental problem with this approach is that Povray blob
objects do not conserve mass. When they approach each other, they become
much bigger than when they separate.
> in POV-Ray.
Mechsim is a patch to Povray; AFAIK the physics simulation is done in C
code. That said, this animation did take a bit over four hours to render.
Unfortunately, I have another project (not Povray related) that's using
up my CPU cycles right now, so I may not get to play with this much
more. If I did have more time, I would try to find a way to turn it into
an entry for the "relativity" round of the TC-RTC.
William Tracy
to say it.
Date: 8 Jan 2009 14:15:00
Message: <web.49664fd3c4fc4309ef2b9ba40@news.povray.org>
But at least discrete mass is conserved.  With enough particles, you wouldn't
really notice the difference.
> code.
But to do something like more complex force laws between nearest neighbors, I
suspect you'd either have to do it in POV-Ray or patch it in.  I'm not sure the
framework, as much flexibility as there is, allows you quite that much freedom.
Or if it does, it's probably O(n^2).
> more.
Always unfortunate.  My CPU cycles (my brain's, not my computer's) are in short
supply too, although I'm just kinda spinning my tires on the other project.
Perhaps time for a few more all-nighters...
 - Ricky
Date: 10 Jan 2009 15:15:21
Message: <496901d9@news.povray.org>
I cranked up the damping so that the droplets don't bounce any more.
Unfortunately, it also retards horizontal motion. :-P
As it turns out, mechsim *does* support attractive forces between
particles, but this thing renders slowly enough as is (13 hours, 39
minutes, and 49 seconds for this sequence).
That said, eliminating the bouncing does *wonders* for making this look
like an actual fluid. Good call!
William Tracy
to say it.
Download 'particle.mpg' (628 KB)
Date: 10 Jan 2009 15:45:00
Message: <web.49690861c4fc4309168446870@news.povray.org>
Looks a bit yucky, somehow - like fresh milk that has ceased to be fresh ;)
Date: 4 Oct 2009 08:05:01
Message: <web.4ac88ea6c4fc4309c7f1d3f30@news.povray.org>
> expectations. :-)
> William Tracy
> afi### [at] gmailcom -- wtr### [at] calpolyedu
> to say it.
Its Great!
