POV-Ray : Newsgroups : povray.binaries.animations : povray writes its own score... Server Time
14 Jul 2025 23:24:31 EDT (-0400)
  povray writes its own score... (Message 1 to 7 of 7)
Subject: povray writes its own score...
Date: 16 Feb 2005 23:09:14
Message: <421418ea@news.povray.org>
for a Csound-produced WAV file in perfect harmony with events happening in
pov-space in SDL.   Single hit of "Run" button in povray.
Download 'csound08001e.mpg' (465 KB)
Subject: Re: povray writes its own score...
Date: 16 Feb 2005 23:26:29
Message: <42141cf5@news.povray.org>
This is very cool!  How about a cyclic animation like this?
I've been playing with CSound for a while myself.  It's hard to decide which
one to spend more time on, looks like you've solved that problem! :)
"Greg M. Johnson" <gregj;-)565### [at] aolcom> wrote in message
news:421418ea@news.povray.org...
Date: 16 Feb 2005 23:40:17
Message: <42142031$1@news.povray.org>
Thanks.  Next project is stereo, perhaps moving to buzzing (al'a what Rune
did before), or some more realistic sound like footsteps.
"Dale Stewart" <dal### [at] coxnet> wrote in message
news:42141cf5@news.povray.org...
> which one to spend more time on, looks like you've solved that problem! :)
>> in pov-space in SDL.   Single hit of "Run" button in povray.
Date: 16 Feb 2005 23:42:19
Message: <421420ab$1@news.povray.org>
Actually, what do you think of the audio quality? There seems to be some
distortion, maybe when two balls hit at same time.    Is there something I'm
doing wrong that causes distortions-- are the freqs too close to whole
number multiples of each other, can Csound just not handle "two sounds", is
amplitude too high or what?
thanks for any advice.
Date: 17 Feb 2005 12:15:30
Message: <Xns9600B9BB9AE3Eseed7@news.povray.org>
in news:421420ab$1@news.povray.org Greg M. Johnson wrote:
> is amplitude too high or what?
This is generaly the problem, when 'adding' several sounds this quickly
happens
Ingo
Date: 17 Feb 2005 21:18:34
Message: <4215507a$1@news.povray.org>
Check for any "samples out of range" messages, and try to eliminate them by
reducing amplitudes of each sound.  If the total adds up to more amplitude
than can be represented in 16-bit audio, the samples are "clipped", which is
probably causing the buzzing sound you're talking about.  I bet that's what
is going on.  BTW, I highly recommend "The CSound Book" if you don't have it
already have it.  There are a lot of resources there that will help you out.
I am just beginning to dig into the wealth of information that is there.
news:421420ab$1@news.povray.org...
> I'm doing wrong that causes distortions-- are the freqs too close to whole
Date: 6 Mar 2005 17:54:50
Message: <422b8a3a$1@news.povray.org>
I think Virtual Sound is a better starter for Csound. The Book is a great
reference, but not something that would lead you thru the maze.
D.
news:4215507a$1@news.povray.org...
by
is
what
it
out.
whole
happening
