POV-Ray : Newsgroups : povray.binaries.animations : Walking Along a Path WIP1 Server Time
3 Jul 2026 16:46:19 EDT (-0400)
  Walking Along a Path WIP1 (Message 11 to 20 of 31)
Subject: Re: Walking Along a Path WIP1
Date: 19 Oct 2001 08:57:47
Message: <3bd0234b@news.povray.org>
"ARTis" wrote:
> "Nekar Xenos" wrote:
> > What's the problem with quadrupeds or 'polypeds'
> > for that matter? Shouldn't it just be two 'bipeds'
> > behind each other linked by the body?
> That COULD work with walking, but not with running.
Could you elaborate a bit? While it's not quite as simple as Nekar makes it
sound, I think it could be done using roughly the same technique as with
bipeds. However, I'm interested in hearing about possible problems I may
encounter.
Rune
Rune's World:    http://rsj.mobilixnet.dk (updated June 26)
Date: 19 Oct 2001 08:57:48
Message: <3bd0234c@news.povray.org>
"Rick [Kitty5]" wrote:
> very impressive :))
Thank you Rick! :)
> more!
That's easy for you to say! ;)
Rune
Date: 19 Oct 2001 09:03:52
Message: <3BD02485.47DFD831@aol.com>
A given property of this server is that whatever I'm working on in its earliest
stages, Rune has already finished and published.  ;)
Amazing work!  I was trying something like that, but was so lazy as merely to
rotate the straight-line-walking character around a huge arc, introducing minute
feet slippage that I hoped no one would notice...
Q: what kind of spline works for you now?  I resorted to linear ones a year or
so ago and your recent complaints about the one in 3.5 gives me no incentive to
"upgrade."
Date: 19 Oct 2001 17:01:13
Message: <3bd09499@news.povray.org>
> I'm working on in its earliest stages, Rune has
Well, your recent postings with your animated character inspired me to get
started on this walking business again. There have also been other times
where I've been inspired by you, for example back when you worked on that
flocking system. There's constant competition around here - I also see that
lots of people are working on particle systems now, just like I've been
doing...
> Amazing work!
Thanks! :)
> to rotate the straight-line-walking character around a huge
> arc, introducing minute feet slippage that I hoped no one
> would notice...
My approach is radically different as you probably can tell... :)
> linear ones a year or so ago and your recent complaints
> about the one in 3.5 gives me no incentive to "upgrade."
In the animation I've just posted no splines were used at all, only simple
math operations.
But later on when I need more complex motion I'll probably use the cubic
splines in POV-Ray 3.5 despite the limitations. I only hope that the bugs
will soon be fixed.
Rune
Date: 19 Oct 2001 23:33:41
Message: <3bd0f095@news.povray.org>
"Rune" <run### [at] mobilixnetdk> wrote in message
news:3bcf5a23@news.povray.org...
> Some of you may have seen my previous walk experiments with simple walk and
> run cycles. (They can be found on my website.)
> Such simple walk cycles are nice if you want a character to walk with
> constant speed along a straight line.
> If however you want it to walk with variable speed along any given path
> (such as a spline), somewhat more sophisticated techniques are necessary.
I've always thought your work is simply amazing, Rune.  Part of the reason I'm
working on my gel simulation, in fact.
I can't wait to see the finished product.
Michael
#macro M(D,J)text{ttf"cyrvetic.ttf"D 1,0translate-J}#end#macro N(E,K)#local A=
M(E,K)light_source{-z*30rgb 1projected_through{A}}#end N("Michael"<1.6,-.2,5>)
N("Johnson"<1.9.8,5>)sphere{z*9,4pigment{gradient x+y scale 10color_map{[0 rgb
x][1rgb x+y]}sine_wave}} // (c)2001 Michael D Johnson red### [at] wvadelphianet
Date: 20 Oct 2001 06:26:35
Message: <3bd1515b@news.povray.org>
Wow, thanks. :)
> Part of the reason I'm working on my gel simulation, in fact.
I get inspired by the works of lots of people around here, and I'd be happy
if anything I've made has inspired you!
I've never yet made an animation that is a finished product. Might take a
while yet before that happens...
Rune
Date: 21 Oct 2001 22:46:35
Message: <3bd3888b@news.povray.org>
> math operations.
Could you please post the code for how you represented the walk path?
Date: 22 Oct 2001 11:10:36
Message: <3bd436ec@news.povray.org>
Greg M. Johnson wrote:
> > were used at all, only simple math operations.
Don't know if that's what you mean, but I've posted a simplified version of
the whole walking technique to povray.binaries.scene-files.
In return, could you tell me what you think of it? :)
Rune
Date: 22 Oct 2001 12:55:42
Message: <3BD44F3D.4DF01C36@aol.com>
Okay, but first of all, you have a totally different "path" in the code you
posted THERE than in the anim you posted HERE, yes?
Date: 22 Oct 2001 13:25:18
Message: <3bd4567e@news.povray.org>
> "path" in the code you posted THERE than in the anim
No, in fact they're exactly the same. By "path" I mean this:
// The path to follow:
#macro WalkPath (Time)
   vrotate(Time*x,180*Time*y)
Rune
