POV-Ray : Newsgroups : povray.binaries.animations : HF seeded with flowers in a vain way [~900KB Mpg] Server Time
18 Jun 2026 09:33:46 EDT (-0400)
  HF seeded with flowers in a vain way [~900KB Mpg] (Message 1 to 10 of 13)
Subject: HF seeded with flowers in a vain way [~900KB Mpg]
Date: 12 May 2001 08:15:14
Message: <3afd2952@news.povray.org>
Seeded because it's using random numbers, vain because it uses a photo of
me.
Not something a person should render over and over again too much, a picture
of themselves.  Gets a little strange.
I was wanting to try what I have seen in a television commercial where
flowers bloom out and form the picture.  Used MegaPov 'trace' to find the
positions, not hf_height_at, hoping to do more with that I hope.  I have a
long way to go before I get there.  Figured I'd make a animation of one of
my nieces when I find a good photograph of her.
Well, have a look if you will please, just don't loop it for too long.  :-)
Bob H.
http://webpages.charter.net/omniverse/omniverse.htm
Download 'TRACEME.MPG' (669 KB)
Subject: Re: HF seeded with flowers in a vain way [~900KB Mpg]
Date: 12 May 2001 09:00:19
Message: <3afd33e3@news.povray.org>
Needs a lot more and smaller flowers. Maybe drop the pixel count in the
image map until each flower gets one color. Then each flower should grow at
a slightly different rate and a different height.
    Done really well it would leave your neice thinking your were the
ultimate hero.
Date: 12 May 2001 09:15:48
Message: <3afd3784@news.povray.org>
"Bill DeWitt" <bde### [at] cflrrcom> wrote in message
news:3afd33e3@news.povray.org...
the
at
Hmmm, possibly by using eval_pigment I could try that.  Just that I haven't
really used it to know about adding it in.  I already had done another of
these with more of a blooming flowers look, starting closed and opening; 600
is the count but it sure doesn't look it.  Also random sizes too.  The file
is about 1.5 MB though.
A varying growth rate would be good too.
I was thinking about not using the image mapped to the HF so that the
flowers do all the work, haven't tried it yet.
Bob H.
Date: 12 May 2001 09:35:51
Message: <3afd3c37@news.povray.org>
    Yeah, I would really do this if I were you (and had the patience to work
it out). Have the green flowers grow out of grass then back out in time to
see them bloom into her picture.
Date: 12 May 2001 10:38:12
Message: <3afd4ad4@news.povray.org>
I would suggest many many smaller flowers that perhaps curve upwards a
little more, and perhaps with out the HF below the flower being visible -
only on the petals
PGP Public Key
Date: 12 May 2001 17:09:08
Message: <3afda674@news.povray.org>
Spooky-cool. :)
Subject: Re: HF seeded with flowers again, file on web
Date: 12 May 2001 18:52:10
Message: <3afdbe9a@news.povray.org>
news:3afd4ad4@news.povray.org...
> only on the petals
How about a picture of someone else too?  For now I'm using a sample photo
from some scanner software.
File size is over the limit for here, being 860KB, so it is at:
http://webpages.charter.net/omniverse/flwrgirltrace.mpg
The flowers start out as buds, although so small that might not be obvious,
then they flatten out.  Needs stems added, and more height variation too
except shadows are a problem.
Bob H.
Date: 13 May 2001 04:32:30
Message: <3AFE46E8.EF7B47CE@gmx.de>
How about varying the style of the flower according to the picture too.
You could also try making the flowers a 'wave' moving across the picture.
Date: 13 May 2001 06:05:24
Message: <3afe5c64@news.povray.org>
news:3AFE46E8.EF7B47CE@gmx.de...
That would be good, yes, if I can work with eval_pigment okay anyhow.  I
started thinking about rotating the flowers around toward the light, moving
it around instead of the moving the camera, but I'd be going off on a
tangent from what I intended to start with.
I keep forgetting to how the midway point has a glitch of scale change or
camera shift or something.  Haven't tracked it down yet, the flowers stop
being placed at >0.5 (clock halfway point) or rather are placed from 0 to
<=0.5.
Wasn't concerned with that before so much but now I'm not sure what's
causing it.
Bob H.
Date: 13 May 2001 09:35:33
Message: <3afe8da5$1@news.povray.org>
This looks nice.  If I could make a couple of suggestions they would be:
- Try it without the large scale motion of the plane (or the camera,
whichever you are doing).  I find this a bit headache-inducing and it also
masks any subtleties in the flower arrangement or motion.  Also your movie
size may be reduced if you keep the camera/plane relatively still... and
this would imply more frames and more detail within the same file size.
- Play with the flowers a bit more.  Try the other suggestions concerning
waves, height, timing, etc.  I like what you have done with the green
background and the bright petals, but you can keep going.
- For bonus points you might be able to figure out how to alternate between
two images.  If a wind were to flip over each petal in turn and reveal a
different picture on the underside you would have the basis for looping your
movie.  Or maybe I am just getting carried away here :-)
Anyway it looks great so far.  Looking forward to the evolution.
"Bob H." <omn### [at] msncom> wrote in message
news:3afdbe9a@news.povray.org...
> "Rick [Kitty5]" <ric### [at] kitty5com> wrote in message
visible -
> > only on the petals
obvious,
> Bob H.
