POV-Ray : Newsgroups : povray.binaries.animations : HF seeded with flowers in a vain way [~900KB Mpg] Server Time
12 Jun 2026 08:07:38 EDT (-0400)
  HF seeded with flowers in a vain way [~900KB Mpg] (Message 4 to 13 of 13)
<<< Previous 3 Messages Goto Initial 10 Messages
Subject: Re: HF seeded with flowers in a vain way [~900KB Mpg]
Date: 12 May 2001 09:35:51
Message: <3afd3c37@news.povray.org>
"Bob H." <omn### [at] msncom> wrote :
> I was thinking about not using the image mapped to the HF so that the
> flowers do all the work, haven't tried it yet.
    Yeah, I would really do this if I were you (and had the patience to work
it out). Have the green flowers grow out of grass then back out in time to
see them bloom into her picture.
Date: 12 May 2001 10:38:12
Message: <3afd4ad4@news.povray.org>
I would suggest many many smaller flowers that perhaps curve upwards a
little more, and perhaps with out the HF below the flower being visible -
only on the petals
PGP Public Key
Date: 12 May 2001 17:09:08
Message: <3afda674@news.povray.org>
Spooky-cool. :)
Subject: Re: HF seeded with flowers again, file on web
Date: 12 May 2001 18:52:10
Message: <3afdbe9a@news.povray.org>
news:3afd4ad4@news.povray.org...
> only on the petals
How about a picture of someone else too?  For now I'm using a sample photo
from some scanner software.
File size is over the limit for here, being 860KB, so it is at:
http://webpages.charter.net/omniverse/flwrgirltrace.mpg
The flowers start out as buds, although so small that might not be obvious,
then they flatten out.  Needs stems added, and more height variation too
except shadows are a problem.
Bob H.
Date: 13 May 2001 04:32:30
Message: <3AFE46E8.EF7B47CE@gmx.de>
How about varying the style of the flower according to the picture too.
You could also try making the flowers a 'wave' moving across the picture.
Date: 13 May 2001 06:05:24
Message: <3afe5c64@news.povray.org>
news:3AFE46E8.EF7B47CE@gmx.de...
That would be good, yes, if I can work with eval_pigment okay anyhow.  I
started thinking about rotating the flowers around toward the light, moving
it around instead of the moving the camera, but I'd be going off on a
tangent from what I intended to start with.
I keep forgetting to how the midway point has a glitch of scale change or
camera shift or something.  Haven't tracked it down yet, the flowers stop
being placed at >0.5 (clock halfway point) or rather are placed from 0 to
<=0.5.
Wasn't concerned with that before so much but now I'm not sure what's
causing it.
Bob H.
Date: 13 May 2001 09:35:33
Message: <3afe8da5$1@news.povray.org>
This looks nice.  If I could make a couple of suggestions they would be:
- Try it without the large scale motion of the plane (or the camera,
whichever you are doing).  I find this a bit headache-inducing and it also
masks any subtleties in the flower arrangement or motion.  Also your movie
size may be reduced if you keep the camera/plane relatively still... and
this would imply more frames and more detail within the same file size.
- Play with the flowers a bit more.  Try the other suggestions concerning
waves, height, timing, etc.  I like what you have done with the green
background and the bright petals, but you can keep going.
- For bonus points you might be able to figure out how to alternate between
two images.  If a wind were to flip over each petal in turn and reveal a
different picture on the underside you would have the basis for looping your
movie.  Or maybe I am just getting carried away here :-)
Anyway it looks great so far.  Looking forward to the evolution.
"Bob H." <omn### [at] msncom> wrote in message
news:3afdbe9a@news.povray.org...
> "Rick [Kitty5]" <ric### [at] kitty5com> wrote in message
visible -
> > only on the petals
obvious,
> Bob H.
Date: 13 May 2001 14:56:43
Message: <3afed8eb$1@news.povray.org>
50% of the flowers with one image and 50% with another, opening in an
alternating sequence...
Yes, I am definitely getting carried away.  Sorry.
"Spock" <spo### [at] nospamcom> wrote in message
news:3afe8da5$1@news.povray.org...
between
your
Date: 21 May 2001 21:41:00
Message: <3b09c3ac$1@news.povray.org>
May I see the code for this? I'm curious about the mapping technique.
Thanks much
D.
news:3afd2952@news.povray.org...
> Seeded because it's using random numbers, vain because it uses a photo of
> me.
> Not something a person should render over and over again too much, a
> of themselves.  Gets a little strange.
> I was wanting to try what I have seen in a television commercial where
> flowers bloom out and form the picture.  Used MegaPov 'trace' to find the
> positions, not hf_height_at, hoping to do more with that I hope.  I have a
> long way to go before I get there.  Figured I'd make a animation of one of
> my nieces when I find a good photograph of her.
> Well, have a look if you will please, just don't loop it for too long.
> Bob H.
> http://webpages.charter.net/omniverse/omniverse.htm
Date: 21 May 2001 23:43:06
Message: <3b09e04a@news.povray.org>
"Dennis Milller" <dhm### [at] mediaonenet> wrote in message
news:3b09c3ac$1@news.povray.org...
I used the MegaPov 'pattern' keyword in the height field to make it from the
image.  It was from a previous scene for making a quick and easy HF which I
then replaced the color_map with image_map just to see if it would work
okay.  Hadn't done so before this and was a little surprised it did.
Since it might be of interest to more people I'll put it at p.t.s-f. group,
not that it is anything spectacular but overall might be a scene file of
some use.
Bob H.
