POV-Ray : Newsgroups : povray.beta-test : Unconfirmed bugs Server Time
13 Oct 2025 04:06:37 EDT (-0400)
  Unconfirmed bugs (Message 1 to 10 of 10)
Subject: Unconfirmed bugs
Date: 23 Dec 2001 19:18:00
Message: <y8dbQGAYPnJ8EwVc@econym.demon.co.uk>
Some of these have been hanging round in my unconfirmed list for months.
I assume that nobody wants to confirm them, so is there anybody out
there who wants to deny any of these so that I can drop them.
[Win] Can't select region that includes bottom and right edges of render
window
http://news.povray.org/3bdf8bd9@news.povray.org
Array assignment crash
http://news.povray.org/3bcc54ab$1@news.povray.org
Scrolling error
("codemax window stays the same as my desktop until I scroll")
http://news.povray.org/3be31146$1@news.povray.org
max_trace_level affects radiosity recursion_limit
(Setting max_trace_level 1 disables radiosity and max_trace_level 2 sets
recursion_limit to 1)
http://news.povray.org/3BE40295.6C3D54DE@engineer.com
Bugs with string/macro handling
http://news.povray.org/3be76148$1@news.povray.org
Philosophical objection to fog distance=0
(Fog colour is then ignored)
http://news.povray.org/3BE7E897.FEC8EF6@aol.com
Animated textures
(memory usage goes quite high)
http://news.povray.org/3bea26bf@news.povray.org
Media visible container line in front of object
(a visible whitish line appears at the edge of a transparent container
box for media)
http://news.povray.org/3bf45a3d@news.povray.org
Priority troubles
(higher priorities cause slower render)
[win gui] line with error highlighted but render finished succesfully
http://news.povray.org/va2tvt4tuitd67ik5t9ps334sbg6205bt3@4ax.com
Unsmooth smooth HF shading
(the shading of height-fields with abrupt changes is very ugly when
smooth shading is turned on)
http://news.povray.org/3c02ac19@news.povray.org
installer behaves strangely
(one would expect povray to install after pressing the "next" button and
not the "button")
http://news.povray.org/Xns916AE9B08012frankverlaathotmailc@204.213.191.2
26
POVWin 'beep on completion' error
('Beep on completion' setting doesn't beep (it does nothing))
http://news.povray.org/qtvi0u0usenm6ua8kht9jsi0p69cefi4bs@4ax.com
Photon Problems
(Rendering the file makes the image strangely bright)
http://news.povray.org/3bc4d0a9$1@news.povray.org
var_refl.pov (\scenes\textues\finishes) Beta 8
(should #include "functions.inc")
http://news.povray.org/3C0A9650.6B98925@compuserve.com
Problems starting Beta8 from Command Line
(If there's already an existing idle POV task)
http://news.povray.org/3c0abb67@news.povray.org
transform syntax
(transform {test_trans} sometimes requires {} and sometimes doesn't)
http://news.povray.org/3C09EE1B.A38DC91A@gmx.de
Win Beta 8: Message window/parse hang error?
(hangs after "Degenerate Blob" warning)
http://news.povray.org/3c0bdc77@news.povray.org
another bug I haven't seen mentioned
(Yellow band around sky_sphere equator)
http://news.povray.org/3c10ef62$1@news.povray.org
[Bug] file names with ","
http://news.povray.org/3c12cc82@news.povray.org
media & fog bug?
http://news.povray.org/3c1379e0$1@news.povray.org
Render window recovery.
http://news.povray.org/Xns917491BB6A608michaelkearnssaacons@204.213.191.
226
bug in sphere_sweep for removing parts of an object
(parameterised sphere_sweeps are very slow)
http://news.povray.org/3C1A5D47.EA38F6E5@amc.uva.nl
"No pigment type given" in blobs
(when each component has a pigment)
http://news.povray.org/3c1e6046@news.povray.org
Re: Mosaic... some clarifications
(#local A2=P(1,2,3).hf; fails)
http://news.povray.org/9n9j1uo0mdlrs4i5toupujr0pqrj4vvb8d@4ax.com
Re: hollow in light groups
http://news.povray.org/3c21172d$1@news.povray.org
Is there a problem with area light
http://news.povray.org/3c22f013@news.povray.org
Mike Williams
Gentleman of Leisure
Subject: Re: Unconfirmed bugs
Date: 23 Dec 2001 20:04:39
Message: <3C267ED6.986E0ED0@gmx.de>
As for some uncomfirmed bugs (i'll be checking some of them, just so that
someone
does it)...
Unsmooth smooth Hf shading:
The normal vectors for smooth-triangles (which is basically what a smooth
heightfield is
about) are probably not very useful when used with gaps and sudden
height-changes. I'd
expect that the algorithm for generating the smoothing-normals may have some
difficulties
with that. I've seen it too, but I think, it's nothing, than can be really
considered as a bug.If
someone has the actual algorithm for the generation of smooth-heightfields
in an understandable
format, and it would be posted, one could try and look, if it's due to some
internally unscaled
vector or whatnot.
I think this has to do with consistency. If the blob itself has no pigment,
it simply doesn't have
any. You mustn't think a blob to be like a union, which does not need a
pigment. But a
blob is a typical "pigment-me" object. This should really be no bug, but a
feature!
More comments soon to come...
Tim
Date: 23 Dec 2001 20:47:23
Message: <3c26892a@news.povray.org>
Tim Nikias <Tim### [at] gmxde> wrote:
: "No pigment type given" in blob
: I think this has to do with consistency. If the blob itself has no pigment,
: it simply doesn't have
: any. You mustn't think a blob to be like a union, which does not need a
: pigment. But a
: blob is a typical "pigment-me" object. This should really be no bug, but a
: feature!
  Well, blob is a kind of union. I don't see any problem in it behaving
like a union (with respect to pigments, that is).
Date: 24 Dec 2001 07:47:44
Message: <3c2723f0@news.povray.org>
> window
This has been fixed (several betas ago).
> Scrolling error
I could never replicate this. I suggest removing it and re-creating it only
if it's reported again.
> not the "button")
> http://news.povray.org/Xns916AE9B08012frankverlaathotmailc@204.213.191.226
I can confirm this, but it's unlikely to be fixed (as it appears to be an
installer bug). Nevertheless it can be moved to the 'confirmed' list.
This bug never existed and can be deleted.
I suggest removing this and adding it back only if it is reported again.
> http://news.povray.org/Xns917491BB6A608michaelkearnssaacons@204.213.191.226
-- Chris
Subject: Re: Unconfirmed bugs (Bug found!)
Date: 24 Dec 2001 11:51:50
Message: <3C275CD7.3ACF9F1F@gmx.de>
The following bug:
is definitely there. I've tried it using floats, 2D, 3D, 4D and 5D vectors.
All except 2D-Vectors work fine, only 2D results in crash. This (as an
educated guess) probably has something to do with the storage of
2D-Vectors and how arrays save them.
My suggestion: If possible, just use 3D-Vectors and create a macro which
transforms those into 2D for lathe etc, like:
#macro Make_2D(Vector)
 <Vector.x,Vector.y>
I'm still looking at other bugs...
Tim
Date: 27 Dec 2001 02:34:08
Message: <3c2acef0$1@news.povray.org>
> Photon Problems
Yes! Yes! Someone please confirm this! I beg you! It will only take a few
minutes!
Pleeeeeeease
- Slime
[ http://www.slimeland.com/ ]
[ http://www.slimeland.com/images/ ]
Date: 27 Dec 2001 07:08:15
Message: <3c2b0f2f$1@news.povray.org>
Slime schrieb in Nachricht <3c2acef0$1@news.povray.org>...
>> Photon Problems
I can confirm that your scene behaves in the described way, but I don't know
enough about photons to judge if that's not the expected behaviour.
But as Nathan Kopp already said that he is looking in the problem, I think
this Problem should be moved to the Known Bug list anyway.
Marc-Hendrik
Date: 31 Dec 2001 00:36:25
Message: <3c2ff959$1@news.povray.org>
Hi!
I could reproduce this one. The problem is, that codemax stores
the name of the opened files and its properties all in one registry
key, with the "," sign as delimiter.
For example:
c:\myfile.txt,52,12,22,0,8,2
So opening a file with a "," in its name and then closing POV-Ray
causes an entry to be created that looks like this:
c:\my,file,52,12,22,0,8,2
When starting POV-Ray again it reads the filename as "c:\my",
which of course doesn't exist.
The only solution to this would be storing the meta data in
seperate registry keys or checking filenames for "," on both
save and open dialog. But I guess this is not directly a POV-Ray
problem; This one should be reported to the codemax people...
Klaus.
Date: 31 Dec 2001 07:34:58
Message: <3c305b71@news.povray.org>
Mike Williams <mik### [at] nospamplease> wrote:
: "No pigment type given" in blobs
: (when each component has a pigment)
: http://news.povray.org/3c1e6046@news.povray.org
  This should be easy to confirm for anyone.
  (Of course another question is if it's really a bug, or just a little
annoyance.)
Date: 31 Dec 2001 08:47:21
Message: <3c306c69@news.povray.org>
Actually, that's all my code (codemax is much lower-level than this).
I guess I just never expected a filename with a comma.
