POV-Ray : Newsgroups : povray.beta-test : POV-Ray v3.8.0-beta 1 - Parse error using "%s" in Win10 Server Time
17 Nov 2025 09:54:19 EST (-0500)
  POV-Ray v3.8.0-beta 1 - Parse error using "%s" in Win10 (Message 1 to 10 of 36)
Subject: POV-Ray v3.8.0-beta 1 - Parse error using "%s" in Win10
Date: 25 Jul 2021 03:45:46
Message: <60fd16aa$1@news.povray.org>
I am currently testing a macro by jr.: tabulated.inc. In one of his demo
scenes he uses the following line:
#declare seed_ = val(datetime(now,"%s"));
Using Windows10, and POV-Ray v3.8.0-beta 1, I get the following error:
Parse Error: Invalid formatting code in format string, or resulting
string too long.
I contacted jr. about this and he answered the following:
"POV-Ray's documentation says the "..optional STRING parameter should
conform to the same formatting as that of the strftime() C function."
and (lowercase) "%s" is documented as described and used.  I assume
that the Windows 'strftime()' does not provide that option?  else it
would be a POV-Ray on Windows bug, I guess."
I mention this error also on behalf of jr. I am not sure about which
system jr. uses, obviously not Windows, but he will jump in if you need
to know.
Subject: Re: POV-Ray v3.8.0-beta 1 - Parse error using "%s" in Win10
Date: 25 Jul 2021 04:35:00
Message: <web.60fd21d7e398ba995e0fed26cde94f1@news.povray.org>
hi,
(thanks, could not post this as I have no MS Windows machine)
just to confirm, this works on all Linux systems I have access to, incl a Debian
VM with (oldest) POV-Ray-3.7.0.8.
regards, jr.
Date: 25 Jul 2021 06:18:07
Message: <60fd3a5f$1@news.povray.org>
Ok on Mac.
#declare DateString = datetime(now,"%s");
#debug concat("DateString     = ",DateString,"\n")
#declare DateNum = val(datetime(now,"%s"));
#debug concat("DateNum        = ",str(DateNum,0,0),"\n")
#declare LongDateString = datetime(now,"%A %e %B %Y %H:%M:%S");
#debug concat("LongDateString = ", LongDateString,"\n")
Result :
DateString     = 1627201022
DateNum        = 1627201022
LongDateString = Sunday 25 July 2021 10:17:02
Kurtz le pirate
Compagnie de la Banquise
Date: 25 Jul 2021 08:44:15
Message: <60fd5c9f$1@news.povray.org>
Am 25.07.2021 um 09:45 schrieb Thomas de Groot:
 From the Linux man page on die.net (https://linux.die.net/man/3/strftime):
%s
The number of seconds since the Epoch, 1970-01-01 00:00:00 +0000 (UTC).
(TZ)
For information on what "(TZ)" means, see further on that page:
Conforming To
SVr4, C89, C99. There are strict inclusions between the set of
conversions given in ANSI C (unmarked), those given in the Single UNIX
Specification (marked SU), those given in Olson's timezone package
(marked TZ), and those given in glibc (marked GNU), except that %+ is
not supported in glibc2. On the other hand glibc2 has several more
extensions. POSIX.1 only refers to ANSI C; POSIX.2 describes under
date(1) several extensions that could apply to strftime() as well. The
%F conversion is in C99 and POSIX.1-2001.
For a list of values officially supported by standard C/C++, see
https://en.cppreference.com/w/c/chrono/strftime.
TL;DR:
"%s" is a non-standard extension to the `strftime` format, that is not
universally supported.
Also note that in POV-Ray, `now` already is a numeric value (albeit in
days, and with 0 corresponding to 2000-1-1, 00:00:00 am UTC). It should
be trivial to convert to a Unix timestamp without the use of `datetime`
and `val`, using simple scalar math.
Date: 25 Jul 2021 09:30:00
Message: <web.60fd670de398ba995e0fed26cde94f1@news.povray.org>
hi,
> Conforming To
> SVr4, C89, C99. ...
> TL;DR:
do you have a reference for the "non-standard", please?  cannot see a mention on
the pages I looked at, including
<https://man7.org/linux/man-pages/man3/strftime.3.html>.
regards, jr.
Date: 25 Jul 2021 17:23:38
Message: <60fdd65a$1@news.povray.org>
Am 25.07.2021 um 15:28 schrieb jr:
(1)
The official reference for the fact that it's non-standard would be the
official documentation of the C and C++ standards: ISO/IEC 9899 and
ISO/IEC 14882, respectively, in whatever revision of the language you're
looking at. Of those, the C documentation is the more interesting, as
the C++ standard only defines it by reference.
The non-standard status of "%s" is documented in ISO-IEC 9899 by
absence: It is not mentioned, therefore it is non-standard.
I do not have access to an authoritative copy of any revision of ISO/IEC
9899 aside a PDF copy of good old ANS/ISO 9899-1990, but there the
relevant information would be found on page 174, in section 7.12.3.5,
"The strftime function"
For ISO/IEC 9899:1999, that forms the main basis for C++, I only have
access to drafts (access to authoritative ISO/IEC standard documents
requires a license fee). In a PDF titled "ISO/IEC Committee Draft - May
6, 2005 ISO/IEC 9899:TCs" (which to the best of my knowledge differs
from ISO/IEC 9899:1999 only in "bugfixes"), the relevant information
would be found on page 7.23.3.5, "Tthe strftime function".
In the official ANSI PDF release of ISO/IEC 14882:2011(E), the relevant
information can be found on page 619, section 20.11.8 [date.time] "Date
and time functions", but it only references the C standard. (The
footnote explicitly listing conversion specifies from C seems to be
intended to only explicitly affirm that C++11 supports those specifiers
added in C99, rather than the smaller set in C89.)
(2)
The page I've linked to, "cppreference.com", is dedicated to faithfully
documenting the official standard in a more accessible format, and has
proven quite reliable in being true to the standards and their versions.
The page you're citing documents what is implemented in Linux' glibc. It
is not authoritative about what to expect from `strftime` on a 100% pure
standard-conformant system.
(3)
The page you liked to, under "%s", also lists effectively the same
information as the other man page source I cited:
%s     The number of seconds since the Epoch, 1970-01-01 00:00:00
               +0000 (UTC). (TZ) (Calculated from mktime(tm).)
Again, note the "(TZ)" here. In the section titled "CONFORMING TO", it
also explains what this "(TZ)" marker means, again just like the man
        UNIX Specification (marked SU), those given in Olson's timezone
        package (marked TZ), and those given in glibc (marked GNU),
        except that %+ is not supported in glibc2.  On the other hand
        glibc2 has several more extensions.  POSIX.1 only refers to ANSI
        C; POSIX.2 describes under date(1) several extensions that could
        apply to strftime() as well.  The %F conversion is in C99 and
        POSIX.1-2001.
In other words:
- If it is marked "(GNU)", it is supported by glibc.
- If it is marked "(TZ)", it is supported by glibc and "Olson's timezone
package"
- If it is marked "(SU)", it is supported by glibc and "Olson's timezone
package", and standardized for Unix in the Single UNIX Specification.
- If it is unmarked, it is supported by glibc and "Olson's timezone
package", and standardized for Unix in the Single UNIX Specification and
ANSI C (which in this case appears to mean ANSI-standard C in general,
not specifically C89 as would usually be the case. ).
(4)
It may be worth noting that Linux' strftime is _not_ in violation of the
C (and, by extension, C++) standard, which explicitly states: "If a
conversion specilier is not one of the above. the behavior is
undefined." In other words, "%s" may crash the program, produce "F***
you" as output, or convert the time to a decimal rendition of the number
of seconds between the very start of 1970 and the specified time. Any of
these behaviors are acceptable per the C/C++ standard.
Date: 25 Jul 2021 17:27:37
Message: <60fdd749$1@news.povray.org>
Am 25.07.2021 um 23:23 schrieb clipka:
That was supposed to read "... the main basis for C++11". Which is the
minimum language revision required to build POV-Ray v3.8.
(In POV-Ray v3.7, which requires C++99 as the minimum language version,
the earlier C89 standard would apply, which is even more limited.)
Date: 25 Jul 2021 18:00:58
Message: <60fddf1a$1@news.povray.org>
It might be worth weaving the following information into the
documentation of our "datetime" function:
Which codes are supported depends on the platform POV-Ray is compiled
an/or running on.
In POV-Ray v3.7, the following codes can be expexted to work reliably:
a,A,b,B,c,d,H,I,j,m,M,p,S,U,w,W,x,X,y,Y,Z,%
In POV-Ray v3.8, the following additional codes can be expexted to work
reliably:
a,A,b,B,c,C,d,D,e,F,g,G,h,H,I,j,m,M,n,p,r,R,S,t,T,u,U,V,w,W,x,X,y,Y,z,Z,%
(Side note: The C99/C++11 standards define additional two-letter codes
starting with E or O; while those should also work in POV-Ray v3.8,
their result _will_ differ between systems, depending on the language
settings of the computer.
(Also, note to self and fellow developers: It may be worth adding a
check in POV-Ray itself, to verify whether the formatting string
submitted is actually portable across platforms, and warn if it isn't.)
Date: 26 Jul 2021 04:40:00
Message: <web.60fe73a3e398ba995e0fed26cde94f1@news.povray.org>
hi,
I thank you for the (detailed) clarification re status of "%s" (and yr time).  I
dug up a PDF (N1256, Committee Draft 7.9.2007) and was shocked (sort of) to find
no mention of "%s".
and also a big thank you for writing "..in POV-Ray, `now` already is a numeric
value..", this has cleared up a complete misunderstanding.  the documentation
says 'now' is a "keyword" and only illustrates its use in a 'datetime()' call.
I had not realised that 'now' can be used outside 'datetime()'.  :-)  so the
demo scene TdG mentioned simply needs a (fairly) reliable unique seed for the
RNG, whenever it's rendered.  made a couple of quick tests with 'now', and am
thinking of using something like the following to replace the
'datetime(now,"%s")', and would appreciate comment(s):
#declare seed_ = mod((now-int(now))*1e16,1e9);
and perhaps improve description of 'now'.
regards, jr.
Date: 26 Jul 2021 10:54:21
Message: <60fecc9d$1@news.povray.org>
The 'now' keyword is documented in the float built-in variables section
of the 3.8 reference manual (as it should be), but unlike most of the
other variables in that section, the word 'now' is not its own header,
so it is easy to miss.  (The same is true of the 'version' keyword.)
The documentation of 'datetime' could use a cross reference to the 'now'
description.
