POV-Ray : Newsgroups : povray.beta-test : v3.7.1 beta 5-- light_group problem? Server Time
25 Apr 2026 06:53:13 EDT (-0400)
  v3.7.1 beta 5-- light_group problem? (Message 1 to 10 of 24)
Subject: v3.7.1 beta 5-- light_group problem?
Date: 30 Apr 2017 11:10:00
Message: <web.5905fcf6ecd03e1c883fb31c0@news.povray.org>
(using Windows 7 64-bit)
I haven't used a light_group in a long time, so I can't remember exactly what
its behavior was in v3.62, but I don't think it's working correctly in the beta.
I've included a test scene below.
Although the light_group's light does not appear on objects outside the group
(which is correct), it's still casting shadows from those objects, onto the
object in the light_group. Is that proper behavior? I don't recall a similar
problem in v3.62 (although I could be wrong.) The included documentation doesn't
mention shadow behavior (except as relates to scattering media.)
Also, the light's looks_like object (yellow sphere) is showing lighting effects
from the extra 'global light', even with 'global_lights off' in the light_group
(although there's no shadow from that sphere, as far as I can tell.) I don't
know if that is correct behavior or not.
#version 3.71;
global_settings{assumed_gamma 1.0 max_trace_level 5}
  perspective
  location  <0, 0, -3.5>
  look_at   <0, 0,  0>
  angle 35
background {rgb .2}
// the extra 'global light'-- up and to the left
light_source {
  0*x
  color rgb <1,1,1>
  translate <-30, 30, -10>
light_group{
light_source {
  0*x
  color rgb 80000*<1,.5,.5>
  fade_power 1.5
  fade_distance .001
  looks_like{
     sphere{0,.03 texture{pigment{rgb <1,.8,0>}finish{ambient 0 diffuse .9}}}
  translate <.09, .2, -.06>
plane{y,-.61
    texture{
         pigment{
              cells
              scale .5
              color_map{
                   [0 rgb .5]
                   [1 rgb 1]
         finish{
              ambient 0
              diffuse .4
  // global_lights on
// tall thin box
#declare TALL_BOX =
box{<-.02,-1,-.02>, <.02,1,.02>
    texture{
        pigment{rgb <.4,1,.4>}
        rotate 30*y
object{TALL_BOX}
object{TALL_BOX
rotate 80*x
translate <-.3,-.3,.3>
Subject: Re: v3.7.1 beta 5-- light_group problem?
Date: 30 Apr 2017 12:15:32
Message: <59060da4$1@news.povray.org>
This is the correct and expected behaviour and did not change since
light_group have been introduced.
Can't tell for that part, but it brobably did not change.
> #version 3.71;
> camera {
>    perspective
>    look_at   <0, 0,  0>
>    angle 35
> background {rgb .2}
> light_source {
>    0*x
>    color rgb <1,1,1>
> light_group{
> light_source {
>    0*x
>    fade_power 1.5
>    fade_distance .001
>    looks_like{
> plane{y,-.61
>      texture{
>           pigment{
>                cells
>                scale .5
>                color_map{
>                     [0 rgb .5]
>                     [1 rgb 1]
>           finish{
>                ambient 0
>                diffuse .4
>    // global_lights on
> // tall thin box
> #declare TALL_BOX =
>      texture{
>          rotate 30*y
> object{TALL_BOX}
> object{TALL_BOX
> rotate 80*x
Date: 30 Apr 2017 19:45:00
Message: <web.590675adcb5fff94883fb31c0@news.povray.org>
I'm having trouble understanding the logic of this; but maybe it will become
clearer to me, as I continue to think about it. ;-)
Long ago, I wrote and archived several light_group 'test scenes' (with lots of
notes to myself about its behavior), but I can't find the files.  :-(
Date: 1 May 2017 02:57:44
Message: <5906dc68$1@news.povray.org>
I agree with you. Intuitively I would say that this shadow behaviour is
not correct. It annihilates imho one of the fundamental reasons to use
light_group in the first place.
Date: 1 May 2017 03:45:01
Message: <web.5906e680cb5fff94a3977ae70@news.povray.org>
You need to consider the purpose of light groups: They exist to allow additional
local lights for objects, a technique that is frequently used in computer
animations to help make certain objects appear lit "better" - after all, there
is no physical equivalent of light groups in the real world.
What you are looking for is something like "shadow groups", though I suppose you
might want to rethink what you actually want to render.
Date: 1 May 2017 07:20:47
Message: <59071a0f$1@news.povray.org>
As for me, that clarifies a lot indeed. Use a bit different than I
expected. I have used light_group is a somewhat different context with a
reddish sundown landscape and a 'midday' lighted moon. I think I got
some unwanted artefacts but I resolved them with no_shadow and
no_reflection.
Date: 1 May 2017 13:50:06
Message: <web.5907752acb5fff94883fb31c0@news.povray.org>
That's basically what the documentation says, although the behavior of shadows
vis-a-vis a light_group isn't discussed there-- which seems like an important
topic, as shadow behavior may be 'unexpected', in an intuitive sense. (Well, at
least for me-- and maybe Thomas as well.) My immediate intuition when reading
the docs is basically this: that a light_group should *only* light the objects
in the group, AND *only* those objects should cast shadows from that light.
Obviously, it doesn't work according to my intuition...  ;-) I admit that I
haven't completely thought through the ramifications of my idea; there may
indeed be some logical conundrums with it. But its present behavior seems like a
conundrum (to me.)
> suppose you might want to rethink what you actually want to render.
That's very possible (and I could probably find a work-around to the scene
problem I encountered, using no_image and/or no_shadow as Thomas mentioned.) My
current scene-- which prompted me to post about this-- is an animation of an
expanding  'explosion' on the top of a tower (like the old A-bomb tests.) I
wanted a VERY bright fading light to flare on the ground (and only there), from
a position at the center of the explosion, so I made a light_group with the
ground-- but found that the explosion sphere and the tower were casting unwanted
harsh shadows... which I didn't expect (based on my... intuition...)
I think my past use of a light_group was always with a carefully-positioned
spotlight, so I probably never noticed the unexpected shadow behavior from other
scene objects. (Actually, I do recall once making a scene where I wanted a light
*underneath* the ground, to artifically light up some above-ground objects-- and
I did have to add no_shadow to the ground. But I thought that was because I had
made some kind of dumb mistake in my complex code.)
Date: 3 May 2017 14:40:27
Message: <590a241b$1@news.povray.org>
Am 30.04.2017 um 18:15 schrieb Alain:
Kenneth and Tomas' posts are clear evidence (nay, proof) that it is
/not/ "expected behaviour" - or at least not universally so.
My personal guess is that light groups were originally implemented for a
use case where shadowing objects or media were a non-issue, and thus no
thought was given in that direction whatsoever. And that when the issue
first arose, light groups were well-established already, so that the
developers were reluctant to change the implementation, out of fear of
breaking existing scenes.
Date: 3 May 2017 14:46:51
Message: <590a259b$1@news.povray.org>
Am 30.04.2017 um 17:04 schrieb Kenneth:
I haven't examined the issue myself, but I wouldn't be surprised if
`looks_like` objects would always be hooked up into the global group
(again presumably because no thought had been given about the
interaction of these two features).
A workaround would be to replace the `looks_like` object with a
corresponding "regular" object in the same light group, with
`no_shadow`, `no_radiosity` and whatever other flags the `looks_like`
feature automatically sets.
Date: 3 May 2017 14:47:39
Message: <590a25cb$1@news.povray.org>
Am 03.05.2017 um 20:40 schrieb clipka:
(Sorry Tom, stole an "h" from you there...)
