POV-Ray : Newsgroups : povray.beta-test : Radiation flickering Server Time
12 Jun 2024 18:12:31 EDT (-0400)
  Radiation flickering (Message 1 to 10 of 12)
Subject: Radiation flickering
Date: 5 Sep 2013 10:00:01
Message: <web.52288dba8ba81a68d27df5500@news.povray.org>
For a project we're using povray 3.7 rc6 to render a scene. For this scene (a
scene with some houses, road & cars) we enabled radiosity in order to get more
realistic images. However, when enabling radiosity, we observe a flickering
effect of lights, a sort of 'disco' effect. Do you have any idea where this
effect comes from and how to reduce this effect?
Regards Jelle
Subject: Re: Radiation flickering
Date: 5 Sep 2013 14:40:50
Message: <5228d032$1@news.povray.org>
Am 05.09.2013 15:57, schrieb Jelle Duives:
Radiosity isn't perfectly accurate, and may over- or underestimate the
illumination in any given region of the image; if radiosity samples are
not carried over from one frame to the next (which is the default), this
may lead to visible random fluctuations in the brightness.
If you don't have any moving elements in your scene (i.e. the animation
is just a fly-through), this can be avoided by saving and restoring the
radiosity samples from frame to frame.
If you have stuff moving around, currently the only solution to the
problem is to crank up the radiosity quality, to make the fluctuations
as "shallow" as possible.
Date: 5 Sep 2013 21:10:01
Message: <web.52292b2e1a834e7711b13fda0@news.povray.org>
> Regards Jelle
When rad is calculated each time and each scene is differently, even slightly,
it may come up with different results which causes the flickering effect.
The best way to handle this is to run a scene where you have a maximum view of
the entire scene (can even try to use some well placed mirrors to help) and run
with high radiosity settings and save the rad file.  You now should be able to
run the scene from your original view but load the rad file instead of
recalculating.
This should work better as the way rad is calculated and determined is dependent
upon the view when, but when it is save and reloaded, the view no longer matters
as it is mapped to the scene the same every time regardless of the new camera
view.  The only thing is areas that were hidden or occluded from the original
view may not get full rad effects which is why you want a setup that lets you
see as much of your scene as possible at one time.
I did a trick scene a long time ago (can't find it now) where I ran a rad scan
with a bunch of coloured balls, but then loaded the rad file with white balls
for an interesting colour cast effect.
-tgq
Date: 6 Sep 2013 07:35:01
Message: <web.5229bcd01a834e77d27df5500@news.povray.org>
> > Regards Jelle
> recalculating.
> -tgq
First of all thanks for your quick replies! I think that for our daylight
scenarios reusing the radiosity samples is a really good solution, we didn't
think of that yet. However, for our night scenes we have moving cars with lights
mounted 'on' them. In other words, we do not only have moving objects, but
moving lights as well.
Can we also reuse the radiosity samples for this type of scenarios? If not, is
there maybe another solution we can use?
Regards Jelle
Date: 6 Sep 2013 20:43:25
Message: <522a76ad@news.povray.org>
Jelle Duives wrote:
> If not, is there maybe another solution we can use?
The other solution is using higher quality radio settings,
and bringing a lot of patience (or computing power).
Date: 9 Sep 2013 01:15:02
Message: <522d5956@news.povray.org>
> Regards Jelle
When you have moving parts, reusing radiosity samples will result in
highly inacurate results. With moving lights, you'll be left with areas
retaining the illumination from the first frame in the last frame.
Some things that you may try:
Use a smaller pretrace_end value. It default to 0.04. Try something like
0.01 or 0.005.
Use a smaler value for low_error_factor. The default is 0.5. Try
something around 0.2.
Use "+hr" on the command line to turn on the "high reproductibility" mode.
Increase the count value.
Take advantage of the importance feature: Set a relatively low default
importance, but have critical objects with "radiosity{importance 1}" to
use the maximum sampling for them. In your case, you should probably set
the road surface and vehicles with a higher importance than the rest.
Sample of using importance:
#default{radiosity{ilportance 0.1}}
global_settings{radiosity{samples 1000}}
object{Some_Object{radiosity{importance 1}}
In this case, most of the scene will get about 100 radiosity samples,
but "Some_object" will be sampled at 1000 samples. This can greatly
reduce the trace time.
Date: 9 Sep 2013 10:12:42
Message: <522dd75a@news.povray.org>
Am 09.09.2013 07:15, schrieb Alain:
Unfortunately that doesn't help with animations.
Date: 10 Sep 2013 21:38:57
Message: <522fc9b1$1@news.povray.org>
>> mode.
To bad. It would be nice if it did.
Date: 11 Sep 2013 02:20:37
Message: <52300bb5$1@news.povray.org>
Just a suggestion: flickering is high frequency, what about computing
(and saving) radiosity samples for "key" frames (such as every second or
something of that range for eye detection) and reusing the saved
radiosity on the next frames, until the next key frames.
On key frame, the radiosity is "exact" and it is stable for a few frames.
Just because nobody complains does not mean all parachutes are perfect.
Date: 14 Sep 2013 12:54:19
Message: <op.w3euknf3ufxv4h@xena>
On Wed, 11 Sep 2013 08:20:36 +0200, Le_Forgeron <lef### [at] freefr> wro
te:
as
or
es.
It would be nice if some kind of motion-blurr-like method could be used
only on radiosity to smooth it out.
-Nekar Xenos-
