POV-Ray : Newsgroups : povray.beta-test : Segmentation fault with animation of large image Server Time
26 Oct 2025 05:45:23 EDT (-0400)
  Segmentation fault with animation of large image (Message 1 to 10 of 17)
Subject: Segmentation fault with animation of large image
Date: 28 Jan 2012 13:35:01
Message: <web.4f243f3ef56eaf9a78641e0c0@news.povray.org>
There are actually two issues here.  The first is that the output display does
not work if the image is more than 1270 pixels wide or more than 720 pixels
high.  The output image file is correctly rendered, but the display remains
blank.  This occurs in openSUSE Linux 12.1, but not in Windows 7.
The second is that if the image is more than 1270 pixels wide or more than 720
pixels high, animation fails with a segmentation fault during the second
rendered frame.  This happens after parsing is complete and the .pov-state file
is created.  The last message line is the "[Rendering...]" line.
On one occasion, POV-Ray hung, and I had to ctrl-Z kill -9 out of it.
On another occasion, instead of the segmentation fault, I got the message:
   povray: xcb_io.c:140: dequeue_pending_request: Assertion `req ==
dpy->xcb->pending_requests' failed.
   Aborted
There is no crash when -D is used.
I have not run an animation this large in Windows, so I don't know if it's a
problem there.
Neither problem occurs in POV-Ray 3.6.1.
I used the following source code:
__________________________________________
light_source { <-1, 1, -1> * 1000, rgb 1 }
sphere { 2.5 * z, 1 pigment { red 1 } }
POV-Ray version: 3.7RC3
Operating system: openSUSE Linux 12.1
Hardware: HP Pavilion dv5030us Notebook PC (32 bits)
RAM: 1GB
Displays: 1280x800 built-in panel; 1680x1050 HP w2007 external monitor
Subject: Re: Segmentation fault with animation of large image
Date: 28 Jan 2012 13:54:15
Message: <4f244457$1@news.povray.org>
Le 28/01/2012 19:32, Cousin Ricky nous fit lire :
I would challenge that, as my default render size used to be 1025 x
1025. But on Ubuntu.
What are your version of SDL library/ies ?
But to be fair, It might be an issue in 3.7RC3 and not anymore.
(also, see further)
I can confirm that one, sort of: the windows being bigger than the
screen (including border), the animation segfaults at frame 2
If it can fit at 1:1, no problem.
If it cannot fit at 1:1, frame 2 get a segfault.
 povray +H2000 +W2000 +KI0 +KF1 +KFF10 +KFI0
Yep, will attach some debugger on that code to find it.
Thanks for report, can you open an issue in bugs.povray.org, please ?
> problem there.
Well, if someone can try that on Windows (animation, picture size bigger
in any dimensions, including both, than the available display)
> RAM: 1GB
Hint... might be related to your display setting (1280x800...
1270x720... guess what are borders & decorations sizes... )
Date: 28 Jan 2012 14:54:52
Message: <4f24528c$1@news.povray.org>
Le 28/01/2012 19:54, Le_Forgeron nous fit lire :
Well, issue is with m_PxCount... in unix/disp_sdl.cpp,
The UnixSDLDisplay::SetPixelScaled() function has it EMPTY on the second
frame of the animation.
That does not help to merge the new pixel in the mapped picture.
Now, to find where that nice vector get cleared... when the picture is
scaled.
Date: 28 Jan 2012 15:41:05
Message: <4f245d61$1@news.povray.org>
Should now be fixed with #5604. It was not a cleared vector, but a not
created one on data's transfer of object.
Date: 28 Jan 2012 15:57:37
Message: <4f246141$1@news.povray.org>
hmmm ... ~smp/unix/disp_sdl.cpp shows no difference with the version I
have locally, so I couldn't do a diff to see what you'd changed. Wanted
to pull the fix and do a little sanity check, but was unable to proceed.
Date: 28 Jan 2012 16:00:26
Message: <4f2461ea$1@news.povray.org>
BTW: I have version #19 of the above mentioned file.
Date: 28 Jan 2012 16:03:26
Message: <4f24629e$1@news.povray.org>
It probably needs to be merged to trunk. I'll take a look at it later
today.
-- Chris
Date: 28 Jan 2012 16:09:19
Message: <4f2463ff@news.povray.org>
>> >  problem there.
Why would a crash in Unix-specific code have any impact on Windows-specific
code?
     Thorsten
Date: 28 Jan 2012 16:10:10
Message: <4f246432$1@news.povray.org>
> today.
> -- Chris
operator error I guess ... my p4 client hung and it must have pulled the
file anyways, because when I came back at it ... said no files updated.
After some more digging version #19 is indeed what I want and have.
Date: 29 Jan 2012 06:11:36
Message: <4f252968$1@news.povray.org>
Le 28/01/2012 22:09, Thorsten Froehlich nous fit lire :
>>> it's a
>>> >  problem there.
> Windows-specific code?
Not directly, but a similar error might have been copied&pasted... or
served as a common design (by same authors or like, so it was an error
on unix, it might also on others.. I just do not know their ways of
handling the scaling (if any) of large pictures)
Better check while at it than sorry in 8 months.
