POV-Ray : Newsgroups : povray.beta-test : Alpha channel with background color Server Time
25 Apr 2026 19:58:03 EDT (-0400)
  Alpha channel with background color (Message 6 to 15 of 25)
<<< Previous 5 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Alpha channel with background color
Date: 31 Dec 2011 02:56:36
Message: <4efec034$1@news.povray.org>
On 31-12-2011 5:30, Cousin Ricky wrote:
> Alain<aze### [at] qwertyorg>  wrote:
>> Effectively, if I remember correctly, the background now need a filter
>> or transmit value to allow alpha transparency.
> Thanks, that works.  I guess it hasn't made it into the documentation yet.
It seems not indeed, or not clear enough. In section 3.1.2.4.1 Output
File Type, the relevant paragraph reads (text put between * * by me):
[quote]
The alpha channel stores a transparency value for each pixel, just like
there is also stored a value for red green and blue light for each
pixel. In POV-Ray, when the alpha channel is turned on, *all areas of
the image where the background is partly or fully visible will be partly
or fully transparent*. Refractions of the background will also be
transparent, but not reflections. Also anti-aliasing is taken into account
[/quote]
In highlighted phrase filter and transmit should be mentioned explicitly.
Date: 31 Dec 2011 08:25:01
Message: <web.4eff0cd43d3e0ec485de7b680@news.povray.org>
Except that anti-aliasing doesn't appear to work properly.
Date: 31 Dec 2011 08:25:50
Message: <4eff0d5e$1@news.povray.org>
> [quote]
> [/quote]
> Thomas
After re-reading the section, I guess a little clarification wouldn't
hurt. The highlighted section you mentioned has been changed ... also
found the same "Note" here:
http://wiki.povray.org/content/Documentation:Reference_Section_5#Using_the_Alpha_Channel
and changed it there too! Thanks everyone.
Date: 31 Dec 2011 08:30:01
Message: <web.4eff0d8e3d3e0ec485de7b680@news.povray.org>
Yes, that would be helpful.  Thanks.
Date: 31 Dec 2011 09:03:07
Message: <4eff161b@news.povray.org>
look at the bottom of this section:
http://wiki.povray.org/content/Documentation:Reference_Section_1.3#Anti-Aliasing_Options
perhaps the problem you are seeing can be mitigated by specifying +AG1.0
which effectively gives neutral behavior ... 2.5 is the default. Haven't
tried this ... maybe for a shot ;-)
Date: 31 Dec 2011 09:07:02
Message: <4eff1706$1@news.povray.org>
LOL ... should be "maybe worth a shot" ... still sounds funny ;-)
Date: 13 Jan 2012 16:58:19
Message: <4f10a8fb$1@news.povray.org>
Am 31.12.2011 14:23, schrieb Cousin Ricky:
Can you be more specific?
Date: 15 Jan 2012 20:25:00
Message: <web.4f137b473d3e0ec485de7b680@news.povray.org>
See post in povray.binaries.images.
Date: 16 Jan 2012 09:25:08
Message: <4f143344$1@news.povray.org>
Am 16.01.2012 02:20, schrieb Cousin Ricky:
Ah, yes - this actually has nothing to do with anti-aliasing, but is a
side effect of various changes to the alpha channel handling introduced
with 3.7.beta.38, which apparently break down in case the resulting
transparency is exactly 1.0 (as opposed to e.g. 0.9999), and generally
don't play nice with colored yet transparent background colors.
I guess it's back to the drawing board for me.
Date: 13 Feb 2012 18:45:01
Message: <web.4f399f873d3e0ec478641e0c0@news.povray.org>
Workaround:
sphere
{  0, HUGE_RADIUS
   pigment { rgb BACKGROUND_COLOR }
   finish { ambient 0 diffuse 0 emission 1 }
   no_image
