POV-Ray : Newsgroups : povray.beta-test : less saturation with more cores? Server Time
15 Jan 2026 11:09:02 EST (-0500)
  less saturation with more cores? (Message 1 to 3 of 3)
Subject: less saturation with more cores?
Date: 16 Sep 2011 19:50:01
Message: <web.4e73e005a1ac5613fed32f960@news.povray.org>
I observed an oddity I have no explanation for. I run RC3 unofficial on 3 Macs.
Two of them have two cores, and behave identical. The third has 8 cores, and
files with mesh objects result in clearly less saturated images. I have
double-checked that I am using the same files with the same settings, and I am
comparing the generated images, not just the gamma-adjusted previews. I'll be
happy to provide a scene file together with the images I get. The only not too
common feature I use is interior_texture. Please advise.
Matthias
Subject: Re: less saturation with more cores?
Date: 16 Sep 2011 20:39:13
Message: <4e73ec31$1@news.povray.org>
Am 17.09.2011 01:47, schrieb Matthias:
Some things you could try:
- On the 8-core machine, use option +WT2 in the INI file or on the
command line; this will reduce the numer of render threads to 2. If this
changes behaviour to match the 2-core machines, then there's something
fishy indeed.
- On all machines, use an INI file with the following settings
explicitly specified:
   File_Gamma=sRGB
   Display_Gamma=sRGB
   +fn
If this makes all machines behave identically, then there's probably
something different with your povray.ini file on the 8-core machine.
Date: 16 Sep 2011 21:50:01
Message: <web.4e73fbcc7d142462fed32f960@news.povray.org>
> fishy indeed.
>    File_Gamma=sRGB
>    Display_Gamma=sRGB
>    +fn
Thanks for the quick response. This pointed me the right way.
It looks like as if on my more saturated
systems the display gamma defaults to 2.2, while on the less saturated one it
defaults to 0. I am not sure why that happened, but it's easy to fix for me now.
Thanks!
Matthias
