POV-Ray : Newsgroups : povray.beta-test : Bright rim in clipped CSG of media objects Server Time
15 Jan 2026 11:09:02 EST (-0500)
  Bright rim in clipped CSG of media objects (Message 1 to 7 of 7)
Subject: Bright rim in clipped CSG of media objects
Date: 4 Jul 2011 18:05:00
Message: <web.4e1238bd842dfa28326f286b0@news.povray.org>
Hi
Can anybody tell me why I get a bright rim when I clip this CSG difference ?
Thanks for your help !
#version 3.7;
#include "math.inc"
global_settings { max_trace_level 256 assumed_gamma 1.0 }
    angle 1.25
    location <0, -50, -1000>
    look_at <0,10,0>
object { difference { sphere { 0, 15.01  }
                      sphere { 0, 15.0 }
         clipped_by { cone { 0, 0.0, <0,50,0>, 50*tand(45) } }
         pigment { rgbt 1 }
         hollow
         interior { media { emission 0.3*White } }
Subject: Re: Bright rim in clipped CSG of media objects
Date: 5 Jul 2011 00:12:47
Message: <4e128f3f@news.povray.org>
> Hi
>                        sphere { 0, 15.0 }
>           clipped_by { cone { 0, 0.0,<0,50,0>, 50*tand(45) } }
>           pigment { rgbt 1 }
>           hollow
This object is used as a container for your media.
This object is NOT fully closed: clipped leaves the clipped part open.
You hit the first surface, you are now considered inside the object. The
next surface encountered is the iner surface of the oposite side. The
third surface is the outer surface. There is NO fourth surface, leading
to an "infinite" path through your media.
Solution: DO NOT use clipped_by.
Change your object as follow:
                       sphere { 0, 15.0 }// Makes your shell
          //clipped_by { cone { 0, 0.0, <0,50,0>, 50*tand(45) } }
          cone { 0, 0.0, <0,50,0>, 50*tand(45) inverse}
// removes the part outside the cone and properly close the edge of the
shell.
          pigment { rgbt 1 }
          hollow
Date: 5 Jul 2011 03:05:01
Message: <web.4e12b6712a835bfeb15d97f60@news.povray.org>
Alain <aze### [at] qwertyorg> wrote:
> > Hi
> >                        sphere { 0, 15.0 }
> >           pigment { rgbt 1 }
> >           hollow
> shell.
>           pigment { rgbt 1 }
>           hollow
> Alain
Sorry for asking such a stupid question ! Your reply is perfect,
and the explanation on the virtual infinite path perfectly clear.
And, as usual : "you never read deeply enough the manual" !
Thanks a lot !
And, by the way : is there some reason for the clipped objects beeing left open
by default in PovRay ?
Gilles
Date: 5 Jul 2011 03:27:51
Message: <4e12bcf6@news.povray.org>
  clipped_by is faster to render than intersection.
Date: 6 Jul 2011 07:44:42
Message: <4e144aaa$1@news.povray.org>
Am 05.07.2011 09:00, schrieb 43oasis:
Yes: This way you can cut openings into otherwise solid primitives
(making them non-solid shells). That's essentially the difference
between clipped_by and difference (no pun intended).
Date: 6 Jul 2011 12:25:01
Message: <web.4e148b402a835bfec4da200b0@news.povray.org>
Thanks !
Gilles
Date: 6 Jul 2011 12:35:00
Message: <web.4e148d832a835bfec4da200b0@news.povray.org>
Thanks !
And : this RC3 is great on quad-core system !
Gilles
PS : what a pity the Special Relativity patch (Leo Brewin, 2005) was not
integrated into the official PovRay ; it would have been a real plus to this
fantastic software, for educational purposes (my case).
But that is an old story, I guess it was not as simple as "just plug it in" ...
