POV-Ray : Newsgroups : povray.beta-test : "Bad allocation" in POV-Ray RC3 for WIndows Server Time
25 Apr 2026 18:06:56 EDT (-0400)
  "Bad allocation" in POV-Ray RC3 for WIndows (Message 11 to 18 of 18)
Subject: Re: "Bad allocation" in POV-Ray RC3 for WIndows
Date: 12 Apr 2011 14:22:21
Message: <4da4985d@news.povray.org>
Am 12.04.2011 14:21, schrieb Christian Froeschlin:
> Tor Olav Kristensen wrote:
>> Can anyone else see this problem ?
> Don't see it here with 64-bit version on Windows 7.
> However, memory use increases by 1.2 GB during parsing
> before going into into saturation. So whether the bad alloc
> occurs may simply be due to available memory.
I can confirm this for Win XP x64 (same 1.2 GB).
I'll have a look at it with a debugger, maybe there's something to be found.
Date: 12 Apr 2011 15:06:35
Message: <4da4a2bb$1@news.povray.org>
Am 12.04.2011 02:41, schrieb Tor Olav Kristensen:
> I get this error message:
> "Parse Error: bad allocation  Render failed"
> - after the code below has been running for about 3 seconds.
> // ===== 1 ======= 2 ======= 3 ======= 4 ======= 5 ======= 6 ======= 7
> #version 3.7;
> #while (true)
>    #local Fn = function { transform { translate<0, 0, 0>  } }
>    #undef Fn
> #end // while
Having had a closer look at the code, I can confirm that this problem
indeed depends on the amount of memory installed in, and/or addressable
by, the user's computer.
As of now, POV-Ray "only" allows a maximum of 1048575 functions per
scene. Unfortunately, this is also the number of entries in a certain
table of function-related data POV-Ray allows before it re-uses entries
marked as deleted.
While this is good for parse speed in scenes using a lot of functions
(POV-Ray doesn't have to waste time searching the table for undef'd
entries), it's fatal for scenes re-defining functions over and over again.
Date: 12 Apr 2011 18:30:01
Message: <web.4da4d19ced9ecc0c734aecd0@news.povray.org>
> > #version 3.7;
> > #while (true)
> >    #local Fn = function { transform { translate <0, 0, 0> } }
> >    #undef Fn
> > #end // while
> marked as deleted.
I see.
I was just playing around with the new mesh_camera feature. For each triangle in
a mesh for a camera, I did a couple of vtransform() calls. (And if I have
understood things right, a mesh camera needs a lot of triangles...)
Perhaps it would be a good thing to make the vtransform() internal to POV-Ray
instead of just a macro (?)
Tor Olav
http://subcube.com
Date: 13 Apr 2011 04:16:26
Message: <4da55bda$1@news.povray.org>
> ... (And if I have understood things right, a mesh camera needs a lot
> of triangles...)
   Not necessarily: you can use an uv-mapped mesh with distribution #3
and the smooth option. But I don't know if this is convenient in your
case...
Jaime Vives Piqueres
http://www.ignorancia.org
Date: 14 Apr 2011 10:18:37
Message: <4da7023d$1@news.povray.org>
Am 13.04.2011 00:27, schrieb Tor Olav Kristensen:
It is quite an important macro, so as long as macros in .inc files are
the performance killers they currently are, it might indeed be a good
idea. Then again, maybe it would be better to put some effort into
speeding up .inc file macros in the first place.
As for the runaway memory consumption you discovered, that's obviously
not limited to vtransform(), so a fix is needed anyway (and is actually
already implemented by now, waiting to be released).
Date: 15 Apr 2011 17:35:00
Message: <web.4da8b9cded9ecc0c734aecd0@news.povray.org>
> > of triangles...)
> case...
Thank you for the tip Jaime.
I hadn't got around to experiment with that distribution type yet.
(Mostly because I find their descriptions a bit difficult to understand.)
But now I have just tried it with just 2 triangles in a mesh.
- and it works fine =)
If anybody else is interested, here's how I did it:
#version 3.7;
#declare H = 2;
#declare W = H*image_width/image_height;
#declare SimpleMesh =
  mesh2 {
    vertex_vectors {
      4,
      <-W, -H, 0>,
      <+W, -H, 0>,
      <+W, +H, 0>,
      <-W, +H, 0>
    uv_vectors {
      4,
      <0, 0>,
      <1, 0>,
      <1, 1>,
      <0, 1>
    face_indices {
      2,
      <0, 1, 2>,
      <2, 3, 0>
  mesh_camera {
    1
    3
    mesh2 { SimpleMesh }
sphere {
  -10*z, 1
  pigment { color Cyan }
light_source {
  <1, 1, 0>*10
  color White
background { color (Gray + Blue)/4 }
Tor Olav
http://subcube.com
Date: 15 Apr 2011 17:40:01
Message: <web.4da8ba99ed9ecc0c734aecd0@news.povray.org>
Yes, I agree.
But the vtransform() macro is a bit difficult to speed up ;)
That's good to hear.
Tor Olav
http://subcube.com
Date: 29 Apr 2011 14:16:35
Message: <4dbb0083$1@news.povray.org>
Am 15.04.2011 23:37, schrieb Tor Olav Kristensen:
> Yes, I agree.
Like any macro that resides in an .inc file, you /can/ speed up its
execution by copying it into your .pov file instead.
