![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
POV-Ray 3.7.0.RC3 on Slackware 13.0 x86_64.
I pointed povray to use the calibri.ttf font over on my Windows 7 partition.
The result is garbled - strange letters with accents appear instead of the
expected text. (KDE's kfontview opens calibri.ttf OK, with nothing strange).
Pointing povray to use other fonts of Win7, e.g. comic.ttf and arial.ttf, was
OK.
I solved the problem by pushing calibri.ttf through fontforge and resaving it
as mycalibri.ttf.
Cheers,
Peter
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> OK.
> as mycalibri.ttf.
> Cheers,
> Peter
Peter,
I am having the same issue when trying to use the Calibri font. Could you post
or email me the "mycalibri.ttf". I am not familiar with FontForge or how it is
used.
Clayton
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> OK.
>> as mycalibri.ttf.
>> Cheers,
>> Peter
> Peter,
> used.
> Clayton
fyi: that's been fixed:
http://bugs.povray.org/task/200
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> > OK.
> > as mycalibri.ttf.
> > Cheers,
> > Peter
> Peter,
> used.
> Clayton
Hi Clayton,
I have emailed a file to you from my yahoo.co.uk email.
Perhaps you could let me know here if you received it and it's OK.
Cheers,
Peter
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> > > OK.
> > > as mycalibri.ttf.
> > > Cheers,
> > > Peter
> > Peter,
> > used.
> > Clayton
> Hi Clayton,
> Cheers,
> Peter
Peter,
I got the file and added it to my fonts through the Font installer. I have
tried using it in POVRAY, but I am still getting strange characters when I run.
Is there another way to install the font? Or can I use it in another folder?
Clayton
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>>>> OK.
>>>> as mycalibri.ttf.
>>>> Cheers,
>>>> Peter
>>> Peter,
>>> used.
>>> Clayton
>> Hi Clayton,
>> Cheers,
>> Peter
> Peter,
> Clayton
you should be able to source that file if it's in your current directory
(or any /any/ path specified in Library_Path ... or wait until the fix
is released, as the modified font file /may/ become moot.
Ciao
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> Peter,
> Clayton
Have sent a revised file with a different internal name.
I assume you're on Windows (I'm on Linux) - and I wonder if Windows got confused
having 2 fonts with the same name, even though the .ttf files have different
names.
Cheers,
Peter
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Am 11.05.2011 20:58, schrieb Jim Holsenback:
It /will/ become moot :-) (tested it myself)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
