POV-Ray : Newsgroups : povray.beta-test : Unable to compile 3.7.0.RC2 Server Time
26 Oct 2025 11:52:52 EDT (-0400)
  Unable to compile 3.7.0.RC2 (Message 1 to 10 of 10)
Subject: Unable to compile 3.7.0.RC2
Date: 6 Jan 2011 21:50:01
Message: <web.4d267f12353f16d36999947f0@news.povray.org>
I can't compile 3.7.0.RC2.  Can anyone help?  When I run "make check", I get the
following:
In file included from ../../source/backend/control/renderbackend.h:101,
                 from ../../source/backend/control/messagefactory.h:100,
                 from ../../source/backend/frame.h:117,
                 from vm/fnpovfpu.cpp:296:
token
I'm also unable to compile beta 41.  The revision info from
source/backend/povray.h is
 * $File: //depot/povray/smp/source/backend/povray.h $
 * $Revision: #77 $
 * $Change: 5346 $
 * $DateTime: 2011/01/05 07:49:23 $
Here's the full transcript of what I did:
adam@birgitte:~/downloads/povray-3.7.0.RC2$ ./configure
--prefix=/home/adam/apps/povray-3.7.0.RC2 COMPILED_BY="Adam Crume <***@***>"
--with-openexr
Configure POV-Ray version 3.7.0.RC2
This is an unofficial version compiled by:
The POV-Ray Team(tm) is not responsible for supporting this version.
Environment
checking build system type... x86_64-unknown-linux-gnu
checking host system type... x86_64-unknown-linux-gnu
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking whether to enable maintainer-specific portions of Makefiles... no
checking whether $C_INCLUDE_PATH contains the "." path... no
checking whether $CPLUS_INCLUDE_PATH contains the "." path... no
Programs
checking for gcc... gcc
checking whether the C compiler works... yes
checking for C compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking for style of include used by make... GNU
checking dependency style of gcc... gcc3
checking how to run the C preprocessor... gcc -E
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking for stdlib.h... (cached) yes
checking for g++... g++
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking dependency style of g++... gcc3
checking whether the g++ compiler works... yes
checking how to run the C++ preprocessor... g++ -E
checking for C++ compiler vendor... gnu
checking for g++ version... 4.4.3
checking for ranlib... ranlib
Libraries
checking whether to link with cygwin DLL... no
checking whether to enable static linking... no
checking for the pthreads library -lpthreads... no
checking whether pthreads work without any flags... no
checking whether pthreads work with -Kthread... no
checking whether pthreads work with -kthread... no
checking for the pthreads library -llthread... no
checking whether pthreads work with -pthread... yes
checking for joinable pthread attribute... PTHREAD_CREATE_JOINABLE
checking if more special flags are required for pthreads... no
checking for boostlib >= 1.37... yes
checking whether the Boost::Thread library is available... yes
checking for exit in -lboost_thread-mt... yes
checking whether the boost thread library is usable... yes
checking for sin in -lmkl... no
checking for sin in -lm... yes
checking for clock_gettime in -lrt... yes
checking whether to use the ZLIB library... yes
checking for library containing zlibVersion... -lz
checking zlib.h usability... yes
checking zlib.h presence... yes
checking for zlib.h... yes
checking for libz version >= 1.2.1... 1.2.3.3, ok
checking whether to use the PNG library... yes
checking for library containing png_get_libpng_ver... -lpng
checking png.h usability... yes
checking png.h presence... yes
checking for png.h... yes
checking for libpng version >= 1.2.5... 1.2.42, ok
checking whether to use the JPEG library... yes
checking for library containing jpeg_std_error... -ljpeg
checking jpeglib.h usability... yes
checking jpeglib.h presence... yes
checking for jpeglib.h... yes
checking for libjpeg version >= 6b (62)... 62, ok
checking whether to use the TIFF library... yes
checking for library containing TIFFGetVersion... -ltiff
checking tiffio.h usability... yes
checking tiffio.h presence... yes
checking for tiffio.h... yes
checking for libtiff version >= 3.6.1... 3.9.2, ok
checking whether to use the OpenEXR library... yes
checking for pkg-config... pkg-config
checking for OpenEXR's pkg-config... not found
configure: WARNING: all program features using the OpenEXR library are disabled
checking for X... libraries /usr/lib, headers /usr/include
checking whether -R must be followed by a space... neither works
checking for gethostbyname... yes
checking for connect... yes
checking for remove... yes
checking for shmat... yes
checking for IceConnectionNumber in -lICE... yes
checking X11/Xlib.h usability... yes
checking X11/Xlib.h presence... yes
checking for X11/Xlib.h... yes
checking for XFlush in -lX11... yes
checking X11/xpm.h usability... no
checking X11/xpm.h presence... no
checking for X11/xpm.h... no
checking whether to enable the watch cursor... no
checking for sdl-config... no
checking for libSDL... not found
configure: WARNING: the preview display is disabled
Language constructs and functions
checking whether time.h and sys/time.h may both be included... yes
checking time.h usability... yes
checking time.h presence... yes
checking for time.h... yes
checking limits.h usability... yes
checking limits.h presence... yes
checking for limits.h... yes
checking sys/resource.h usability... yes
checking sys/resource.h presence... yes
checking for sys/resource.h... yes
checking sys/time.h usability... yes
checking sys/time.h presence... yes
checking for sys/time.h... yes
checking for unistd.h... (cached) yes
checking for size_t... yes
checking whether struct tm is in sys/time.h or time.h... time.h
checking size of int... 4
checking size of long int... 8
checking size of size_t... 8
checking size of float... 4
checking for working memcmp... yes
checking for vsnprintf... yes
checking for getcwd... yes
checking for readlink... yes
checking for nanosleep... yes
checking for clock_gettime... yes
checking for getrusage... yes
checking for gettimeofday... yes
checking for asinh... yes
Compiling
checking whether to enable pipes for communications... yes
checking whether g++ accepts -pipe... yes
checking whether g++ accepts -Wno-multichar... yes
checking whether g++ accepts -Wno-write-strings... yes
checking whether g++ accepts -fno-enforce-eh-specs... yes
checking whether to enable I/O restrictions... yes
checking whether to enable debugging... no
checking whether to enable profiling... no
checking whether to enable stripping... yes
checking whether g++ accepts -s... yes
checking whether to enable optimizations... yes
checking whether g++ accepts -O3... yes
checking whether g++ accepts -ffast-math... yes
checking whether to enable architecture-specific optimizations... yes
checking whether g++ accepts -xHost... no
checking whether g++ accepts -march=native... yes
checking which architecture to optimize for... x86_64-unknown-linux-gnu (using
-march=native)
Makefiles
configure: creating ./config.status
config.status: creating Makefile
config.status: creating source/base/Makefile
config.status: creating source/backend/Makefile
config.status: creating source/frontend/Makefile
config.status: creating source/Makefile
config.status: creating vfe/Makefile
config.status: creating unix/Makefile
config.status: creating config.h
config.status: executing depfiles commands
POV-Ray 3.7.0.RC2 has been configured.
Built-in features:
  I/O restrictions:          enabled
  X Window display:          disabled
  Supported image formats:   gif tga iff ppm pgm hdr png jpeg tiff
  Unsupported image formats: openexr
Compilation settings:
  Build architecture:  x86_64-unknown-linux-gnu
  Built/Optimized for: x86_64-unknown-linux-gnu (using -march=native)
  Compiler vendor:     gnu
  Compiler version:    g++ 4.4.3
  Compiler flags:      -pipe -Wno-multichar -Wno-write-strings
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -pthread
Type 'make check' to build the program and run a test render.
Type 'make install' to install POV-Ray on your system.
The POV-Ray components will be installed in the following directories:
  Program (executable):       /home/adam/apps/povray-3.7.0.RC2/bin
  System configuration files: /home/adam/apps/povray-3.7.0.RC2/etc/povray/3.7
  User configuration files:   /home/adam/.povray/3.7
  Standard include files:
/home/adam/apps/povray-3.7.0.RC2/share/povray-3.7/include
  Standard INI files:
/home/adam/apps/povray-3.7.0.RC2/share/povray-3.7/ini
  Standard demo scene files:
/home/adam/apps/povray-3.7.0.RC2/share/povray-3.7/scenes
  Documentation (text, HTML):
/home/adam/apps/povray-3.7.0.RC2/share/doc/povray-3.7
  Unix man page:              /home/adam/apps/povray-3.7.0.RC2/share/man
adam@birgitte:~/downloads/povray-3.7.0.RC2$ make check
make  all-recursive
make[1]: Entering directory `/home/adam/downloads/povray-3.7.0.RC2'
Making all in source
make[2]: Entering directory `/home/adam/downloads/povray-3.7.0.RC2/source'
Making all in backend
make[3]: Entering directory
`/home/adam/downloads/povray-3.7.0.RC2/source/backend'
g++ -DHAVE_CONFIG_H -I. -I../..  -I../.. -I../../source -I../../source
-I../../source/base -I../../unix -I../../vfe -I../../vfe/unix -pthread
-I/usr/include  -I/usr/include  -pipe -Wno-multichar -Wno-write-strings
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -pthread -MT fnpovfpu.o
-MD -MP -MF .deps/fnpovfpu.Tpo -c -o fnpovfpu.o `test -f 'vm/fnpovfpu.cpp' ||
echo './'`vm/fnpovfpu.cpp
token
make[3]: *** [fnpovfpu.o] Error 1
make[3]: Leaving directory
make[2]: *** [all-recursive] Error 1
make[2]: Leaving directory `/home/adam/downloads/povray-3.7.0.RC2/source'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/home/adam/downloads/povray-3.7.0.RC2'
make: *** [all] Error 2
adam@birgitte:~/downloads/povray-3.7.0.RC2$ uname -a
Linux birgitte 2.6.32-27-generic #49-Ubuntu SMP Thu Dec 2 00:51:09 UTC 2010
x86_64 GNU/Linux
Subject: Re: Unable to compile 3.7.0.RC2
Date: 6 Jan 2011 21:55:01
Message: <web.4d268024805b28c16999947f0@news.povray.org>
I'm sorry; I just realized this is a duplicate of a previous thread.  Please
disregard.
Date: 7 Jan 2011 05:37:26
Message: <4d26ece6$1@news.povray.org>
> following:
> token
>  * $Revision: #77 $
>  * $Change: 5346 $
> --with-openexr
> Environment
> Programs
> Libraries
> Compiling
> -march=native)
> Makefiles
> Built-in features:
>   Standard INI files:
> make  all-recursive
> token
> x86_64 GNU/Linux
builds ok for me ... 32bit opnsuse11.2
try a different configure string for:
./configure --with-boost-thread=boost_thread-mt
COMPILED_BY="jus### [at] testingorg"
I see that your transcript says it found 1.37 boost (/might/ be a
different directive on 64bit sys dunno) also your configure directive
calls for openexr but the transcript says no go ... so I'm suspecting
your setup. Have you recently added packages that you're built from
source ie: some of the requirements for povray and not refreshed your
library cache? ... ldconfig for me. Usually packages installed through
some platform specific tool (YaST) on my system it does that for you,
but when you drive the command line you need to do that.
Date: 7 Jan 2011 08:47:15
Message: <4d271963$1@news.povray.org>
   It also compiles fine here with Fedora 14 at first try... I didn't
even need to specify "--with-boost-thread" this time.
Jaime Vives Piqueres
http://www.ignorancia.org
Date: 7 Jan 2011 09:21:06
Message: <4d272152$1@news.povray.org>
just built out of the code repository and the boost configure directive
doesn't seem to be required anymore ... must have been the include that
Chris added ... but hey (ha-ha) given my track record as of late I won't
go to the bank with that!
Date: 7 Jan 2011 09:36:01
Message: <4d2724d1$1@news.povray.org>
> directive doesn't seem to be required anymore ... must have been the
> include that Chris added ... but hey (ha-ha) given my track record as
> of late I won't go to the bank with that!
   I'm sorry, but as usual I talked too soon: make did fail. Finally I
had to specify:
   for it to compile, so it must have nothing to do with the missing
include.
Date: 7 Jan 2011 09:56:43
Message: <4d2729ab$1@news.povray.org>
> had to specify:
> include.
>   Regards,
I suppose that I'd expect that you would have to as his change went in
last evening after posting the RC2 linux source ... or so it would seem.
I did however see an odd error when I did a sync with the code
repository ... ~source/unix/configure.ac was writable and perforce
issued a warning about not being able to clobber that file. chmod 444 on
the file and I was able to pull the new file.
After doing make distclean I did prebuild.sh (because i'm building
direct in my local version of repository on my system) in the unix
directory, but I'm seeing some warnings (unfamiliar) that urge me to do
autoupdate. So for whatever it's worth it DID build without the boost
configure directive. Hmmmmm
Date: 7 Jan 2011 10:10:00
Message: <web.4d272c4a805b28c1380f8080@news.povray.org>
../configure \
--with-boost-thread=boost_thread-mt \
COMPILED_BY="RC2"
make -j 2
make check
checkinstall (to build Slackware package)
just built and installed a seemingly working RC2 on Slackware 13.0 x86_64
No unexpected messages. make check looks OK.
My 30 minutely povray cronjob looks OK too - http://tinyurl.com/3xgm2sl
Cheers,
Peter
Date: 8 Jan 2011 05:55:01
Message: <web.4d2841fc805b28c1380f8080@news.povray.org>
Just for info, I need to specify --with-boost-thread in ./configure else make
fails. Slackware 13.0 x86_64, boost 1.38.
Cheers,
Peter
Date: 8 Jan 2011 09:50:00
Message: <web.4d287890805b28c1937718c80@news.povray.org>
I have two machines with Fedora 14 installed, one has "i386" architecture and
the other is "x64".
I need to add --with-boost-thread=boost_thread-mt to ./configure to make
povray 3.7.0.RC2 compile on the x64 machine, whereas this is not necessary
on the i386 machine.
Maurizio Paolini
