POV-Ray : Newsgroups : povray.beta-test : Build povray 3.7 beta40 on mac osx Server Time
25 Apr 2026 18:01:33 EDT (-0400)
  Build povray 3.7 beta40 on mac osx (Message 1 to 10 of 12)
Subject: Build povray 3.7 beta40 on mac osx
Date: 15 Dec 2010 15:10:00
Message: <web.4d091fcd62af24a47800993b0@news.povray.org>
Hello,
I would like to build povray 3.7 beta40 on mac osx snow leopard, but it doesn't
work.
"./configure" works without any problems, but "make" always produces the
following error:
.../../source/backend/support/task.h:184: error: thread-local storage not
supported for this target
MacMegaPov isn't an option for me, because I need a command line version of
povray.
Best regards
Subject: Re: Build povray 3.7 beta40 on mac osx
Date: 15 Dec 2010 15:22:30
Message: <4d092386$1@news.povray.org>
Le 15/12/2010 21:06, xoros nous fit lire :
> Hello,
> work.
> following error:
More clue in source/backend/frame.h
(in lines 1890+)
// platform-specific headers should have provided
DECLARE_THREAD_LOCAL_VARIABLE.
// if not, rather than generate an error, we will default to useing the
common
// __thread-style declaration. if your compiler throws an error on this
declaration,
// you'll need to fix your platform-specific config to provide a means
to declare
// thread-local variables. support for TLS is required for efficient
access by the
// render threads to their stats and cache data.
#ifndef DECLARE_THREAD_LOCAL_PTR
#define DECLARE_THREAD_LOCAL_PTR(ptrType, ptrName)       __thread
ptrType *ptrName;
#endif
But I'm afraid your compiler/os does not support per thread variables
(or if it does, it need to be instrumented in configure... )
Date: 16 Dec 2010 11:36:48
Message: <4d0a4020$1@news.povray.org>
On 15.12.10 21:06, xoros wrote:
> Hello,
> work.
> following error:
This is not surprising as Apple boycotts the GPL3 versions of gcc, which
effectively means all recent versions of gcc. What you need to do is select
the llvm compiler that comes with the latest XCode rather than use the
default gcc.
     Thorsten
Date: 16 Dec 2010 16:20:01
Message: <web.4d0a81d4ea80a0bbe45c8dfa0@news.povray.org>
> > Hello,
> > work.
> > following error:
I ran into this too.
> default gcc.
Could you just refactor the POV code to use boost's thread local storage
instead? Obviously more than just one person would find that helpful.
Cheers,
Edouard.
Date: 16 Dec 2010 17:44:27
Message: <4d0a964b$1@news.povray.org>
>>> Hello,
>>> work.
>>> following error:
>> default gcc.
> Cheers,
> Edouard.
haha ... just press the "easy button" and poof she's done ... not hardly
Date: 18 Dec 2010 03:21:30
Message: <4d0c6f0a$1@news.povray.org>
No, because we won't need that code at all and it will go away in 3.71. It
was actually changed from boost code to this at a time when I had little
time to take care of the Mac side, hence it was not noticed early on that it
is a problem.
	Thorsten
Date: 18 Dec 2010 04:05:00
Message: <web.4d0c784bea80a0bbe45c8dfa0@news.povray.org>
> is a problem.
Doesn't really help the Mac users now though. Unless you're going to release
some 3.71 alpha source in the next few days. That would be great.
>  Thorsten
Cheers,
Edouard.
Date: 18 Dec 2010 07:23:03
Message: <4d0ca7a7$1@news.povray.org>
>> is a problem.
Well, this is not new at all. It has been in the code for well over a year.
So expecting a release of new source code in a few days for seems rather
strange...
	Thorsten
Date: 21 Dec 2010 17:55:01
Message: <web.4d11287fea80a0bb7d4da7460@news.povray.org>
"xoros" <xor### [at] fakehostcom> wrote:
> Hello,
> work.
> following error:
> povray.
> Best regards
The patch below will make povray 3.7 beta40 compile fine on max osx.
Unfortunately, I'm not allowed to post attachements to this newsgroup so I also
put it here: http://pastebin.com/TYugP76L .
The idea is to use the thread local storage API defined by POSIX. It's not as
convenient as gcc's __thread but it is portable on POSIX platforms.
The last part of the patch brings the type uint alive by including sys/types.h.
diff -uwr original/povray-3.7.0.beta.40/source/backend/frame.h
new/povray-3.7.0.beta.40/source/backend/frame.h
--- original/povray-3.7.0.beta.40/source/backend/frame.h 2010-12-06
12:55:33.000000000 +0100
+++ new/povray-3.7.0.beta.40/source/backend/frame.h 2010-12-21
22:59:33.000000000 +0100
@@ -96,6 +96,9 @@
 // Generic header for all modules
+#include <pthread.h>
 #include <new>
 #include <stdio.h>
@@ -1898,9 +1901,55 @@
 // you'll need to fix your platform-specific config to provide a means to
declare
 // thread-local variables. support for TLS is required for efficient access by
the
+#ifdef __APPLE__
+template<typename T>
+class Pthread_Thread_Local_Storage
+ public:
+ Pthread_Thread_Local_Storage()
+    pthread_key_create(&m_key, NULL);
+ Pthread_Thread_Local_Storage(T *ptr)
+    pthread_setspecific(m_key, ptr);
+ //  ~Pthread_Thread_Local_Storage() {};
+  Pthread_Thread_Local_Storage& operator=(T const &rhs)
+    pthread_setspecific(m_key, rhs);
+    return *this;
+  bool operator!=(T* rhs)
+    return pthread_getspecific(m_key) != rhs;
+  T* operator->() const
+    return static_cast<T*>(pthread_getspecific(m_key));
+  operator T*() const
+ private:
+  pthread_key_t m_key;
+#  define DECLARE_THREAD_LOCAL_PTR(ptrType, ptrName)
Pthread_Thread_Local_Storage<ptrType> ptrName;
+#else
 #define DECLARE_THREAD_LOCAL_PTR(ptrType, ptrName)       __thread ptrType
*ptrName;
 #endif
+#endif
diff -uwr original/povray-3.7.0.beta.40/vfe/vfesession.h
new/povray-3.7.0.beta.40/vfe/vfesession.h
--- original/povray-3.7.0.beta.40/vfe/vfesession.h 2010-12-06 12:55:33.000000000
+0100
+++ new/povray-3.7.0.beta.40/vfe/vfesession.h 2010-12-21 22:36:54.000000000
+0100
@@ -94,6 +94,8 @@
 #ifndef __VFESESSION_H__
 #define __VFESESSION_H__
+#include <sys/types.h>
 #include <queue>
 namespace vfe
Date: 14 Jan 2011 14:50:01
Message: <web.4d30a896ea80a0bb2f451cea0@news.povray.org>
> > Hello,
> > work.
> > following error:
> > povray.
> > Best regards
I'm trying to compile RC2 and have the same error as the original poster.  This
patch doesn't seem to be able to be automatically applied to frame.h in RC2, and
I wasn't able to figure out what the changes need to be.  This patch does work
great for me on beta40; I checked today and was able to compile with no
problems.  In frame.h, what in beta40 we had:
Pthread_Thread_Local_Pointer<ptrType> ptrName;
#else
#efine DECLARE_THREAD_LOCAL_PTR(ptrType, ptrName)       __thread ptrType
*ptrName;
#endif
but in RC2 we now have:
boost::thread_specific_ptr<ptrType> ptrName
#define IMPLEMENT_THREAD_LOCAL_PTR(ptrType, ptrName, ptrCleanup)
boost::thread_specific_ptr<ptrType> ptrName(ptrCleanup)
#define GET_THREAD_LOCAL_PTR(ptrName)
(ptrName.get())
#define SET_THREAD_LOCAL_PTR(ptrName, ptrValue)
(ptrName.reset(ptrValue))
#endif
I'm not knowledgable enough to know how to modify the patch for RC2.  Can
someone help?  I'm trying to compile on Mac OS X 10.6.6 using the llvm-gcc
compiler.
Thanks for any help you can provide,
Adam
